Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 07-04-2007, 04:11 PM   #1
mogrl840
Member#: 85298
Keep talkin **** you
are makin me famous
Default what do you think of this map?
this is for a 2004 sti. stage 2 ebcs. what do you think of the boost and waste gate duty? i could not get everything to line up, but if you know what you are looking at then you should be able to understand it.
boost
[Table3D]
0 10 20 30 50 60 70 80
1800 -6.96 -4.64 -1.93 -1.16 3.00 4.00 4.00 4.00
2000 -6.96 -5.12 -1.16 -0.58 6.01 7.00 6.09 8.10
2200 -6.96 -5.90 -0.19 -0.19 8.01 10.00 10.09 13.09
2400 -6.96 -6.57 1.35 9.01 10.00 11.00 13.09 15.10
2600 -6.96 -6.96 2.32 9.01 10.00 13.01 16.09 16.57
3200 -13.63 -7.54 3.67 9.30 13.01 16.51 17.60 19.51
3600 -13.63 -8.89 3.67 9.30 13.01 16.51 17.60 19.51
4000 -13.63 -8.89 -3.87 9.30 13.01 16.51 17.60 19.51
5200 -13.63 -8.89 -3.87 9.30 13.01 16.51 17.60 18.51
6000 -13.63 -8.89 -3.96 9.30 13.01 16.51 16.09 17.00
6400 -13.63 -8.89 -3.96 9.30 13.01 16.01 15.10 15.99
6800 -13.63 -8.89 -3.96 9.30 13.01 15.51 14.60 15.01
waste gate
[Table3D]
0 0.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0
1800 0.0 10.0 10.0 15.0 20.0 25.0 45.0 56.0
2000 0.0 10.0 10.0 20.0 25.0 30.0 55.0 66.0
2200 0.0 10.0 10.0 20.0 30.0 35.0 60.0 71.0
2400 0.0 10.0 10.0 20.0 38.0 42.0 59.0 71.0
2600 0.0 15.0 15.0 25.0 40.0 46.0 59.0 67.0
3200 0.0 16.0 16.0 28.0 50.0 50.0 58.0 67.0
3600 0.0 16.0 16.0 28.0 50.0 50.0 58.0 67.0
4800 0.0 16.0 16.0 26.0 42.0 46.0 59.0 67.0
5200 0.0 16.0 16.0 26.0 40.0 46.0 61.0 72.0
5600 0.0 16.0 16.0 26.0 40.0 46.0 63.0 75.0
6800 0.0 16.0 16.0 26.0 40.0 46.0 65.0 76.0
max waste gate
[Table3D]
0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
2000 0.0 19.0 19.0 23.0 33.0 38.0 63.0 73.0
2200 0.0 19.0 19.0 27.0 37.0 42.0 68.0 76.0
2400 0.0 19.0 19.0 27.0 54.0 54.0 70.0 78.0
3200 0.0 23.0 23.0 36.0 60.0 60.0 72.0 80.0
3600 0.0 23.0 23.0 36.0 60.0 60.0 74.0 82.0
5600 0.0 23.0 23.0 35.0 57.0 57.0 74.0 81.0
6400 0.0 23.0 23.0 35.0 51.0 51.0 73.0 80.0
mogrl840 is offline   Reply With Quote
Old 07-04-2007, 04:36 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the differences between waste & max waste
is suppose to be about 10%. just your max waste
10% more than your waste gate map.
Old 07-04-2007, 04:53 PM   #3
mogrl840
Member#: 85298
are makin me famous
alright thank you very much.
Old 07-04-2007, 04:56 PM   #4
mogrl840
Member#: 85298
are makin me famous
I got my cable the other day. I was currently tuned and when I read the map the tuner put in, some things he changed did not look right or make sense. Are you suppose to change the avcs?
Old 07-05-2007, 10:50 AM   #5
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
What ebcs are you running?
06rexwagon is offline   Reply With Quote
Old 07-05-2007, 12:33 PM   #6
mogrl840
Member#: 85298
are makin me famous
Perrin
Old 07-05-2007, 05:42 PM   #7
06rexwagon
Member#: 114730
9.8@150
In that case your max and initial wgdc tables should be 4-5% different, not 8-10 like a stock bcs.
Old 07-05-2007, 06:01 PM   #8
mogrl840
Member#: 85298
are makin me famous
the max should be more right? should I leave my max and raise the initial or should I lower the max and leave the initial? I understand that there should be a 4-5 % difference but which one should I mess with?
Old 07-05-2007, 06:26 PM   #9
06rexwagon
Member#: 114730
9.8@150
If you're not hitting your targets, adjust max and make the min 4-5% lower than the max.
Old 07-07-2007, 12:57 AM   #10
mogrl840
Member#: 85298
are makin me famous
I loaded one of the maps I found and reviewed in my STi. Car felt great, I could use some better gas but I work with what I got. I wont post the map up till I am done making changes on it but here is what numbers I am seeing. There is room for improvement. I can't figure out how to save my log yet but I am working on it. I think it is my lop top though.
Air/fuel= Mim 11.14 Current 14.79 Max 20.33
AIM= min 1 current 1 max 1
Timing= min -12 current 22.50 max 46
Intake air temp= min 106 current 142 max 151
Boost= min -12.77 current -7.98 max 19.15
Mass air flow= min 2.20 current 2.20 max 282.79
Primary waste gate= min .00 max 81.57
KC= min -.50 max 5.50
What do you think of this 2.5in exhaust system (on a 98 impreza L) Would you buy it?? lotus2843 Normally Aspirated Powertrain 20 08-13-2005 04:45 PM
I know this is 99% new school, but what do you think of this? old school North West Impreza Club Forum -- NWIC 4 09-15-2004 10:35 PM
What Do You Think of the MAP R200?? Rallycarperson Off-Topic 3 08-30-2004 04:30 PM
What do you think of this driving light conversion? nicd Interior & Exterior Modification 1 05-15-2001 11:23 AM
What do you think of this?!? Primm Motorsports Motorsports 25 04-22-2001 12:40 AM
