Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 06-26-2007, 02:04 PM   #1
flatlander4510
Member#: 100935
2005 2.5RS
San Remo Red
Default Need help installing cams in '05 RS
Hey everyone,
I'm looking for someone who can help me install a set of cams in my '05 2.5RS. Pulling apart the engine is something I've never done before, so I'd like to have someone by my side who has. I'm located in Mays Landing (South Jersey). I'd be glad to throw you some $$ for the help.
Thanks!
-Harrison
flatlander4510 is offline   Reply With Quote
Old 06-26-2007, 03:56 PM   #2
piker28
Member#: 22664
something like that if you dont know what your doing it might be best to have a reputable shop do it... sometimes cost more but in the end its better
piker28 is offline   Reply With Quote
Old 06-26-2007, 04:44 PM   #3
flatlander4510
Member#: 100935
2005 2.5RS
San Remo Red
Right now, having a shop do it is completely out of my budget.
Old 06-26-2007, 05:16 PM   #4
piker28
Member#: 22664
gotta pay to play, if you install it improperly messing up the motor will cost a whole lot more
Old 06-26-2007, 05:24 PM   #5
flatlander4510
Member#: 100935
2005 2.5RS
San Remo Red
I understand that. That is why I want to have someone who's done it before help me. Plenty of people have done this on their own with no problems. Its not impossible.
Old 06-27-2007, 02:58 PM   #6
elsanto
Member#: 34832
1989 M3
is the engine out of the car yet?
elsanto is offline   Reply With Quote
Old 06-27-2007, 03:03 PM   #7
flatlander4510
Member#: 100935
2005 2.5RS
San Remo Red
Nope...its my daily driver, so I'd like to have it done in a day (which from what I've read, is a perfectly acceptable timeframe). I also understand that you can get by without removing the engine.
Old 06-27-2007, 03:44 PM   #8
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
for Sohc you dont need to pull the motor.
RS22b is offline   Reply With Quote
Old 06-27-2007, 10:29 PM   #9
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
remove radiator,
set engine to top dead center on cyl 1.
remove timing cover
remove timing belt and tensioner
pull valve covers
note cam lobe position/timing mark locations, white-out belt/cam and crank gear marks if necessary
unbolt cam bearing caps
remove cam, swap gear to new cam if necessary
install cams with lobes facing EXACTLY how they were before removing.
torque cam bearing caps down
install timing belt properly, lining up marks if you made them.
pull timing tensioner pin, force down on tensioner a little to further tension belt
turn crank with bolt 4 revolutions, if all is lined up, re-install everything.
add coolant.
start engine and let idle
realize you spent alot of money to gain an OK amount of power when making slightly higher payments on a WRX is much easier.
i'd help ya out, but im too damn busy anymore, sorry. good luck finding someone, its really not that hard to do, especially on a SOHC...
you should be able to have the cams out within 1 hour... removing the radiator gives you alot more room to work in the front of the engine. unbolting the engine from the Xmember also allows you to jack the engine up and move it more toward one side to gain more working room, then shove it to the other side to do the other cam..just dont forget to re-install the lower engine mount bolts when finished if you loosen them.
Murray is offline   Reply With Quote
Need help, installed cams, IAM down to 0 SubiFTW Open Source Reflashes 1 07-14-2009 11:50 PM
Need help installing uppipe in West MI pcpolo Mid West Subaru Owners Club Forum -- MWSOC 45 09-09-2005 01:38 AM
need help installing springs!! in ct jpsimon Tri-State Area Forum 26 08-08-2003 12:24 PM
need help install Utec in PA Area Yellow03Wrx Tri-State Area Forum 5 02-05-2003 09:33 AM
Need help installing springs in San Diego Porsche914boxer4 Southern California Impreza Club Forum -- SCIC 11 11-06-2001 11:16 AM
