Old 12-29-2001, 02:03 AM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Question Power Steering (around there) Leak
Ive got a leak coming from aparently below my power steering pump... (same color fluid, its trickled down to the block)
Anyone ever have this problem, or know what it is? Its a slow leak, and the fluid level isnt down, so its not like a pipe is busted
Old 01-26-2002, 10:37 PM   #2
sc00by25rs
Member#: 1406
2013 HKS boosted BRZ
yeah, i just found one, it seems like it is coming from under the turbo, whatever power sterring line runs acroos in front of the front axle, im not sure how it happened yet though, i ngot to take it to subaru or a lift and check on mon.
sc00by25rs is offline   Reply With Quote
Old 01-28-2002, 09:18 PM   #3
wrxracer
Member#: 5275
2002 impreza WRX
WR BLUE
Lightbulb pwr steering
take it to your dealer. i had this problem and it seems there is some o-rings that do not seal well and they have to be replaced, this was done by my dealer about 5months ago. keep an eye on the fluid level, it will leak out quick..
wrxracer is offline   Reply With Quote
Old 01-29-2002, 07:33 AM   #4
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
Barry is offline   Reply With Quote
Old 06-14-2003, 04:17 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well guess what? My power steering pump is leaking again Im not gonna waste another $300 whatever dollars getting the pump itself replaced, so someone tell me how to fix this myself and how to tell if its the O-ring or some other issue with the pump...
Its definatly in the pump or the resevoir, cause the leak is coming from right in the middle of the black metal resevoir housing and isnt leaking from anywhere else above that. The fluid level isnt droping dramatically, but its definatly all over the engine again...
BTW, all that other info about the WRX's has to do with the power steering lines under the car not the pump type leak like I have.
Old 11-01-2003, 01:01 AM   #6
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
This just happened again on my car...The 1st time I caught it before the the tank went dry. Now my P/S failed completely because I thought it was fixed and I didn't worry about checking the level. The bolt that was leaky is the high pressure pump line under the turbo and above the passenger side CV axle. I tightened the bolt thinking everything was cool...but apparently it came loose again or the O-ring just isn't holding.
Edit BTW-
Does the pump running dry mean damage to the pump... How long will the pump last with out fluid??? I try to keep it full but it goes through a 1/2 quart of ATF per day. THe cardboard in the driveway is saturated with it
Turbo9000 is offline   Reply With Quote
Old 11-01-2003, 09:00 AM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
on my L i went through 3 pumps
before i found one that wouldnt leak
seems to be a curse on those older cars...
and believe it or not? the one that 'worked'
i bought used for $75 from a junk yard...
i think they are weak and just tend
to go bad.
i've run em dry before with no consequence
other than the PS wouldnt work
(which was hell in 100F middle of
the CA Desert and 2 full rally stages.... )
not sure resealing helps...
but it's worth a shot... and fairly simple to do.
2nd time my PS pump went i just went
and bought the used/rebuilt one...
good luck
jamie
www.subiegal.com
Old 11-01-2003, 10:15 AM   #8
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
geez..replacing the pump would suck.. Im fairly sure that this is just the same fitting that came loose last time.This time...after some spirited driving all of the fluid leaked on to the down pipe and smoked really ######## which scared the ***** out of me when I looked in my rear view. No P/S on the subaru is harder than I thought... those 225's just dont wanna turn.
Old 11-01-2003, 12:44 PM   #9
Hawk296
Member#: 14555
1995 Impreza L
Baja
Didnt you convert pumps or resevoirs or something?? bummer to see it leaks. My L pump leaked too. I think its just a bad design.
I switched mine over to the 02-current design with the remote resevoir and so far havnt had any problems (18,000 miles on this setup). But thats kind of a hassle to change over and expensive if you dont have the pump already.
ide probably try and reseal it or find a way to seal it better, try and save some cash.
Hawk296 is offline   Reply With Quote
Old 11-03-2003, 06:02 AM   #10
Ozymandias
Member#: 44238
1996 Impreza w/2.2t
Yellow
i have the same leak. the lady i bought it from said that she had just replaced the o-rings but looks like i will be 'replacing' it again.
any idea on the cost of the o-rings?
(stupid cold weather, makes for horrible conditions to work on one's car)
Ozymandias is offline   Reply With Quote
Old 11-03-2003, 12:27 PM   #11
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
Im still a bit uneasy with letting the pump run dry...Iv'e also heard that the pump will fry after a few seconds without fluid. I put more fluid in there a few days ago to see if the P/S would still work and the pump was loud as hell and didn't assist for the 1st second of turning the wheel...Im thinking that it could also be due to the massive leak in the high pressure line...Its worse than I thought, the fluid just pours out of the line when I start the car. I have not been able to drive it for a few days because Im afraid of burning up the pump..I looked for a fuse or somthing to dismantle it..but I dont think there is a way to.
Old 11-03-2003, 11:04 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Damn it, I just got chased in by the mosquitos while installing a new grill I'm gonna have to put on long pants and a long sleeve tee shirt
Old 11-04-2003, 02:59 AM   #13
Ozymandias
Member#: 44238
1996 Impreza w/2.2t
Yellow
agh! if it would just go back to the 80 that i was last week!
power steering pressure line leak after turbo inlet install StarDogChampion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 05-11-2012 05:31 PM
Power Steering Return Hose Leak lobelsteve Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 01-19-2008 01:46 PM
Power Steering Pump is leaking.... Jutboy Brakes, Steering & Suspension 4 08-31-2007 09:15 AM
Power steering may be leaking... Speedwagon Legacy Forum 1 03-05-2006 01:58 AM
Power steering sprung a leak phooka Brakes, Steering & Suspension 2 12-14-2001 03:02 PM
