Old 06-30-2007, 08:18 PM   #1
Optical NZ
Member#: 120463
Default Switching to a Garrett turbo, oil feed different?
Hi all
Im upgrading from a vf23 and Ive bought an APS SR40 second hand but it didnt come with any oil or water fittings. The water lines i have sorted out. Im wondering if the oil feed needs to be changed..
The hole in the banjo bolt that goes into the head has a ~1mm aperture, then I have a braided feed line, then the banjo that went into my vf23 has a ~2mm aperture.
Will the garrett cored SR40 get enough oil if i keep the 1mm aperture head banjo and change only the banjo that goes into the turbo core?
Optical NZ is offline   Reply With Quote
Old 07-01-2007, 02:59 AM   #2
Displaced
Member#: 142459
C6 Z06
Bump.
Just because I'd like to hear some info on this as well. I'm installing a bigger snail soon too and am also curious.
Displaced is offline   Reply With Quote
Oil Leak: turbo oil feed line... UltimateLurker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 45 11-27-2010 01:20 PM
Oil Leak: turbo oil feed line... UltimateLurker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 10-06-2007 10:24 PM
Some stock parts, oil pan baffle pickup dip stick turbo oil feed line snwman Engine/Power/Exhaust 5 08-05-2007 06:29 AM
Turbo Oil feed line copper crush washers, where to buy? XWRATED Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-20-2006 12:57 AM
Garrett turbo oil pressure problems... 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 14 07-29-2003 02:28 PM
