Old 07-02-2007, 11:32 AM   #1
cartervt2k
Member#: 43198
02 WRX
Default instrument cluster light bulbs
Does anyone have any info on what size bulbs go in behind the WRX gauge cluster? I called the stealership, and they said I would need to bring the cluster down there and look at exactly which bulb blew out because there are different size bulbs that fit in there. It would be a lot easier if I just knew in advance what the bulb sizes go where, so I wouldn't have to take apart my instrument cluster more than once. My autometer instrument cluster gauge pod makes pulling the piece out a little more of a PITA than it would normally, and I'd like to not have to do it twice.
I've read a bunch of posts saying people tried size 74 and 24 bulbs, but I haven't heard definitively if they work or not. Can anyone confirm? If they do, I suppose I will also need green colored condoms for them to match the rest of the cluster, right? TIA.
cartervt2k is offline   Reply With Quote
Old 07-02-2007, 01:28 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Here is a link to the Sylvania site where you can select your model car and it will show you most of the lights used on the car but it doesn't show the dash lights unfortunately.
http://www.sylvania.com/ConsumerProd...lacementGuide/
Instrument Cluster Replacement Bulbs 2000vfr800 Electrical & Lighting 4 05-06-2008 04:39 PM
03 wrx instrument cluster info bulb sizes wrxmase Electrical & Lighting 2 03-18-2007 07:24 PM
Instrument cluster / lights dim when indicator on doufdouf Electrical & Lighting 0 09-03-2006 01:59 AM
instrument cluster lights will not turn off::PLEASE HELP:: nottheliving Electrical & Lighting 3 03-26-2005 01:23 AM
Using Instrument Cluster Light as Shift Light/Any Ideas? jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-21-2003 09:08 PM
