Old 06-25-2007, 06:50 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default will a 99 2.5rs engine bolt into a 99 legacy outback?
ok I'm looking @ buying an outback for short money, its got 140k on the clock...the car is MINT....other than having a siezed engine...
can I directly bolt in a 99 2.5rs engine? or will I get a cell???
as long as its phase 2 will it be 100% bolt on ?
its not like I'm trying to change phases...
in vice versa... can I swap a (phase 1) 98 2.5rs engine into a 98 outback ?
IllNastyImpreza is offline   Reply With Quote
Old 06-25-2007, 07:01 PM   #2
gearsoup
Member#: 144100
the search button is your friend.....
also, more info would be helpful...
what does the legacy have in it right now? auto, 5 spd? there are small variables that actually do matter...
gearsoup is offline   Reply With Quote
Old 06-25-2007, 07:12 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
so I guess they both have to be iether stick ....or automatic ?
Old 06-25-2007, 10:48 PM   #4
djwhetzel
Member#: 109020
2015 WRX STi Limited
WR Blue
As far as I knew they were the same engine. Before I did my swap, I put a long block from a 1996/1997 Outback into my 1998 2.5 RS and everything bolted up just fine. As long as your using the same phase engine I don't think that you'll have any problems.
Actually any EJ engine can be swapped into any other EJ car. That doesn't mean that the wiring will be the same. Example, I put an EJ20G in my RS when I did my swap. Everything just fell into place other than the cross member. The wiring was a different story, but in your case, since they are the same year cars, I'm sure it will just drop right in. Don't take my word for it though because I'm not 100% sure.
Edit: I forgot to tell you that the EJ20G I used was an automatic also. All I had to do is remove the flex plate and install my fly wheel and clutch.
djwhetzel is offline   Reply With Quote
Old 06-26-2007, 01:30 AM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
yeah the wiring is the big part...I don't want to do any extra work. Just a direct swap into the Outback...
But I also assumed that since its the same year car... that the engines would be the same...
CEL = No good
Old 06-26-2007, 12:00 PM   #6
linsavy
Member#: 11620
1997 GF4-STiV3 clone
No they are not the same. 99 OB is Phase I DOHC, 99 RS is the hybrid phase II SOHC. You can swap the shortblocks but wiring is different on the heads. It can be done, but it is not plug and play.
My 99 Legacy heads are being married to a 99 RS SB as we type.
You can swap in a 1998 RS engine into the 99 Outback without issue.
Check out the N/A forum and franken engines.
linsavy is offline   Reply With Quote
Old 06-26-2007, 03:15 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Concur with linsavy. Shortblocks are interchangeable, but the intake manifold, heads, and various sensors are different.
Old 06-26-2007, 08:44 PM   #8
djwhetzel
Member#: 109020
WR Blue
Sorry about that. I didn't realize that the 99 OB still used the Phase I engine. I knew that they switched to the Phase II engine in 99 on the RS so I just assumed that they switched the entire line of Subaru's. They should have anyway. The Phase I engine was/is junk. By far the worst engine that Subaru ever made.
Is the OB the only Subaru after 98 that had the Phase I or did other Legacy's have them too?
Old 06-26-2007, 08:54 PM   #9
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
...The Phase I engine was/is junk. By far the worst engine that Subaru ever made.
I beg to differ.
civic2scooby is offline   Reply With Quote
Old 06-26-2007, 09:27 PM   #10
linsavy
Member#: 11620
The EJ25D is pretty crappy. Maybe Subaru made a worse engine back in the 60s, but that one has got issues.
Old 06-26-2007, 09:49 PM   #11
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
EJ25D may be a phase 1, but phase one is not all encompassed by the EJ25D
I know I am splitting hairs, but the EJ20G and EJ20K are both phase I motors as well. That was really what I meant by begging to differ.
Old 06-26-2007, 11:16 PM   #12
djwhetzel
Member#: 109020
WR Blue
I guess I should have been more specific then. I meant that the EJ25 Phase I engines are junk. I just assumed that since they were such pieces of crap, and this thread is based on the EJ25 engine, that everyone would know which engine that I was talking about.
I love my EJ20G.
Old 06-26-2007, 11:35 PM   #13
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
I love my EJ20G.
I was feeling knit picky today
Old 06-27-2007, 12:06 AM   #14
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
so...it looks like If I want to swap out an RS engine into an outback....they both have to be phase 1 ....
Old 06-27-2007, 12:12 AM   #15
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
have to be..no
plug and play..yes
if the block is just seized though you can slap the DOHC phase 1 heads/IM/sensors etc onto a 99 SOHC block and it will work just fine.
Old 06-27-2007, 12:14 PM   #16
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
have to be..no
plug and play..yes
hhmm I'm verry curious about doing just the block...
I wonder why an engine would sieze??? if they just didn't change the oil...I'm worried that the heads are damaged too...
whata u think ?
why would a subaru engine sieze?
Old 06-27-2007, 01:35 PM   #17
linsavy
Member#: 11620
The EJ25D not only is famous for headgasket issues, but also spins bearings. My guess is that it popped the HG, overheated and spun a bearing/broke a rod.
The heads would at least need to be cleaned and machined true and inspected carefully.
This head/sb combo yields 10.3 compression ratio depending on gasket used. I can let you know in a week if it runs significantly better.
Old 06-27-2007, 06:29 PM   #18
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
yup my guess would be the same as stated above. One way or another I would say it prob. spun a bearing. The other reason could be they deep puddled it and hydrolocked it.
if you have the 99 block laying around, pull the ej25D heads and take them to the machine shop to see if the heads are warped. If they are in good shape, slap those boys on the 99 block for a fabulous phase I/II frankestein
Old 06-27-2007, 10:26 PM   #19
djwhetzel
Member#: 109020
WR Blue
...One way or another I would say it prob. spun a bearing.
That would be my best guess too. That's what happened to the two EJ25's that I had in my RS before I did my swap. In fact, that's the biggest reason I did my swap. After spinning a bearing in two different EJ25's I wasn't about to put a third one in.
NYC: 99 2.5RS engine tranny rear diff misc ryceracerx Private 'For Sale' Classifieds 4 09-12-2005 09:13 PM
99 2.5RS Engine in parts RallyKid Private 'For Sale' Classifieds 3 05-01-2004 06:31 PM
99 2.5RS Engine in parts RallyKid Mid West Subaru Owners Club Forum -- MWSOC 5 05-01-2004 05:56 PM
FS : 99 2.5rs engine bruno Private 'For Sale' Classifieds 2 02-15-2004 10:39 PM
FS: 99 2.5RS engine/tranny/ecu smacksube Private 'For Sale' Classifieds 10 10-29-2003 08:10 AM
