Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 06-29-2007, 08:54 PM   #1
tube
Member#: 139485
2004 16g WRX DomTune
Java Black Pearl
Default Crashed the car, need some advice
So I'm driving down the road around 50-55 mph, squirrel runs out in front of me, swerve to avoid while braking hard, end up sliding sideways about 70 feet, front end goes into a brick pillar. UNDERSTEER FTL!!!
Both air bags went off. Radiator was crushed in toward the engine, front bumper destroyed, hood bent up, driver's side fender bent.
Wheels are fine, tie rods still connected, still steers. Motor still on it's mounts, transmission still on it's mounts, still rolls fine, goes into gear fine.
I didn't start it for fear of a broken timing belt, as well as the radiator being crushed up against the front of the motor.
I looked under the car (it rode up onto the pillar) and the subframe is intact, not bent. The front bumper beam/ cross member/ whatever, is totally bent etc. Driver's side headlight is obliterated. Battery pushed up etc.
How difficult is it to repair the front portion of the frame? Everything past the front of the engine is fine, but everything before that is ruined.
I would have pictures but I forgot my camera. I might have some in a few days.
tube is offline   Reply With Quote
Old 06-29-2007, 08:56 PM   #2
borat85
Member#: 146232
2005 wrx wagon
it seems like it is a pretty bad crash. not gonna be easy to fix... certainly not a diy job unless you work at a mech shop. sorry and good luck
borat85 is offline   Reply With Quote
Old 06-29-2007, 08:56 PM   #3
kreitz3
Member#: 100242
Hit the squirrel next time. Sorry to hear. I would say take it to a shop. But I don't have m3d tyt3 collision damage fixing abilities.
kreitz3 is offline   Reply With Quote
Old 06-29-2007, 08:58 PM   #4
yoda2
Member#: 143453
You should never swerve and brake at the same time. I suggest some driving courses.
yoda2 is offline   Reply With Quote
Old 06-29-2007, 08:58 PM   #5
soobiesvx93
Member#: 70782
2006 Impreza 2.5i
let this be a lesson...always slaughter the squirrel
soobiesvx93 is offline   Reply With Quote
Old 06-29-2007, 09:08 PM   #6
tube
Member#: 139485
Java Black Pearl
I've never hit an animal before, thought I could get away with it.
I've taken performance driving courses, these things don't instantly come to mind in a split second scenario.
How is the front frame/ bumper area even repaired in a general case?
Old 06-29-2007, 09:41 PM   #7
trotpntbll
Member#: 150954
2007 CGM WRX
Agile Tuned
Yea just cream the ****ed thing next time. Hopefully damage isn't to bad
trotpntbll is offline   Reply With Quote
Old 06-29-2007, 09:47 PM   #8
06stisilver
Member#: 141862
2006 Stage 2 STi
steel grey metallic
It won't be that bad I just rebuilt my STi that was wrecked and had the driver's side air bag deployed and everything from the motor up i had to redo myself, the rad shroud, new crash bar, 2 new headlights, new bumper cover, new subframe, 2 new fenders, i had some framework done and a new hood and it was about 4*** in parts. As far as if its a DIY job I bought a subaru service manual off of Ebay for 10 bucks and it breaks down everything in the entire car if you can read and follow that you can do anything I did the whole car minus the framework in my garage for a project car since feburary and i just finished it like a week ago
06stisilver is offline   Reply With Quote
Old 06-29-2007, 09:47 PM   #9
RexisMe
Member#: 96821
RexisMe is offline   Reply With Quote
Old 06-29-2007, 09:48 PM   #10
rkramer
Member#: 118209
2015 WRX Limitec
driving courses do absolutely zero when in a panic situation, experience is about all you really can go on. $hit happens unfortunately.
Old 06-29-2007, 09:54 PM   #11
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
I don't swerve for anything smaller then a large raccoon...
Mavrik is offline   Reply With Quote
Old 06-29-2007, 09:55 PM   #12
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
The whole point of driving courses are to show you how to keep your cool when a situation comes up.
wrxwhat is offline   Reply With Quote
Old 06-29-2007, 09:55 PM   #13
tube
Member#: 139485
Java Black Pearl
06stisilver,
could you tell me more about that, how did the original damage occur, pictures, how did you fix the crash beam etc?
Old 06-29-2007, 10:00 PM   #14
spongejosh
Member#: 62783
Midnight Black Pearl
will you be able to repair the car?
NO.
will a competent shop be able to repair the car?
YES - for a lot of monies.
josh
spongejosh is offline   Reply With Quote
Old 06-29-2007, 10:05 PM   #15
06stisilver
Member#: 141862
2006 Stage 2 STi
steel grey metallic
BEFORE
AFTER
Just needs painted hehe
Old 06-29-2007, 10:12 PM   #16
SQ3.0dotJP
Member#: 136330
# OCCUPY
***backs away slowly**
SQ3.0dotJP is offline   Reply With Quote
Old 06-29-2007, 10:17 PM   #17
PhamilySedan
Member#: 132249
2003 Bugeye PSM
RIP RSTi
^ lol.
PhamilySedan is offline   Reply With Quote
Old 06-29-2007, 10:18 PM   #18
CynicX
Member#: 48199
06 WRX
Yeah definitely hit animal next time. In this situation you would have been better off hitting a deer then a brick pillar. An a squirrel? Instead of all this you would have been sad for a couple minutes....or like me and laughed maniacally muahahaha
Glad your ok though!
CynicX is offline   Reply With Quote
Old 06-29-2007, 10:29 PM   #19
si12j12
Member#: 99697
04 wrx [wrb]
ni stage-ah san!
once upon a time there was a cat that ran across the street and a subaru owner that ran over it ...cat smashed, the end...
^true story
oh and sorry to hear about the wreck ....next time run over it !
..ahhh mighty awd works wonders on small creatures!
si12j12 is offline   Reply With Quote
Old 06-29-2007, 10:38 PM   #20
tube
Member#: 139485
Java Black Pearl
Hmm, your front end looks a hell of a lot better than mine does :\
Old 06-29-2007, 10:42 PM   #21
06stisilver
Member#: 141862
2006 Stage 2 STi
steel grey metallic
Am I correct in assuming that your damage is in the same area as mine?
Old 06-29-2007, 10:46 PM   #22
tube
Member#: 139485
Java Black Pearl
I'm assuming my front area on the drivers side is crushed in about 6" more than yours.
also my lower bumper beam/crash bar or whatever, is dented more than yours.
Old 06-29-2007, 10:53 PM   #23
06stisilver
Member#: 141862
2006 Stage 2 STi
steel grey metallic
Ah well i guess its up to you I'd say it's still fixable if you find a frame shop to straighten out your stuff and have them tack weld all your rad shroud stuff together this was the only part that I needed straightened
Old 06-29-2007, 10:59 PM   #24
tube
Member#: 139485
Java Black Pearl
hmm, I wonder how hard it is to fix that stuff...
Old 06-29-2007, 11:13 PM   #25
06stisilver
Member#: 141862
2006 Stage 2 STi
steel grey metallic
Framework is the worst part after that its not bad
Painting my car, need some advice/help icehockey101 Car Care & Detailing 25 11-18-2008 07:00 PM
looking at a few cars, need some advice loki993 Newbies & FAQs 21 11-08-2008 09:51 AM
Building a dedicated track car, need some advice on it... think Ariel Atom, ETC. Vintage_ Off-Topic 119 11-05-2007 12:47 PM
Going to the "Ring" Need some advice nrcooled Off-Topic 12 07-18-2007 05:59 PM
May have to sell my car, need some advice xjohnx Mid Atlantic Impreza Club -- MAIC 11 08-20-2003 03:55 PM
