Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 12-29-2001, 04:25 PM   #1
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Default Wind Noise at Normal Speeds in WRX
I know people have posted about noise at really high speeds but I think this is different-
I am getting a whistling-type wind noise that can be heard at lower speeds, even around 30MPH, as well as when going faster. It doesn't seem to change much with speed either except maybe to get somewhat louder. I don't think it's window seals because I can crack any of the windows open and still hear it. As far as localizing it until I can get someone to ride with me to listen my best guess is maybe right-front but it's hard to tell for sure.
This also seems to get more noticeable as the outside temp gets colder.
Wondering if anyone else has experienced this and found the cause.
Old 12-29-2001, 05:16 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Common problem I'm afraid... it's the wind whistling between the crack in the passenger side mirror housing. Because they are able to fold back so they don't get broken off in tight parking spots, the wind can get in between the base part attached to the door and the dome that holds the mirror itself. Some people have had luck with seperating the base and the mirror housing and putting something like felt in there to block the wind. I find it's easier to just turn up the radio .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 12-29-2001, 06:41 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, thanks. I'll have to try putting something in there and seeing if it helps.
I can only turn up the radio so much, I have the stock head unit (for now).
Old 12-30-2001, 10:15 AM   #4
travmn
Member#: 10964
06 ForesterXT
'02 Triumph S3
question is then, are there aftermarket mirrors that look good, lower profile, and are "fixed" position to eliminate that noise? that should eliminate some noise, but at higher speeds, you'll still get a fair amount of noise from the hood scoop and also since the front isn't very aerodynamic ( can't remember the Cd though ).
travmn is offline   Reply With Quote
Werid Wind noise at high speed RHSTi Vancouver Impreza Club Forum -- VIC 21 08-12-2007 03:29 PM
Werid Wind noise at high speed RHSTi Interior & Exterior Modification 9 08-11-2007 03:27 PM
Strange noise at high speed in '06 STI scrawshaw Tire & Wheel 1 12-24-2006 01:13 PM
Wind Noise at freeway speed. SubyWRXSti Warranty Issues & SOA Problems 9 09-10-2006 01:42 PM
Noise at high speed Disruptor Newbies & FAQs 24 01-13-2002 11:21 PM
