Welcome to the North American Subaru Impreza Owners Club Friday August 1, 2014
Old 07-01-2007, 10:21 AM   #1
stcktnkid
Member#: 76743
04 WRX
Default button on automatic shifter wont engage to move out of drive
I am driving a 93 impreza wagon with an automatic transmission. Once and a while, I will start the car, and put my foot on the brake to shift outof drive. when I go to press the button on the shifter with my thumb to put it into drive or reverse, the button wont push in, so i cant get the car out of park. I will play with the button and wiggle the shifter, turn the car on and off a few times, pump the break peddle, and nothin, then eventually it will just press in, and shift gears.
And when I am driving the car drives and shifts gears fine on its own. But the button wont engage sometimes on the shifter. Anyone know what would cause this or how to fix it.
It happened at the gas station recently and I was sitting at the pump forever playing with the shifter untill the button randomly pushed in and i could shift gears.
thanks
stcktnkid is offline   Reply With Quote
Old 07-01-2007, 10:43 AM   #2
stcktnkid
Member#: 76743
04 WRX
i think its called the shift interlock system. I dont have an owners manual with the car. Is there a way to bypass the shift interlock so you dont have to push the button to shift gears?
Old 07-01-2007, 01:02 PM   #3
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
That's exactly what it is. You can remove the center trim from the car enough to get to the micro-switch that activates the interlock. If in fact you move the switch and everything works, then you know that the shifter assy. itself is the problem.
The last vehicle I looked had a similar issue, they could not remove their key from the switch. Turns out the little tab on the shifter assy., was bent and would not activate the switch.
Check and see if the tab, looks more like a straight pin, is bent.
Pacobeagle is offline   Reply With Quote
05 wrx wont go in and out of 2nd gear freely.....shifter linkage?? password:ej20 Transmission (AT/MT) & Driveline 0 01-29-2010 12:35 AM
Wont engage to first gear..STUCK 97sportwaggie Transmission (AT/MT) & Driveline 10 11-23-2009 01:45 PM
So I'm getting ready to move out of the apartment, and didn't put down a deposit.... nos Off-Topic 7 11-14-2007 10:09 PM
Have to sell!! Have to move out of the country for good... imprzaWRC Southern California Impreza Club Forum -- SCIC 4 04-26-2001 12:21 AM
Group buy on lines moves out of midwest ralyrcr Mid West Subaru Owners Club Forum -- MWSOC 2 01-31-2001 05:48 PM
