Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-29-2008, 11:32 AM   #151
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Originally Posted by CoolRex View Post
Indeed. The EJ207 pistons are forged whereas the WRX are cast or whatever you call it.
Yep... and the v.8 EJ207 AND the EJ257 are hypereutectic alum/silicone alloy. Strong, but brittle so they will hold power, but they are not very det resistant.
def
dug-e-fresh is offline   Reply With Quote
Old 04-29-2008, 12:27 PM   #152
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Originally Posted by dug-e-fresh View Post
Its more about the alloy/process of how they are made than the thickness of the ringlands. If I recall correctly, the V.7 and V.8 ringlands are the same size as WRX ringlands, but well all know what order we can put them in terms of holding power.... I'll have to get my pistons out and do a side by side comparison again. I have some of all 3.
def
Oh yeah definitely. I have a set of CPs lying around that are probably even thinner but obviously can take the abuse. I guess I just made the blind assumption that the compositions of the WRX and Leggy pistons are similar because of looks/weight. The weighed pretty similar (but obviously the legacy pistons will be heavier due to larger bore and physical size) but I would have no idea what their alloy is for sure.
TyranosaurusWRX is offline   Reply With Quote
Old 05-01-2008, 11:47 AM   #153
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
40 psi in cylinder number 4. after that i didnt even bother to test the others. its done! it lasted a while though. oh well... life goes on.
fantabulous is offline   Reply With Quote
Old 05-01-2008, 07:35 PM   #154
BoostUnderPressure03
Member#: 117724
2003 WRX
Ouch
BoostUnderPressure03 is offline   Reply With Quote
Old 05-01-2008, 08:52 PM   #155
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
did you ever get to take it to the strip?
Loomin is offline   Reply With Quote
Old 05-02-2008, 07:40 PM   #156
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
yes sir, i believe it did an 11.8 at 123ish? i forget it was a long time ago. oh and the clutch started to slip real bad when i got hot.
new motor should be in this weekend. its my birthday present to myself.
Old 05-03-2008, 02:06 PM   #157
Richie03
Member#: 38136
Any specs on the engine going in? I'm craving "The Nibbler" right now.
Richie03 is offline   Reply With Quote
Old 05-04-2008, 11:44 AM   #158
killthelights145
Member#: 88071
1985 Defender 90
i love this car
killthelights145 is offline   Reply With Quote
Old 05-04-2008, 01:28 PM   #159
mikaust
Member#: 7468
2008 Outback Limited
MMMM............... The Nibbler
mikaust is offline   Reply With Quote
Old 05-04-2008, 02:32 PM   #160
Devil27
Member#: 105600
RIP 05 wrx limited
03 MBP wrx coming soon
Originally Posted by killthelights145 View Post
i love this car
agreed
Devil27 is offline   Reply With Quote
Old 05-04-2008, 03:55 PM   #161
Paulys05wrx
Member#: 82433
2005 STi EFR 6738 &
WRX EFR 8734 Twin Scroll
Same thing happened to my old motor, but I was not pushing the same power you were. Cylinder 4 38 psi so I didn't even bother to check the others.
Paulys05wrx is offline   Reply With Quote
Old 05-05-2008, 03:29 PM   #162
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
DEFINITELY! We need to hit that up next time were down...
def
Parts swap needed: My stock 2.5 crank and rods for your stock 2.0 crank and rods. HamFist RMIC Private Classifieds 4 04-17-2009 10:10 PM
gettin 10.2 avg mpg in a STOCK 2.0.....causes? 03boxer4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-29-2006 09:16 PM
Want to switch from a blown stock 2.0 to an 2.5 sti short block jaltman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 02-01-2006 06:40 PM
Wnt to swtch to 2.5 sti block from blown stock 2.0 jaltman Subaru Conversions 8 01-11-2006 09:29 PM
fastest stock 2.0 and stock trans boardertj Proven Power Bragging 28 01-13-2005 08:11 PM
