Old 12-28-2001, 10:46 PM   #1
yuzo
Member#: 9197
Question how can you tell if your differential was damaged due to towing?
i got into an accident in feb of 00' and am wondering if there was any drive train or differential damage. i'm not really sure if they did tow it on all fours or just on two so i'm am wondering on that?
yuzo is offline   Reply With Quote
Old 12-29-2001, 01:10 AM   #2
CosmoTheCat
Member#: 3409
If you can drive it then most likely there were no tires on the ground. A lot of tow companies use wheel dollies to lift the rears off the ground and then hoist the front up with the truck. Works as well or better than a flatbed (if they don't have keys to your car anyway).
If you really want to know, change the fluid. If there is a lot of crap in it, then something might be wrong.
CosmoTheCat is offline   Reply With Quote
Old 12-29-2001, 02:41 AM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Any damage that occured would have hurt the centre Viscous Coupling (assume your car is manual) which is sealed.
Changing the fluid won't tell you anything.
The car would drive like crap - could act like a FWD car, but it depends on how fried the VC got.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 12-29-2001, 03:27 AM   #4
CosmoTheCat
Member#: 3409
My bad.
Old 12-29-2001, 11:44 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
But you're right that most towing companies know the deal with Subarus. Except that he's in Honolulu..... are there a lot of Subies there?
Aloha!
Old 12-30-2001, 02:53 AM   #6
yuzo
Member#: 9197
Talking
nope.. not many subarus around here...mostly hondas and acuras. yes my car is MT and still running and am hoping that nothing went wrong.
p.s. don't come to hawaii to live. i say if you want a pretty good vaction, then you can come here. but if you would like to live here, think again busta cause the cost of living is toooo high, job opening suck, and the hawaiians here think they own everything.
How can you tell if your turbo has a clipped wheel? SolidSnake General Community 0 02-25-2006 02:11 PM
So how can you tell if your post was deleted? jonny_boy Off-Topic 8 08-07-2003 09:42 AM
How can you tell if your clutch is slipping? SoLo OnE Transmission (AT/MT) & Driveline 7 06-12-2002 02:05 AM
How can you tell if your boost gauge is accurate? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-01-2001 07:24 PM
How can you tell if your diff is not working? codemunky Technical Forum Archive 5 09-17-2000 09:53 PM
