Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 02-24-2001, 07:12 AM   #1
Scoobie Newbie
Member#: 4184
2004 WRX
World Rally Blue,Moonroof
Question 20mm Sway Bar
What does a sway bar do? How does it change the feel of the ride?
Scoobie Newbie is offline   Reply With Quote
Old 02-24-2001, 10:29 AM   #2
direwlf
Member#: 1479
1999 Impreza 2.5RS
Silverthorn Metallic
Post
A sway bar affects the way weight transfers from one side of the car to the other. A stiffer (IE Bigger) bar transfers some of the load from the heavily loaded tire to the tire without as much of the load. THis greatly improves the way the car handles. On the front of the car, it increases understeer and on the back of the car it increases oversteer. With a larger rear bar on an impreza, it is quite possible to get the tail out if you corner hard. Don't think it affects the ride too much normally.
direwlf is offline   Reply With Quote
Old 02-25-2001, 05:23 AM   #3
Scoobie Newbie
Member#: 4184
2004 WRX
Post
Thanks for your help.
WTB: 20mm Sway Bar or Adjustible Bar nate49509 Mid West Subaru Owners Club Forum -- MWSOC 1 04-02-2004 09:26 PM
quick question, what's the difference between 18mm and 20mm sway bars? popnGEAR Brakes, Steering & Suspension 17 05-15-2002 02:20 AM
20mm Sway Bar on FF 1.8L Install STi-Nismo Dood Brakes, Steering & Suspension 2 03-24-2001 11:38 PM
20mm Sway Bar on FF 1.8L STi-Nismo Dood Brakes, Steering & Suspension 2 02-18-2001 12:06 AM
18/20mm sway bar in Vancouver Cecil Vancouver Impreza Club Forum -- VIC 8 04-15-2000 11:48 PM
