Old 06-28-2007, 01:14 PM   #1
fastlanerex
Member#: 133391
2004 boosted saleen
white
Default where to mount extra bung on divorced wastgate downpipe.
Okay i have an invidia v3 divorced wastegate dp and want to know where to install another bung for an wideband aem uego. right now its where the stock 02 sensor is on the dp because i have an 02 sim but now that i removed the factory 02 i have a p0037 code so i need to put it back in and have another bung welded.
fastlanerex is offline   Reply With Quote
Old 06-28-2007, 01:21 PM   #2
tasq
Member#: 62362
2005 wrx
CGM
You shouldn't run the wideband on your DP anyway... run it further back.
tasq is offline   Reply With Quote
Old 06-28-2007, 02:20 PM   #3
fastlanerex
Member#: 133391
2004 boosted saleen
white
where on the midpipe? i was gonna run it right before the factory 02 sensor on the dp will it burn up that close to the turbo?
Old 06-28-2007, 02:31 PM   #4
fastlanerex
Member#: 133391
2004 boosted saleen
white
i was told by my local performance shop that it cant be more than 18 inches away fro the turbo
Old 06-28-2007, 03:51 PM   #5
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
It can be any distance from the turbo. Usually no closer than 3 inches though. 6-24 inches should be good. Being divorced wastegate doesn't change anything, just don't put it in the wastegate side of the pipe.
Old 06-28-2007, 05:59 PM   #6
hondaeater69
Member#: 60324
install it six inches in front of the oem sensor, assuming you're catless. if you are catted install it before the cat.
Old 06-28-2007, 06:09 PM   #7
WeldingHank
Member#: 98645
2002 WRX Wagon
I had mine in the main exhaust pipe about 6 inches back of the turbo when I had a bosal divorced shorty. Now, I have a megan racing DP that has its own auxilliary o2 bung, I have it there obviously.
WeldingHank is offline   Reply With Quote
Where to mount meth kit on 08+ STi Speedricer Water/Methanol Injection, Nitrous & Intercooler Cooling 22 10-27-2012 12:32 PM
Where to put widband bung on stromung midpipe? SubeN'Siren Commercial ECU Reflashes 11 03-20-2008 02:06 AM
Where to mount hood pins on cf hood krystek Newbies & FAQs 3 11-07-2006 01:44 AM
Stromung Divorced wastgate Downpipe 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 10-17-2004 11:29 PM
Extra gauges...which brand and where to mount gxt120 General Community 6 12-05-2002 05:32 PM
