Old 12-28-2001, 10:16 PM   #1
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Default First problem with Rex...
Rex started has its first problem at 10,100 miles. In the last two days I have noticed something going on. When cold the car stutters. If I use light throttle its ok but if I use more than 1/4 I get a bucking like there is a dead mis. Idle is perfect. Power is normal. It just cuts out and generaly feels bad. Once warm I had no issue. The mis and cut out is slight so I passed it off.
This morning.. Same thing. Slight stumble when cold. Nothing major. Go past 1/4 throttle and it smooths out. Not much to worry about but it is stumbling.
On the way home on Decel I noticed something odd.. As many of us know on decel there is still some fuel being injected so the decel is smooth. In my car on decel on the highway I can feel the fuel being turned off and on. One sec ther is major pull and and slows down fast, the next sec I am at normal decel.
At light part throttle cruise if you let off the slightest bit on the pedal the car falls on its face as if you turned the motor off. Push the gas pedal in a bit and you get your power back as normal.
Odd problem. Again, The car idles perfect. WOT power is normal. No CEL. Car is bone stock and I just did 1000 miles in it over the holiday.
CT
AZScoobie is offline   Reply With Quote
Old 12-28-2001, 10:28 PM   #2
mdntridr
Member#: 8886
2004 Ford Ranger
'05 Honda VTX1300C
Default Re: First problem with Rex...
Me too!!!
I've just been ignoring it or chalking it up to some Unichip weirdness (just got the chip a few weeks ago).
*thinking*
--Greg--
mdntridr is offline   Reply With Quote
Old 12-28-2001, 11:51 PM   #3
wrxspdr
Member#: 10570
2002 wrx
maybe fuel filter or plugs also cats maybe need to warm up
wrxspdr is offline   Reply With Quote
Old 12-29-2001, 12:28 AM   #4
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Check your coils. They may be toast after using the Link. Don't ask me to elaborate. I will only say that someone I know attempted to tune a WRX with one. He killed a coil with it.
If that isn't it, check all vacumm connections.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 12-29-2001, 01:20 AM   #5
AZScoobie
Member#: 8785
netcom.com
Ken
I am using and have been using the stock ECU. I have a link but it is not in the car right now. I think I will start with Plugs. Now, who has Plugs instock?
Thanks
CT
Old 12-29-2001, 02:37 AM   #6
SPeeDSiN
Member#: 4667
Black (well kinda)
ok...
where did you get the link. I'm ready for mine!
SPeeDSiN is offline   Reply With Quote
Old 12-29-2001, 09:52 AM   #7
Obsidian
Member#: 5627
06 WRX STi
FWIW I have the same thing in my wagon. I had chalked it up to a cold clutch and flywheel though. The clutch won't grab as hard as it does when it is warm when it is cold. After a minute or two it goes away. So, who knows which is right...
Obsidian is offline   Reply With Quote
Old 12-29-2001, 09:55 AM   #8
phxscooby101
Member#: 4355
Azscoobie i thought you were catless do you think it has
something to do with that?
phxscooby101 is offline   Reply With Quote
Old 12-29-2001, 01:13 PM   #9
AZScoobie
Member#: 8785
netcom.com
PHX:
I am not catless... I am stock again.
SPeeDSiN
I am selling the Link if you want it..
CT
first problem with suby jakedown Newbies & FAQs 23 11-20-2006 03:56 PM
First problem with MY06 c2g Newbies & FAQs 29 11-15-2006 12:19 AM
First problem with accessport, sort of. CryderSpeed AccessPort 0 07-21-2006 01:05 AM
First problem with STi... CEL, CRUISE, Parking essogas Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 01-16-2005 05:02 PM
any major problems with 04 REX i should know about jimtweet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 05-04-2004 12:08 AM
