Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 06-30-2007, 03:16 PM   #1
Division By Zero
Member Sales Rating: (10)
Member#: 7555
Default Garrett GT3282 Rotated Turbo Kit
Selling my GT32 based rotated setup. Up-pipe, DP, and turbine housing are ceramic coated.
Includes:
  • Garrett GT32 .78AR turbo (compressor is 82mm GT35R wheel upgrade in T04E housing and upgraded 360* thrust bearing)
  • SS-braided teflon oil inlet and outlet lines
  • UP 2.15" to 2.25" stepped design
  • DP 3.0"
  • Intake and K&N filter 3.0" with vac fittings
This is a direct bolt-on for any factory turbo Subaru. Compressor housing is cloackable 360*. It will even work with an existing TMIC with a short 45* bend to it (not included). AVCS equipped Subarus will need a different oil inlet line. WG is sprung to 14psi minimum. Will easily run over 30psi on a 2.5L motor. The turbine side is sized between a 30R and a 35R (64mm turbine inducer vs 60mm and 68 respectively).
Spool up is about 18psi or so by 4k rpms on a 2.5L in 4th gear (5spd).
Lots of money in this set up. Turbo has 4k miles on it. Fits like a glove in the engine bay. Low profile design as you can see. Generates little heat due to the ceramic coatings.
$1500 + shipping
Shot with NIKON D50 at 2007-06-30
For reference, here's a new kit on a completely stock car with TMIC. We simply used a short 45 degree bend....
Shot at 2007-06-30
Division By Zero is offline   Reply With Quote
Old 07-01-2007, 11:34 AM   #2
Division By Zero
Member#: 7555
Ttt....
Old 07-02-2007, 10:18 AM   #3
Division By Zero
Member#: 7555
Bump...
Old 07-03-2007, 11:24 AM   #4
Division By Zero
Member#: 7555
Up up up
FS MD: Perrin Rotated Turbo Kit (Minus the Turbo & WG) 9vapors MAIC Private Classifieds 9 06-13-2011 08:23 PM
F.S.: Garrett 35r rotated turbo kit w/ 44mm tial EWG, DP, UP complete hock3yplay3r20 MWSOC Private Classifieds 1 06-29-2009 11:24 PM
BCS Kits, Rotated Turbo Kits, AP's, Fuel Pumps(08's too), CP Pistons, and much more FlyingPerformance Engine/Power/Exhaust 24 12-06-2008 04:39 PM
FS: Ultimate racing rotated turbo kit w/ Insane ITS turbo shadymilkman129 Engine/Power/Exhaust 56 09-04-2008 09:21 PM
what kit rotated turbo kit? oo fast line oo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-18-2005 09:31 PM
