Alaskan Impreza Club
Old 07-04-2007, 12:13 AM   #1
redl1newrx
Member#: 121977
2009 Impreza2.5i
Default helicial vs mechanical LSD
whats the differences???
redl1newrx is offline   Reply With Quote
Old 07-04-2007, 12:17 AM   #2
Firestrike
Member#: 135785
2006 Impreza WRX LTD
Cloaking Device Gray
Firestrike is offline   Reply With Quote
Old 07-04-2007, 12:25 AM   #3
redl1newrx
Member#: 121977
2009 Impreza2.5i
Originally Posted by Firestrike View Post
explain in english please...
Old 07-04-2007, 12:38 AM   #4
Firestrike
Member#: 135785
Well John, from what I read here:
The use of the word mechanical implies that the limited slip differential is engaged by interaction between two (or more) mechanical parts. This category includes clutch and helical limited slip differentials. For road racing, many prefer a helical limited slip differential, because it does not lock the two output shafts to spin at the same rate, but rather biases torque to the wheel with more grip by up to 80%
Helical and mechanical are part of the same type.
Old 07-04-2007, 12:39 AM   #5
Firestrike
Member#: 135785
If you are looking for a diff that is different, it would be this:
Viscous
The viscous type is generally simpler, and relies on the properties of a dilatant fluid - that is, one which thickens when subject to shear. Silicone-based oils are often used. Here, a cylindrical chamber of fluid filled with a stack of perforated discs rotates with the normal motion of the output shafts. The inside surface of the chamber is coupled to one of the driveshafts, and the outside coupled to the differential carrier. Half of the discs are connected to the inner, the other half to the outer, they alternate inner/outer in the stack. Differential motion forces the interlocked (though untouching) discs to move through the fluid against each other.
Old 07-04-2007, 12:40 AM   #6
RawCode
Member#: 3115
2002 Impreza 2.5RS
IIRC helical is a mechanical differential.
edit: I am too slow!
Maybe he is better off reading this: http://auto.howstuffworks.com/differential.htm
RawCode is offline   Reply With Quote
Old 07-04-2007, 12:43 AM   #7
Firestrike
Member#: 135785
Wow! What a find!
Old 07-04-2007, 12:44 AM   #8
RawCode
Member#: 3115
2002 Impreza 2.5RS
here is a thread in the driveline forum FAQ too: http://forums.nasioc.com/forums/showthread.php?t=423584
Old 07-04-2007, 12:52 AM   #9
soldmyboxster
Member#: 65520
'11 M3 Coupe
I recall reading in SCC a long time ago that the fluid in a viscous differential could also be described as thixotropic. I believe it's a synonym for dilatant.
No, I'm not going to bother looking it up.
As for which is better, I've driven a Quaife ATB diff (all gears, no clutches) and a Honda OEM clutch-type diff in very similar cars (1988 CRXs) and I strongly prefer the clutch-type. The Quaife caused serious understeer under throttle. The clutch type was a little more forgiving.
soldmyboxster is offline   Reply With Quote
Old 07-04-2007, 12:55 AM   #10
RawCode
Member#: 3115
2002 Impreza 2.5RS
Old 07-04-2007, 01:01 AM   #11
Firestrike
Member#: 135785
Haha John. Any more questions?
I say this will teach you what you need to know.
And how to use the search function maybe? lol
Old 07-08-2007, 12:41 AM   #12
shortfuseWRX
Member#: 38573
1997 toyota tacoma
Black death
do a spool john!!!!
sam
shortfuseWRX is offline   Reply With Quote
Old 07-08-2007, 01:04 AM   #13
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
Don't even start
EvolvedAK is offline   Reply With Quote
Sti Lsd Vs Kaaz Lsd nicolas316 Transmission (AT/MT) & Driveline 6 03-12-2008 04:39 AM
IS JDM WRX Version 2 RA non-sti Mechanical LSD or Viscous? JDM_Scobaru Factory 2.0L Turbo Powertrain 1 02-22-2006 02:25 AM
STI -> Mechanical LSD oil for differentials? 02WRX_BLUE Transmission (AT/MT) & Driveline 2 04-05-2005 10:14 AM
rear diff fluid for Mechanical LSD? jeffg Transmission (AT/MT) & Driveline 4 05-16-2003 09:11 AM
2001 LSD vs 2000 LSD Spectre23 Normally Aspirated Powertrain 11 01-17-2001 02:19 AM
Message Board Statistics All times are GMT -4. The time now is 10:54 PM.
