Old 12-29-2001, 05:24 PM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default Alert! power steering hose fitings are loose on some WRX's - - fluid leaks all over
I just had my power steering system make a fluid trail all over town !
Was getting some tunning help from the nice guys at Imported Cars of Stamford - - they were kind enough to share some tunning insight on ignition advance as I tune my stand alone
Was running up and down the road with them working the lap top and after a 90 mph run there is lots of smoke and noise
BIG puddle of fluid
The guy told me that Subaru had put out a service advisory on the lines going into the power steering rack being loose on some wrx's
Sure enough the couplings had loosened right up
I am posting this becuase had this happened around a corner I could have eaisily slide off the road
PLEASE check your power steering lines near the pass half shaft
Thansk to Imported Cars of Stamford!
alfriedesq is offline   Reply With Quote
Old 12-29-2001, 05:46 PM   #2
gossamer_monster
Member#: 3574
Blase' Yellow----R.I.P.
Thanks Al, I`lll have to check mine.
Bill
gossamer_monster is offline   Reply With Quote
Old 12-29-2001, 06:05 PM   #3
Fubaru
Member#: 6046
'08 Prius
I can't believe SoA hasn't issued some kind of recall or service notice for this if true. Even if it only affects 1 out of 1000 imprezas.
Fubaru is offline   Reply With Quote
Old 12-29-2001, 06:08 PM   #4
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
half shaft? Got a pic where we should look?
Geek Guy is offline   Reply With Quote
Old 12-29-2001, 06:20 PM   #5
Fubaru
Member#: 6046
'08 Prius
Glenn wallace posted pics where to tighten up in this thread:
http://www.i-club.com/forums/showthr...hreadid=127530
Old 12-29-2001, 06:56 PM   #6
Geek Guy
Member#: 8151
2002 WRX Rally Car
Thanks chief
Old 12-29-2001, 07:50 PM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
I wonder it its a design flaw - or if the idiot who works this part of the line is drinking too much saki???
Either way - if this sucker lets loose around a curve - its going to be very slippery !
I recommend checking all the fittings - - - the ones which were loose on mine where right over the pass side inner half shaft end
Very hard to reach - but you can tighten it up if you take your time
I just can't believe that Mr. Wallace had the same problem - this really sucks
Old 12-29-2001, 08:05 PM   #8
JER
Member#: 4472
I had the same thing happen to me. I just tightend it back up a refilled the fluid no problems since.
JER is offline   Reply With Quote
Old 12-29-2001, 08:30 PM   #9
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Its just amazing that there are so many with this problem
Old 12-29-2001, 10:32 PM   #10
Geek Guy
Member#: 8151
2002 WRX Rally Car
Hey SOA! Do a recall! I'm curious if my.subaru.com is actually going to notify me that I have to take my car in!
In all seriousness though, I think losing power steering is kinda dangerous, esp. considering how you market the car. It's not like you've got commercials with the car at the drag strip!
Old 12-30-2001, 01:09 AM   #11
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
My main concern is when the oil blows out and it gets on the pass side tires - - it will cause accidents
Old 12-30-2001, 01:34 AM   #12
tcarter
Member#: 12366
I'll have to check on mine now.. Ugh... :monkey:
tcarter is offline   Reply With Quote
Old 12-30-2001, 01:43 AM   #13
mWRX
Member#: 8854
2007 B9 Tribeca
Smoke Grey
Unhappy me too
I had this problem too. Noticed a lot of smoke and a clear oily fluid was leaking all over my exhaust and uppipe. Tightened them up and have had no more problems since then.
mWRX is offline   Reply With Quote
Old 12-30-2001, 01:54 AM   #14
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Plus now there is an oil trail all over stamford leading right to my driveway !
Old 12-30-2001, 04:15 AM   #15
Akiata
Member#: 297
Yup, happened to me too.
But on mine it was a fitting just under the turbo.
Don't forget to check that one.
Akiata is offline   Reply With Quote
Old 12-30-2001, 04:19 AM   #16
boostaholic
Member#: 7224
2002 WR Blue WRX
13's with just a MBC
Don't worry Al I've left many trails of transmission fluid from my GN leading up my drive way and into my garage...
boostaholic is offline   Reply With Quote
Old 12-30-2001, 09:47 AM   #17
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Yeah, I had the same problem and started a thread in Waranty & SOA issues. Do a search!
http://www.i-club.com/forums/showthr...referrerid=185
I think it's time for a recall!
Leo
Leonardo is offline   Reply With Quote
Old 12-30-2001, 11:42 AM   #18
tcarter
Member#: 12366
I agree...
Old 12-30-2001, 02:24 PM   #19
wrxracer
Member#: 5275
2002 impreza WRX
WR BLUE
Lightbulb pwr steering.........
i have had this done to my WRX. noticed that one day fluid was low, you could hear the whining from the steering. filled it up drove it to the dealership, and bam yes there is a notice out that the o-rings have been leaking around one of the hoses. they replaced the o-ring re-installed the hose and been good ever since, its been over 2000mile and no more probs, i just keep an eye out more ofter now....
wrxracer is offline   Reply With Quote
inlet hose & power steering hose??? warui111 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-26-2006 02:36 AM
Changing WRX clutch and power steering hose question Ken-gv Service & Maintenance 1 07-29-2003 03:04 AM
Anyone KNow the specs on braided power steering hose? cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-02-2003 11:03 PM
"Aftermarket power steering hose swelling not proper hose for fluid" SEXY GC8 Service & Maintenance 2 08-30-2002 04:26 PM
