Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Private Classifieds
Old 06-26-2007, 08:36 PM   #1
gling
Member Sales Rating: (33)
Member#: 122654
2002 v8 STI w/ GT30R
2013 GTR Premium
Default FS: VF39, Uppipe, V8 JDM STI Cluster, Lotek 3-Gauge A-Pillar Pod, Stock Boost Gauge
VF39: SOLD
This turbo came out of an 05 STI with less than 15k mi. on it. It has zero shaft play but has the typical crack on the hotside (refer to images attached below). I don't know how well it controlled boost but per the previous owner, it didn't seem to be an issue. I bought the turbo for a project but gave up on it midway. The other quirk with the turbo is that one of the hotside bolts is broken and is stuck in the housing (refer to images attached below). I was going to remove it but gave up halfway due to the failure in my project. If required, I think I can finish the job or have my machine shop take a look at it. It shouldn't be an issue anyways. Looking for best offer on this piece.
Uppipe: SOLD
This is a brand-new catless flex uppipe of unknown make. I am going to guess Tanabe but can't be quoted on it. If anyone wants to help out and chime in on its make, I'll greatly appreciate it. Its inner diameter seems to be a bit larger than most other uppipes I've come across. Looks beefy and if this piece doesn't sell, I might consider swapping it out for my Invidia one. Comes with a new header-to-uppipe gasket. Looking to get $105 shipped for this piece.
V8 JDM STI (2005) Cluster : SOLD
The cluster has less than 46,500 km (29,000 mi.) on it and is in good condition. It will fit all WRXs as far as I know but may require some slight modification. In terms of modification to fit, I know that 02-04 WRXs will need a tab to be shaved and a wire to be cut (5-minute job). I am not sure about 05+ WRXs; I think they don't require any modification at all but if anyone knows better, feel free to chime in. Looking to get $330 shipped for this piece.
Lotek 3-Gauge A-Pod: SOLD
Painted-to-match 60-mm pod for 02+ (as far as I know) WRX sedans. I had it on my 02 WRX for a few days and decided that A-piller gauge pods are not for me. It's pretty much brand new. I've managed to mount it in my car without having have to use the stock A-pillar piece by using two screws up top. This will save your stock A-piller piece from being hacked-up. Looking to get $60 shipped for this piece.
Stock WRX Lamco Boost Gauge: SOLD
Came with my car. It includes the steering-wheel mounted pod and gauge. Simple device and not much to say about it. Looking to get $40 for this piece.
Clear 02/03 Side-markers: SOLD
While these are eBay items, they are not the cheaper versions. They sell for $25 shipped on eBay and are of the "diffused" variety. Used them for a few weeks before getting some carbon fiber deletes. Looking to get $10 for them.
gling is offline   Reply With Quote
Old 06-26-2007, 10:08 PM   #2
fenderwrx
Member Sales Rating: (1)
Member#: 143139
2013 VW Golf R 2dr
Carbon Steel Gray
i'll take the boost gauge - where in ct are you?
fenderwrx is offline   Reply With Quote
Old 06-26-2007, 10:10 PM   #3
fenderwrx
Member#: 143139
2013 VW Golf R 2dr
Carbon Steel Gray
edit. just realized i bought a prosport boost gauge haha. sorry.
Old 06-27-2007, 12:35 AM   #4
PrecisionPB
Member#: 131769
2004 Impreza WRX
Black Mica
PM'd you about turbo.
PrecisionPB is offline   Reply With Quote
Old 06-27-2007, 07:50 AM   #5
gleinz
Member Sales Rating: (25)
Member#: 17541
I'll take the boost gauge.
gleinz is offline   Reply With Quote
Old 06-27-2007, 09:46 AM   #6
Mechie3
Member Sales Rating: (51)
Member#: 120152
Bump for the cleanest classified pics I have EVER seen.
Mechie3 is offline   Reply With Quote
Old 06-27-2007, 11:04 AM   #7
prj_miata
Member Sales Rating: (13)
Member#: 151043
2005 2.5RS cgm
2003 Wrx psm
pm sent
prj_miata is offline   Reply With Quote
Old 06-27-2007, 01:48 PM   #8
dirtyhartland
Member Sales Rating: (7)
Member#: 64298
lazy and in pieces
I just recently put a v8 JDM STi cluster into my 02 wrx. There is definitely no tab that I had to shave off. My car has been apart since I put it in, so it hasn't been run - so I don't know about cutting any wires... why is this necessary?
dirtyhartland is offline   Reply With Quote
Old 06-27-2007, 02:17 PM   #9
gling
Member#: 122654
2013 GTR Premium
Thanks!
If you have an 04 cluster, then it is plug and play. If you have an 05 cluster, then you have to shave a tab and cut a wire to prevent your radio/clock fuse from popping. Both 04 and 05 STIs are V8s.
Old 06-27-2007, 04:40 PM   #10
GetUpKid
Member Sales Rating: (8)
Member#: 130076
02 WRX w/ STi wing
PSM. 5Zigen. DC ShoeCO
bump for a good seller.
GetUpKid is offline   Reply With Quote
Old 06-27-2007, 05:02 PM   #11
rex2281
Member Sales Rating: (39)
Member#: 128808
2002 wrx sedan
black
does anybody have a bugeye with the sti v8 cluster installed in their car?? was it a simple install???this is a very nice cluster and i might be interested.
rex2281 is offline   Reply With Quote
Old 06-27-2007, 06:00 PM   #12
gling
Member#: 122654
2013 GTR Premium
My car is a bugeye. I have had both the 04 and 05 V8 clusters in them. What are your specific questions?
04 V8 clusters are pretty much plug and play unless you want to get the outside-temperature gauge going.
05 V8 clusters are almost plug and play. You will need to shave a tab on one of your connectors and cut a wire (or two depending on shift-buzzer). Both steps require 5 min. of your time total. Outside-temperature gauge will also require the same wiring as the 04 V8 cluster (or V7, I had that one too).
PM me if you have other specific questions.
Cheers.
Gerald.
Old 06-28-2007, 10:40 AM   #13
C4NiNjA
Member Sales Rating: (10)
Member#: 91964
2003 Impreza WRX WRB
349.9/354 Epic Tuned
contact bigboy.. he had one in his car. You can find him in the SE forum in the fayetteville thread.
C4NiNjA is offline   Reply With Quote
Old 06-29-2007, 09:00 PM   #14
gling
Member#: 122654
2013 GTR Premium
Bump to the top.
Old 06-30-2007, 11:03 AM   #15
bstoehr83
Member Sales Rating: (18)
Member#: 59698
2004 wrx VF39 w/meth
94 rhd STI 91 MR2
sent pm
bstoehr83 is offline   Reply With Quote
Old 07-02-2007, 08:33 AM   #16
gling
Member#: 122654
2013 GTR Premium
bump to the top
Old 07-02-2007, 07:04 PM   #17
SUBYS R US
Member Sales Rating: (36)
Member#: 99591
2003 18g w/38EWG
PSM(siver)
you have a pm
SUBYS R US is offline   Reply With Quote
Old 07-02-2007, 08:08 PM   #18
fenderwrx
Member#: 143139
2013 VW Golf R 2dr
Carbon Steel Gray
if i put that cluster in will it show the miles i have or the miles that are on the cluster?
Old 07-03-2007, 10:28 AM   #19
gling
Member#: 122654
2013 GTR Premium
It'll show the miles - or in this case, kilometers - on the cluster.
Cheers.
Gerald.
Old 07-03-2007, 10:53 AM   #20
i50caL
Member#: 94899
91 GTR, 75 S30Z,
97 STI, EVO X?
uppipe come with studs? PM me.
i50caL is offline   Reply With Quote
Old 07-05-2007, 12:37 AM   #21
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
$50 for the A-pillar shipped to 99515? Pm me
EvolvedAK is offline   Reply With Quote
Old 07-10-2007, 08:07 AM   #22
gling
Member#: 122654
2013 GTR Premium
Uppipe and A-pillar pod bump.
Old 07-10-2007, 12:46 PM   #23
nperkins
Member Sales Rating: (5)
Member#: 135812
90 Miata
04 Evo Rally Car
I want that pillar gerald, but you need to find me super deals on the gauges to go in them...
nperkins is offline   Reply With Quote
Old 07-10-2007, 01:02 PM   #24
gling
Member#: 122654
2013 GTR Premium
Now where did I put those old 60-mm bedside-clocks of mine...
Just kidding. How much are you looking to spend on the gauges?
Old 10-15-2007, 08:01 PM   #25
gling
Member#: 122654
2013 GTR Premium
From-the-grave bump; A-pillar gauge pod still for sale.
WTT: PA 04 STi Cluster for V8 JDM STi cluster soji Private 'Wanted' Classifieds 6 02-16-2007 10:57 PM
dual cluster pod + stock boost gauge? shineynitelite Electrical & Lighting 1 02-01-2007 01:17 PM
Lotek 3 guage A-pillar pod drez14 Interior/Dressup/Audio & Security 1 12-01-2006 07:01 PM
FS: v8 JDM STi Cluster Tuned New England Impreza Club Forum -- NESIC 10 05-13-2005 06:58 AM
3 gauge a pillar pod for 52mm gauges...asap dothespeedlimit Private 'Wanted' Classifieds 2 04-07-2004 09:14 PM
