Old 06-27-2007, 12:48 AM   #1
Paranoid Fabrications
Member#: 140712
2008 WRX STI
Default Super Pro trailing arm rear bushing install
well, i finally got around to install this. Install took about an hour for both sides. not too bad.
Tools needed.
17mm combo wrench
17mm socket
C clamp
2" scrap piece of tubing.
I started off by lifting the car and taking the wheel off. I could not find my jack stands so i used the stock jack and put the tire under the car in case it fell.
this is the bushing we are removing. its the bottom on on the knuckle. the stock bushing has a lot of play in it and is very soft.
Next up was removing the stock bushing. This was a PITA. you take the C clamp and put it on the knuckle as shown. you just keep cranking on it till the bushing pops out. the hardest part is just holding everything there and getting it started.
here is a pic of the two bushings together. notice the difference. the new bushings are a two piece design. so its way easier to install.
and a side shot to show the two pice.
just pop the new bushings in and insert the new metal sleeve. then bolt it up. nice and simple
Paranoid Fabrications is offline   Reply With Quote
Old 06-27-2007, 12:59 AM   #2
WRblueX_Guy
Member#: 53247
Nice.
You have Group N bushings pressed into your lateral links, right? What made you go with the poly bushings instead of the Group N for the rear trailing arm?
WRblueX_Guy is offline   Reply With Quote
Old 06-27-2007, 01:12 AM   #3
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
Originally Posted by WRblueX_Guy View Post
Nice.
Because you need a special tool and a huge press to install the Group-N bushings into the rear hub...
I tried the Group-N bushings first, but gave up and bought the Superpro bushings. 100x easier to deal with.
Old 06-27-2007, 01:25 AM   #4
WRblueX_Guy
Member#: 53247
Ah true. Luckily I'm next in line for Big Sky WRX's tool for the group n bushing
Old 06-27-2007, 02:15 AM   #5
Member#: 140712
2008 WRX STI
the groupn bushings were installed then taken off to paint. i have a seperate set of lat links (painted green ) ready to go back on. The reasion i didnt do the group in bushing is that there was a long line for that tool i have access to the presses and what not, so thats not an issue I have the groupN knuckle bushing sitting here when i have more time ;D
Shane
Old 06-27-2007, 08:32 AM   #6
fastwrx25
Member#: 126441
03 bugeye
did you break from the bolt side or nut side? I am having a hard time getting that bolt off.
fastwrx25 is offline   Reply With Quote
Old 06-27-2007, 12:13 PM   #7
Member#: 140712
2008 WRX STI
Yea, they are on there tight. i broke it from the nut site. just used a extension on my combo wrench
Shane
Old 06-27-2007, 01:00 PM   #8
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
I used my 3 foot breaker bar
Old 06-27-2007, 02:07 PM   #9
Member#: 140712
2008 WRX STI
crap, looking at that top pic it looks like my trailing arm is bent. hmm
Shane
Old 06-27-2007, 02:10 PM   #10
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Shane
Might be an optical illusion due to the axle peeking out there behind it along with a bend due to the camera lense.
Old 06-27-2007, 02:40 PM   #11
lovesmysuby04
Member#: 71494
07 Legacy GT
11 SSM Hatch
Air tools FTW. I like this mod cause I'm a bushing freak. Was there any noticable difference, maybe just a cuts down on the play from the rubber bushing is my guess.
lovesmysuby04 is offline   Reply With Quote
Old 06-27-2007, 04:56 PM   #12
Member#: 140712
2008 WRX STI
the car seems to rotate around corners a lot better. haven't had much seat time on it. I seem to feel more bumps
yea, air tools are nice, and while i have a good selection of them. I find it more tranquil to work on my car with out them. I usually only use them if i am in a hurry.
Shane
Old 06-27-2007, 10:26 PM   #13
mrpedal
Member#: 71361
2000 Impreza 2.5RS
my 2c: I used bigsky's bushing tool and put in the grpN a week or so ago (it's in the mail back to him as of monday for whomever was waiting on it). Very easy, but nowhere near that easy. As for the NVH, I detect only H, and like the alk, it's the muted thwack from road gaps/expansion joints, or other stuff. Not offensive at all. For the record, my wife did notice the change- over rough road around us, but wasn't bothered by it.
Handling wise, it's hard to isolate the change- I did front and rear trailing arms as well as whiteling lateral links at the same time. Oh wow is the back end nicer now. Nothing scary, but it really comes around better. Haven't had that 'oh wow this mod makes the car drive like it's on rails' feeling since the ALK & camber plates install.
As for the bolts holding the arms and links to the hub- I sprayed them once a week with PB Blaster for about a month before I did the job. I had air tools, but all the bolts came off w/o it really hammering at all. Main headache was the inner link bolts were only accessible with a wrench, and with the car up on jackstands there wasn't much room. Using a wrench on another wrench for an extension and a lot of grunting took care of that.
edit: And Shane- use some of that fender brace/cowl stay cash and get some harbor freight jackstands!
Last edited by mrpedal; 06-27-2007 at 10:31 PM. Reason: shane needs some @#$%ing jack stands!
mrpedal is offline   Reply With Quote
Old 06-28-2007, 01:17 AM   #14
Member#: 140712
2008 WRX STI
oh, i have jack stands. they are just big ones. (i work on a lot of off road trucks) and i ahd a set of smaller ones, but they are missing now
yea, those trailing arm bolts suck. those were some of the tighest bolts ever.
Shaen
Old 06-29-2007, 10:34 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Ok - I'll bite. You got me curious on these so I ordered up a few sets to try on our local test cars. Word from the US distrib is that they are out of stock though so it won't be for a while.
I noticed that superpro also make replacements for the forward end of the trailing arm. Have you considered trying those as well?
Old 06-29-2007, 10:52 AM   #16
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
I have the forward trailing arm ones as well. They were equaly useful.
Old 06-29-2007, 12:00 PM   #17
Member#: 140712
2008 WRX STI
no, i have a full set of GroupN bushings to go on. i just did those as it was real quick. I am working on another pair of trailing arms that i am going to reinforce to get rid of the weakness of it (twists easy) then install it. so within a month or so, the whole rear will be GroupN bushings, and maybe i will pull this one out for the GroupN bushing as well
oh, this place has them in stock. i bought mine from there and they shipped super quick. Global seems to be out of them
http://www.landefabrication.com/sess...iew.shopscript
Shane
Old 06-29-2007, 02:22 PM   #18
din
Member#: 93164
1999 Impreza
Are there any performance reasons as to why you are planning to change your rear end with group n's? or is it just for drivability and noise reasons?
BTW, when you are done could you please post pics and the results of your reinforced trailing arms. Thanks
din is offline   Reply With Quote
Old 06-29-2007, 02:28 PM   #19
Member#: 140712
2008 WRX STI
hmm. main reason is that i want a nice and tight rear end
if you push the car, i can feel the rear give some. it seems to be inconsistent. so i figure with nice new harder rubber it will be perfect. and the choice of GroupN ones, is that poly usually makes noise after a wile, and i don't want to deal with that (same reason i went with the GTspec ALK)
oh and don't worry, i will make a post on those arms
Shane
Old 08-16-2007, 01:36 AM   #20
Ottawagon
Member#: 87068
04 WRX Wagon
Oh man... in the middle of an install of the rear trailing arm group-n - it is killing me!
I thought I could pull the whole knuckle off, but I can't figure out how to disconnect the parking brake cable. I tried to lay the press down in there under the car, but that was too akward... maybe if I get a friend to help, but even then, it is hard to get that thing in the press, since the backside and dust cover are in the way of where you would want to brace it from.
I guess I can use your idea of a C-clamp to push out the original one, but I am sure that won't be enough force to push in the group-n. I guess I might have to make a tool with a big bolt and washer and cup to pull it in... this is taking a long time! Just fighting with all the bolts last night was brutal... I sprayed them first, but in Canada things get rusty and hard to work with.
BTW - for reference, I am putting sedan lateral links and new trailing arms and sedan rear axles on a wagon. Already pressed in all the other group-n bushings into the sedan links and the extra set of trailing arms, and gave those a good sand blast, primer and paint coat, so they are ready to go. Just need to deal with these bloody rear bushings!
Ottawagon is offline   Reply With Quote
Old 08-16-2007, 10:43 AM   #21
wrxwhite
Member#: 28632
2011 Legacy 3.6R
Dark grey metallic
The parking brake cable disconnect should be inside where the parking brake
shoes are.
wrxwhite is offline   Reply With Quote
Old 08-16-2007, 11:50 AM   #22
Member#: 140712
2008 WRX STI
yea, if doing the groupN bushing, you really need the bigsky tool. would make it way easy. it was out on loan when i asked, and i was too lazy to wait, so i went with poly
Old 08-16-2007, 02:27 PM   #23
Ottawagon
Member#: 87068
04 WRX Wagon
Yeah - going to try to make my own with a machinist friend in the next day or two... if it doesn't work out, I will leave the stock ones for now and wait until we can make a proper tool, or rent Mike's.
Old 08-23-2007, 10:16 AM   #24
Ottawagon
Member#: 87068
04 WRX Wagon
Update: Tool is done! Can't wait to try it later today.
Pics to follow...
Old 08-23-2007, 12:29 PM   #25
MasterKwan
Member#: 98961
2003 WRX
I just ordered a complete set of bushings from L&E. Looking forward to installing them. Cheaper than a set of pillow-balls (spherical links).
WRX trailing arm (front) bushing install JarHarms Brakes, Steering & Suspension 39 05-04-2010 03:21 PM
FS: MD STI lateral links, trailing arms, and Super Pro Trailing Arm Bushing boyracer_05 Suspension/Brakes/Handling 10 04-16-2010 12:46 PM
Rear trailing arm rear bushing QuickSilverSTi Brakes, Steering & Suspension 1 05-23-2005 11:21 PM
installed whiteline / super pro front and rear poly endlink bushings on my wrx wagon garie Brakes, Steering & Suspension 1 02-21-2005 08:46 PM
Rear trailing arm front bushing width? NicGordon Brakes, Steering & Suspension 0 12-28-2003 09:14 AM
Message Board Statistics All times are GMT -4. The time now is 06:25 PM.
