Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 07-03-2007, 11:42 AM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default Stumbles/Hesitates when under any kind of boost.
Before my transmission went the car ran perfectly. The car stood for 2 months straight. I took the engine out to remove the transmission and did not touch anything on the engine.
I put the engine in now the car runs like complete crap. When under negative vaccuum the car runs perfectly normal no issues. As soon as it sees any kind of boost the AFR is way too lean.
MOD LIST
VF22
SSA TMIC
STI UPPIPE
INVIDIA DP
STOCK CATBACK
STI SHORTBLOCK WITH STI HG
STOCK WRX CAMS AND HEADs
UTEC
DEATSCHWERK 780 INJECTORS
1) I pressure tested the intake system no leaks anywhere (I will be doing this again)
2) Only cel I have is a broken TGV sensor which i HAD before my transmission went.
3) Changed spark plugs
4) Did a warm engine compression test 190 all around
5) Added an extra ground wire from the battery neg to top of the intake.
6) Checked and recheck vaccuum hoses cant find anything that seems out of place.
7) Utec is not reporting any knock
8) ECU wants to run an ungodly amount of timing under boost.
HERE IS A UTEC LOG, IT IS SLOW TO BUILD BOOST AND RPM DROPS IN SOME PLACES.
Code:
[TSMP][RPM][PSIG][MAF][TPS][LOD][KN][SNB][SIG][IDC%][IGN][FMVL][BMV][MMV][WBO2][TAFR]
000.00 3140  +1.7 3.0   36   10   0  W/b  33.7  16.9 30.3  +0.0  22  2.5  12.17 14.0
000.09 3167  +2.3 3.0   46   20   0  W/b  33.0  17.2 26.3  +0.0  22  2.6  12.14 13.5
000.09 3180  +2.7 3.0   59   20   0  W/b  32.5  18.1 22.3  +0.0  22  2.6  12.06 13.5
000.13 3187  +2.9 3.0   73   20   0  W/b  32.3  18.5 21.7  +0.0  21  2.6  12.00 13.5
000.18 3183  +3.7 3.1   86   20   0  W/b  32.4  18.2 21.8  +0.0  21  2.6  11.98 13.5
000.22 3193  +3.9 3.1   95   20   0  W/b  32.4  18.3 21.3  +0.0  20  2.6  11.98 13.5
000.27 3217  +4.3 3.2  100   20   0  W/b  32.3  18.9 20.9  +0.0  20  2.6  11.92 13.5
000.30 3224  +4.5 3.2  100   20   0  W/b  32.4  18.9 20.8  +0.0  20  2.6  11.87 13.5
000.35 3219  +4.9 3.2  100   20   0  W/b  32.3  19.5 20.3  +0.0  19  2.6  11.80 13.5
000.39 3229  +5.1 3.1  100   30   0  W/b  32.2  20.2 19.7  +0.0  19  2.6  11.81 12.5
000.43 3254  +5.3 3.1  100   30   0  W/b  31.9  20.6 19.2  +0.0  19  2.6  11.76 12.5
000.47 3270  +5.7 3.2  100   30   0  W/b  32.0  21.0 18.4  +0.0  18  2.6  11.77 12.5
000.52 3284  +5.9 3.2  100   30   0  W/b  32.0  22.0 18.0  +0.0  18  2.6  11.77 12.5
000.57 3271  +6.2 3.3  100   30   0  W/b  32.1  22.0 17.8  +0.0  17  2.7  11.77 12.5
000.60 3252  +6.2 3.2  100   30   0  W/b  32.2  22.2 17.0  +0.0  17  2.7  11.73 12.5
000.66 3246  +6.6 3.2  100   30   0  W/b  32.1  23.0 16.5  +0.0  17  2.8  11.81 12.5
000.70 3305  +7.0 3.2  100   30   0  W/b  31.6  22.8 16.4  +0.0  17  2.9  11.68 12.5
000.74 3351  +7.4 3.2  100   40   0  W/b  30.6  23.4 16.5  +0.0  17  2.8  11.81 12.0
000.81 3382  +7.6 3.2  100   40   0  W/b  30.7  24.5 16.2  +0.0  13  2.8  11.68 12.0
000.82 3372  +8.4 3.3  100   40   0  W/b  29.2  25.4 15.7  +0.0  12  2.8  11.76 12.0
000.88 3373  +8.6 3.4  100   40   0  W/b  28.9  25.2 15.6  +0.0  12  2.7  11.73 12.0
000.91 3408  +8.8 3.4  100   40   0  W/b  28.9  25.8 15.2  +0.0  11  2.7  11.73 12.0
000.95 3395  +8.8 3.5  100   40   0  W/b  29.0  26.1 15.0  +0.0   6  2.8  11.71 12.0
001.00 3383  +8.8 3.3  100   40   0  W/b  28.5  25.9 15.0  +0.0   6  2.9  11.73 12.0
001.05 3426  +9.2 3.3  100   40   0  W/b  28.3  26.0 15.0  +0.0   6  2.9  11.62 12.0
001.09 3413  +9.4 3.4  100   50   0  W/b  27.8  25.9 15.0  +0.0   6  2.9  11.73 11.5
001.13 3409  +9.8 3.4  100   50   0  W/b  28.2  25.6 15.0  +0.0   6  2.9  11.62 11.5
001.19 3446  +9.8 3.3  100   50   0  W/b  28.4  25.9 15.0  +0.0   6  2.8  11.68 11.5
001.23 3463  +9.8 3.3  100   50   0  W/b  28.1  26.6 14.8  +0.0      2.7  11.67 11.5
001.27 3468  +9.4 3.3  100   50   0  W/b  27.8  26.7 14.8  +0.0      2.9  11.67 11.5
001.30 3459  +9.4 3.3  100   50   0  W/b  27.7  27.0 14.7  +0.0      2.8  11.68 11.5
001.35 3464  +9.4 3.3  100   50   0  W/b  28.2  27.3 14.7  +0.0      2.9  11.68 11.5
001.39 3518  +9.6 3.3  100   50   0  W/b  28.2  27.3 14.8  +0.0      2.9  11.65 11.5
001.44 3524 +10.2 3.4  100   50   0  W/b  27.9  27.5 14.9  +0.0      2.8  11.73 11.5
001.48 3527 +10.0 3.4  100   50   0  W/b  27.8  27.4 14.7  +0.0      2.8  11.73 11.5
001.52 3537  +9.8 3.5  100   50   0  W/b  27.8  27.5 14.8  +0.0      2.8  11.87 11.5
001.58 3541  +9.4 3.5  100   50   0  W/b  28.1  27.3 14.6  +0.0      2.8  11.80 11.5
001.60 3537  +9.6 3.4  100   50   0  W/b  27.8  27.7 14.6  +0.0      2.9  11.80 11.5
001.66 3599  +9.8 3.5  100   50   0  W/b  27.8  27.8 14.8  +0.0      2.9  11.92 11.5
001.70 3622 +10.2 3.5  100   50   0  W/b  27.9  26.8 14.9  +0.0      2.9  11.87 11.5
001.73 3609 +10.4 3.5  100   50   0  W/b  27.5  28.5 14.9  +0.0      2.9  11.98 11.5
001.78 3614 +10.2 3.5  100   50   0  W/b  27.5  27.9 14.7  +0.0      2.8  12.11 11.5
001.83 3615 +10.0 3.5  100   50   0  W/b  27.5  29.3 14.7  +0.0      2.9  12.09 11.5
001.88 3611  +9.8 3.6  100   50   0  W/b  27.5  29.1 14.6  +0.0      2.9  12.11 11.5
001.91 3630 +10.4 3.6  100   50   0  W/b  27.6  28.9 14.8  +0.0      2.9  12.11 11.5
001.95 3652 +10.4 3.6  100   50   0  W/b  27.5  29.6 14.8  +0.0      2.8  12.11 11.5
002.01 3673 +10.2 3.6  100   50   0  W/b  27.6  29.5 14.6  +0.0      2.9  12.33 11.5
002.05 3663  +9.8 3.6  100   50   0  W/b  27.4  28.1 14.5  +0.0      2.9  12.39 11.5
002.09 3690 +10.2 3.5  100   50   0  W/b  28.6  28.7 14.6  +0.0      2.9  12.61 11.5
002.13 3710 +10.6 3.6  100   50   0  W/b  27.8  30.1 14.8  +0.0      2.9  12.52 11.5
002.19 3718 +10.4 3.6  100   50   0  W/b  27.5  28.2 14.6  +0.0      2.8  12.53 11.5
002.23 3718 +10.0 3.5  100   50   0  W/b  27.4  30.1 14.7  +0.0      2.9  12.61 11.5
002.27 3757  +9.8 3.5  100   50   0  W/b  28.1  29.0 14.6  +0.0      2.9  12.64 11.5
002.30 3782 +10.2 3.5  100   50   0  W/b  28.6  29.7 14.7  +0.0      2.8  12.64 11.5
002.36 3756 +10.2 3.5  100   50   0  W/b  28.5  30.6 14.6  +0.0      2.9  12.59 11.5
002.40 3730  +9.8 3.5  100   50   0  W/b  28.1  29.7 14.5  +0.0      2.9  12.53 11.5
002.42 3776  +9.8 3.5  100   50   0  W/b  28.1  29.5 14.7  +0.0      2.9  12.53 11.5
002.48 3811 +10.2 3.5  100   50   0  W/b  28.1  30.1 14.8  +0.0      2.9  12.49 11.5
002.52 3777 +10.0 3.5  100   50   0  W/b  28.2  30.1 14.8  +0.0      2.9  12.49 11.5
002.58 3757  +9.6 3.4  100   50   0  W/b  28.4  28.9 14.7  +0.0      3.0  12.56 11.5
002.61 3810  +9.8 3.4  100   50   0  W/b  28.8  30.5 14.7  +0.0      3.0  12.56 11.5
002.66 3836 +10.4 3.5  100   50   0  W/b  28.2  30.8 14.9  +0.0      2.9  12.56 11.5
002.70 3833 +10.4 3.4  100   50   0  W/b  28.1  29.5 14.8  +0.0      2.8  12.56 11.5
002.73 3817  +9.6 3.4  100   50   0  W/b  28.5  30.9 14.7  +0.0      3.0  12.68 11.5
002.79 3868 +10.0 3.4  100   50   0  W/b  28.5  29.3 14.6  +0.0      2.9  12.74 11.5
002.83 3870 +10.4 3.4  100   50   0  W/b  28.5  29.0 14.9  +0.0      2.8  12.67 11.5
002.88 3865 +10.2 3.4  100   50   0  W/b  28.8  30.3 14.9  +0.0      2.8  12.67 11.5
002.91 3878  +9.6 3.5  100   50   0  W/b  28.8  30.5 14.8  +0.0      2.9  12.67 11.5
002.95 3891 +10.2 3.5  100   50   0  W/b  28.5  30.8 15.0  +0.0      2.9  12.64 11.5
003.01 3889 +10.2 3.5  100   50   0  W/b  28.4  30.3 14.9  +0.0      2.8  12.64 11.5
003.05 3871  +9.8 3.5  100   50   0  W/b  28.8  30.3 14.9  +0.0      2.9  12.67 11.5
003.09 3911  +9.6 3.6  100   50   0  W/b  28.8  30.4 14.7  +0.0      2.9  12.75 11.5
003.13 3950 +10.2 3.5  100   50   0  W/b  28.4  30.4 15.0  +0.0      2.9  12.74 11.5
003.18 3930 +10.2 3.5  100   50   0  W/b  28.4  30.6 14.7  +0.0      2.9  12.86 11.5
003.23 3901  +9.8 3.4  100   50   0  W/b  28.4  30.5 14.8  +0.0      2.9  12.92 11.5
003.27 3920 +10.0 3.4  100   50   0  W/b  28.5  30.2 15.0  +0.0      2.9  13.02 11.5
003.30 3940 +10.4 3.4  100   50   0  W/b  28.8  30.9 15.0  +0.0      2.8  13.23 11.5
003.36 3934  +9.6 3.4  100   50   0  W/b  28.7  31.4 14.9  +0.0      3.0  13.23 11.5
003.40 3956 +10.0 3.4  100   50   0  W/b  28.5  30.3 15.0  +0.0      2.9  13.39 11.5
003.43 3978 +10.2 3.5  100   50   0  W/b  28.8  30.5 15.0  +0.0      2.9  13.53 11.5
003.48 3971 +10.0 3.5  100   50   0  W/b  28.7  32.2 15.0  +0.0      2.9  13.81 11.5
003.53 3981  +9.8 3.6  100   50   0  W/b  28.8  31.5 14.8  +0.0      2.9  14.45 11.5
003.58 3982 +10.4 3.5  100   50   0  W/b  28.7  31.0 15.0  +0.0      2.9  15.58 11.5
003.61 3973  +9.8 3.5  100   50   0  W/b  28.8  30.6 15.1  +0.0      2.9  18.12 11.5
003.66 4019  +9.6 3.4  100   50   0  W/b  28.7  31.9 14.9  +0.0      2.9  21.27 11.5
003.70 4057 +10.2 3.4  100   50   0  W/b  28.8  32.5 15.1  +0.0      2.9  21.27 11.5
003.73 4064 +10.4 3.4  100   50   0  W/b  28.8  32.8 15.0  +0.0      2.9  25.00 11.5
003.78 4042  +9.6 3.5  100   50   0  W/b  28.8  32.0 15.0  +0.0      3.0  25.00 11.5
003.83 4072 +10.2 3.5  100   50   0  W/b  28.8  32.7 15.1  +0.0      2.9  25.00 11.5
003.87 4090 +10.0 3.5   97   50   0  W/b  28.8  33.4 15.1  +0.0      3.0  25.00 11.5
003.91 4041  +9.6 3.5   85   50   0  W/b  28.4  33.2 15.0  +0.0      3.0  25.00 11.5
003.96 4032  +9.6 3.5   65   50   0  W/b  28.7  31.1 15.3  +0.0      2.9  25.00 11.5
003.98 4045  +9.2 3.4   32   50   0  W/b  29.1  28.5 15.6  +0.0      2.7  25.00 11.5
HERE IS A LOG OF THE ENGINE RUNNING NORMALLY THE DAY MY TRANSMISSION BLEW UP 2 MONTHS AGO.
Code:
000.00 3044  -0.8 3.1   89   10   0  W/B  36.3  13.1 31.1  -6.3      2.4  13.02 14.0
000.04 3077  -0.6 3.1  100   10   0  W/B  35.3  12.5 27.1  -6.1      2.4  13.02 14.0
000.09 3070  -0.2 3.1  100   10   0  W/B  35.6  13.3 27.1  -6.8      2.4  12.64 14.0
000.13 3026  +0.4 3.1  100   10   0  W/B  34.7  13.8 26.3  -6.0  99  2.5  12.30 14.0
000.18 3021  +0.8 3.1  100   10   0  W/B  34.1  13.9 25.6  -6.2  99  2.4  11.96 14.0
000.21 3071  +1.1 3.2  100   10   0  W/B  34.0  14.5 25.2  -6.4 WGS  2.5  11.65 14.0
000.26 3091  +1.5 3.2  100   10   0  W/B  33.6  14.9 24.6  -6.2 WGS  2.5  11.42 14.0
000.31 3077  +2.1 3.3  100   10   0  W/B  33.2  15.7 23.9  -4.4 WGS  2.6  11.27 14.0
000.35 3086  +2.5 3.3  100   20   0  W/B  32.5  16.8 23.1  -4.9 WGS  2.6  11.14 13.5
000.39 3128  +3.1 3.3  100   20   0  W/B  32.3  17.3 22.2  -4.9 WGS  2.7  11.14 13.5
000.43 3155  +3.7 3.4  100   20   0  W/B  32.0  19.2 21.1  -5.1 WGS  2.7  11.05 13.5
000.48 3143  +4.3 3.4  100   20   0  W/B  32.1  19.5 20.4  -5.1 WGS  2.7  10.96 13.5
000.53 3150  +4.9 3.4  100   30   0  W/B  30.9  20.6 19.1  -2.8 WGS  2.8  10.90 12.5
000.56 3174  +5.7 3.5  100   30   0  W/B  25.7  22.9 18.2  -2.8 WGS  2.9  10.90 12.5
000.60 3219  +6.6 3.5  100   30   0  W/B  23.4  24.6 17.0  -2.6 WGS  2.9  10.99 12.5
000.65 3224  +7.6 3.6  100   40   0  W/B  21.3  25.7 16.4  -0.4 WGS  3.0  11.06 12.0
000.70 3194  +8.4 3.6  100   40   0  W/B  20.6  30.4 15.4  -1.2 WGS  3.0  11.11 12.0
000.73 3193  +9.2 3.7  100   40   0  W/B  18.3  33.5 14.9  -2.3 WGS  3.0  11.11 12.0
000.82 3258 +10.0 3.8  100   50   0  W/B  17.6  32.9 14.5  -2.3 WGS  3.1  11.14 11.5
000.83 3297 +11.0 3.8  100   50   0  W/B  17.0  33.5 14.1  -2.3 WGS  3.1  11.20 11.5
000.87 3286 +12.3 3.9  100   60   0  W/B  16.3  34.8 13.5  -1.3 WGS  3.1  11.23 11.5
000.91 3291 +13.1 3.9  100   60   0  W/B  15.3  37.4 13.1  -1.1 WGS  3.2  11.24 11.5
000.95 3364 +13.9 3.9  100   70   0  W/B  14.2  39.0 12.8  +1.4 WGS  3.4  11.28 11.4
001.00 3424 +14.9 4.0  100   70   0  W/B  12.4  42.6 12.4  +1.7 WGS  3.3  11.28 11.4
001.03 3432 +16.4 4.1  100   80   0  W/B  +9.7  45.8 11.7  +1.2 WGS  3.4  11.30 11.2
001.08 3452 +17.2 4.1  100   80   0  W/B  +9.5  45.0 11.4  +0.2  97  3.4  11.30 11.2
001.13 3497 +18.0 4.0  100   80   0  W/B  +9.1  48.4 11.2  +1.1  97  3.4  11.37 11.2
001.18 3528 +18.2 4.1  100   80   0  W/B  +9.0  47.0 11.0  +1.1  96  3.4  11.37 11.2
001.21 3507 +18.8 4.1  100   80   0  W/B  +8.7  48.9 11.0  +0.2  96  3.3  11.37 11.2
001.26 3539 +19.0 4.1  100   90   0  W/B  +9.0  49.6 11.4  +0.1  96  3.4  11.18 11.1
001.31 3591 +19.2 4.1  100   90   0  W/B  +9.0  49.1 11.5  -0.2  96  3.4  10.96 11.1
001.35 3613 +19.6 4.2  100   90   0  W/B  +9.1  50.6 11.3  +0.1  95  3.4  10.96 11.1
001.39 3630 +19.8 4.2  100   90   0  W/B  +9.1  48.9 11.6  -0.1  95  3.4  10.96 11.1
001.43 3647 +20.0 4.2  100   90   0  W/B  +8.9  49.3 11.7  -0.3  95  3.5  10.96 11.1
001.51 3660 +20.0 4.2  100   90   0  W/B  +9.7  49.8 11.9  -2.1  95  3.4  10.96 11.1
001.53 3708 +20.2 4.2  100   90   0  W/B  +9.7  48.9 11.7  -0.3  95  3.4  11.06 11.1
001.55 3725 +20.2 4.2  100   90   0  W/B  +9.7  49.7 12.0  -2.1  95  3.4  11.49 11.1
001.60 3735 +20.2 4.2  100   90   0  W/B  +9.7  51.5 12.2  -0.7  96  3.4  12.25 11.1
001.65 3792 +20.2 4.2  100   90   0  W/B  10.8  51.4 12.1  -2.1  96  3.5  13.45 11.1
001.70 3820 +20.2 4.2  100   90   0  W/B  10.5  51.0 12.5  -0.9  96  3.4  15.37 11.1
001.73 3858 +20.2 4.2  100   90   0  W/B  10.9  48.8 12.5  -1.7  96  3.4  19.05 11.1
001.78 3903 +20.2 4.2  100   90   0  W/B  12.9  53.6 13.2  -1.5  96  3.4  19.05 11.1
001.83 3906 +20.0 4.3   99   90   0  W/B  12.6  49.0 12.4  -1.7  97  3.5  24.47 11.1
001.86 3952 +20.2 4.3   99   90   0  W/B  13.0  51.4 12.8  -2.1  97  3.4  25.00 11.1
001.91 3996 +20.2 4.3   99   90   0  W/B  13.6  51.8 13.1  -1.7  97  3.4  25.00 11.1
001.95 4060 +20.0 4.2   99   90   0  W/B  14.0  51.8 12.8  -2.2  98  3.4  25.00 11.1
001.99 4062 +20.0 4.2   97   90   0  W/B  13.7  52.5 13.1  -2.3  97  3.5  25.00 11.1
002.03 4044 +20.0 4.3   91   90   0  W/B  13.9  52.5 13.3  -1.9  84  3.4  25.00 11.1
002.10 4058 +19.6 4.3   64   90   0  W/B  13.8  51.3 13.2  -2.3  65  3.4  25.00 11.1
NITROS is offline   Reply With Quote
Old 07-07-2007, 10:43 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
bump! Ever figure this out..
I was analizing the logs when you first posted them, and I wanted to reply but all i could figure out was what you already said about them.
What did you do?
Paul
PaulRex is offline   Reply With Quote
Old 07-09-2007, 01:50 AM   #3
NITROS
Member#: 41561
04 GT3076 2.1
No, still digging around I think it might be a faulty TPS but i wont know until next week when i get back into down.
Old 08-16-2007, 11:52 AM   #4
NITROS
Member#: 41561
04 GT3076 2.1
TGV sensor was installed improperly. It was keeping the TGVs to always be closed.
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 11:24 PM
('93-'01) Hesitation when accelerating ...any help ? walt mazar Impreza Forum 11 08-18-2005 10:32 PM
Brakes: Any kind of shield to deflect stones/debris? Siper2 Brakes, Steering & Suspension 2 09-30-2001 12:05 AM
What kind of boost controller for WRX's? dannyboy7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-19-2001 08:06 PM
