Old 07-01-2007, 03:06 PM   #1
dangle
Member#: 149172
2006 impreza sti
white
Default just got my car dyno tuned. is this about average for my car?
2006 sti
mods:
greddy fmic
pe 850cc injectors
perrin intake
invidia downpipe
greddy catback
turbo xs rfl bov
fp green
turbo xs utec
tuned on pump gas at 21 psi then dropped to 19 at redline.
345hp and 338 tq on a mustang dyno.
tuner said thats most he can make without engine knocking. what do you guys think?
dangle is offline   Reply With Quote
Old 07-01-2007, 03:11 PM   #2
lev98
Member#: 140529
01 Ferrari 360 spy
Every dyno is different so take it to the track and you can get a better idea of how you compare.
Besides mustang dynos read low anyway.
lev98 is offline   Reply With Quote
Old 07-01-2007, 03:44 PM   #3
dangle
Member#: 149172
2006 impreza sti
white
true. hoping to break 11's. thanks
Old 07-01-2007, 03:50 PM   #4
wgknestrick
Member#: 32576
04 STI
That's about right. Green's really don't 400whp like everyone posts (or at least I've never seen one first hand).
They are pretty much a (solid) 350whp turbo and should make that on most "accurate" dynos.
wgknestrick is offline   Reply With Quote
Old 07-01-2007, 07:32 PM   #5
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
Originally Posted by dangle View Post
2006 sti
Seems like you are very close to the knock threshold!!!! Be careful.....
BBBsti LTD is offline   Reply With Quote
Old 07-01-2007, 08:52 PM   #6
dangle
Member#: 149172
2006 impreza sti
white
Default i know
i know im very scared, although he did say he did a semi conservative tune it still flashes check engine when i go full boost.
Old 07-01-2007, 09:01 PM   #7
Member#: 111556
2006 STI
rofl....dont drive the car like that
xerox445@yahoo.com is offline   Reply With Quote
Old 07-01-2007, 09:04 PM   #8
Sogonerg
Member#: 108207
on race gas you'll hit 400whp...but 350whp is what I would aim for on pump gas...thats still a bit on the high side usually 330whp on ours. DD Dyno...The "real heart breaker"
Sogonerg is offline   Reply With Quote
Old 07-01-2007, 10:30 PM   #9
dangle
Member#: 149172
2006 impreza sti
white
dont drive the car like that? so you're saying dont ever wide open throttle the car or are you saying dont drive the car while its flashing check engine when i boost?
Old 07-01-2007, 10:37 PM   #10
dangle
Member#: 149172
2006 impreza sti
white
thanks for the information. im happy with the power now but i was sort of hoping for alittle bit more because the kit i bought. which was a 'stage 4'. and when people ask me you only gained 50 hp with a stage 4 kit?
Old 07-01-2007, 10:45 PM   #11
SoGardSuby
Member#: 144104
2013 Ram Big Horn
actually u gained more like 105hp...ur making 345whp now. stock u were making around 240whp
SoGardSuby is offline   Reply With Quote
Old 07-02-2007, 12:02 AM   #12
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
retune it
Kastley85891 is offline   Reply With Quote
Old 07-02-2007, 05:51 AM   #13
TeamTHP
Member#: 151994
05 STI "Stage 2"
[email protected], 1.78 60's
who tuned your car
TeamTHP is offline   Reply With Quote
Old 07-02-2007, 09:58 AM   #14
VWGrk1
Member#: 57882
2004 WRX
Well, you can't just look at peak #'s and call it a day. Consider the shape of the curve- larger snails tend to make power all the way to red line versus the stocker that dies off in the upper-rpm range.
If your CEL is flashing, then you need to go back to your tuner and tell them that your motor is knocking. This is bad and should be fixed right away. Stop flooring the car.
VWGrk1 is offline   Reply With Quote
Old 07-02-2007, 12:06 PM   #15
karl750
Member#: 100977
2004 VF30 WRX
[email protected] 1.84 60'
Maybe the tune is fine but you've just got a tank of bad gas. I'll get those a few times a year.
As for your numbers, i wouldn't worry about it too much. Take your car to the track and see what it traps. On a dyno jet last year with my stage 4 setup, i made 200whp, but then trapped a 104mph at the strip. So obviously the dyno was low reading but still tuned well. Dyno #'s don't mean much IMO.
karl750 is offline   Reply With Quote
Old 07-02-2007, 12:14 PM   #16
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
thats bull****.... take it back to your tuner and get a retune... a good map should not knock... if a bad tank of gas is causing it to knock its tuned to the edge. Try putting some colder plugs in it and see if that helps...
If it were me, id take it back to the tuner and get it retuned though and if your knocking at full boost, the last thing your going to need to do is take it to the drag strip, your car will start pulling timing the second it knocks and you woulnt get a good time anyways...
All4bSpinnin is offline   Reply With Quote
Old 07-02-2007, 03:30 PM   #17
SuperStreet
Member#: 115793
2006 Subaru STI
Aspen White, FP Green
SuperStreet is offline   Reply With Quote
Old 07-02-2007, 08:11 PM   #18
dangle
Member#: 149172
2006 impreza sti
white
here is my dyno sheet:
yeah i stopped flooring the car right afterwards when i saw the check engine flashed. after your car gets off the dyno you're going to want to of course test it out and floor it. that was the only time though.
yeah, for some reason i was hoping for 375-400 cause that was what the shop would tell me so i was a little disappointed in 345. but now that i see other dyno sheets, thats about average. as for now i am just throwing in a bottle of octane booster each full tank to be on the safe side.
yeah i will have to, problem is i live in seattle washington and the shop is in portland oregon. 3 hour drive away
Originally Posted by SuperStreet View Post
thanks.
Originally Posted by TeamTHP View Post
who tuned your car
PDXtuning.com they are located in portland, oregon
Old 07-02-2007, 08:37 PM   #19
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Different dyno and slightly different setup. Although the bases are there (257/Green/850s). I made 340/340. So you sound about right to me. How do you like that greddy fmic? I hear mixed reviews on it.
DoctorNick is offline   Reply With Quote
Old 07-02-2007, 08:48 PM   #20
dangle
Member#: 149172
2006 impreza sti
white
the greddy fmic is fine, i sort of dont like the way it looks on a 06 front end because of how it has the bigger mouth then 04-05's.
Old 07-02-2007, 10:10 PM   #21
subenerd
Member#: 72630
2004 STi
God forbid you put the year/model of your car in the thread title
subenerd is offline   Reply With Quote
Old 07-03-2007, 01:54 AM   #22
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
something is going on with the timing curve. There is a pretty major dip in the midrange. Might be knock correction. Might be the timing curve. Might be the AVCS mapping. Hard to say. The peak power is not bad.
Clark
AZScoobie is offline   Reply With Quote
Old 07-03-2007, 02:05 AM   #23
WRXINTX
Member#: 96712
Clark
Does the Cobb Street tuner software adjust the AVCS curve also??
or which systems will tune the AVCS?
thanks Clark!
RYNO
WRXINTX is offline   Reply With Quote
Old 07-03-2007, 02:08 AM   #24
flatthump
Member#: 102749
2005 impreza STi
OBP'
Yes it will^
Did he forget to disable a CEL?
flatthump is offline   Reply With Quote
Old 07-03-2007, 02:10 AM   #25
AZScoobie
Member#: 8785
netcom.com
thanks Clark!
RYNO
Yes. Cobb street and pro tuner software will adjust the AVCS maps. Most tuners do not adjust them however. I have no idea on this car in this thread. I just noticed that power is dipping down and back up around 5000 rpm.
Clark
is this exhaust overkill for my setup? iNfEk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-26-2009 09:41 PM
just got my car dyno tuned. is this about average for my car? dangle Proven Power Bragging 7 07-01-2007 05:04 PM
Just got the utec dyno tune at turbotrix jimball21 Tri-State Area Forum 34 09-22-2004 09:57 AM
Is this going to ruin my car? Its about wiring lights DangeRS Interior & Exterior Modification 2 10-18-2001 02:40 PM
