Old 07-05-2007, 11:49 PM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default 04 STI - Perrin Gt35 Kit - Ap2 Pro Tune
Although the perrin kit does not utilize the most up to date GT35R based back housing it is very well made and I have found that the Perrin equiped cars run very smooth and drive almost stock like. Its a well enginered kit and the driveabiolity is great.
This car had the Perrin gt35 turbo kit - fmic and pipes and down pipe
The customer used a UR cold air intake kit to get the cool air
This dyno sheet represents max flow on the maf from the UR intake and just over 20 psi of boost. This is a safe and conservative pump gas set up.
If the customer wants a race map or to add alchy a larget "Big MAF" would be needed to give the ecu more headroom on the air flow sensor.
All together it was a very enjoyable and well running machine.
AP2 - continues to get better and better with each revision
Dyno Flash is offline   Reply With Quote
Old 07-06-2007, 12:37 AM   #2
Skully
Member#: 48990
98 Impreza RS
RBP
Looks like good numbers AL.. Keep up the good work.
-Thomas
Skully is offline   Reply With Quote
Old 07-06-2007, 01:11 AM   #3
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
kind of laggy... does it drop out of boost when he shifts?
All4bSpinnin is offline   Reply With Quote
Old 07-06-2007, 01:34 AM   #4
WolfInSheepsCLothing
Member#: 61197
2004 WRX
vf39 + goodies...
i'm surprised he didn't want a race gas map, missing a great opportunity...
you posted this on the 4th why does the date on the graph say the 6th?
WolfInSheepsCLothing is offline   Reply With Quote
Old 07-06-2007, 01:34 AM   #5
CatfaceType-R
Member#: 81102
^^^ehh..for that amount of power...from 4000 rpm to redline, that isn't to bad at all. Especially on pump
CatfaceType-R is online now   Reply With Quote
Old 07-06-2007, 02:41 AM   #6
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
strange yesterday was the 5th?
THE-95-STi is offline   Reply With Quote
Old 07-06-2007, 03:30 AM   #7
scooter29
Member#: 110418
2006 Sti
white
he couldnt do a race gas map until he gets a bigger MAF. the UR maf is not a "big MAF."
scooter29 is offline   Reply With Quote
Old 07-06-2007, 12:07 PM   #8
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Strange eh ?
yes - he would need a big maf and a alchy kit to go for 500 whp on pump gas !
I love Gt35's on STI's
Al
Old 07-06-2007, 01:01 PM   #9
03clipsegts
Member#: 117692
2004 30R STI
Great numbers I wish I would have gotten the 35r instead of the 30r.
03clipsegts is offline   Reply With Quote
Old 07-06-2007, 01:26 PM   #10
Redline927
Member#: 77622
Al, do you not use the same Protuner software for both Accessports v.1 and v.2? Or did Cobb come out with different software for ap v2?
Redline927 is offline   Reply With Quote
Old 07-06-2007, 04:10 PM   #11
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
At this time the tuning application is the same - however they keep adding more features recently
e.g.
Ability to tune to much higher boost levels with a external map sensor
Launch control
Etc.
Cobb is a first rate companies and they are continually opn top of the game with updates and world class tech support
Old 07-06-2007, 04:11 PM   #12
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Seriously - IMHO the Gt30 is a waste product in this application
This actual car had the Gt30 when I first was tuning it 3 weeks ago and the results sucked so bad I suggested the customer simply plug in a GT35 which is what he did
The gt30 spools up only marginally faster but has at least 50 whp less min
Al
Old 07-06-2007, 06:39 PM   #13
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Huh? GT30R Perrin kits make 400 to 410whp on the dyno dynamics dyno all the time. They also do that with a much wider power band. On C16 I have had them up to 480whp. I think for pump gas the 30R gets the nod. On Race gas the 35R is king. Nice tune Al.
http://forums.nasioc.com/forums/show...ht=Clark+GT30R
CLark
AZScoobie is offline   Reply With Quote
Old 07-06-2007, 08:07 PM   #14
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
CLark
I disagree - I would not waste my time with a Gt30 - the Gt35 is my turbo of choice on a 2.5 L
It is silly to compare individual cars with various mods - the only way to reach a meaningful comparision is on the same car - same dyno - same boost - samt tuning style etc
Al
Old 07-07-2007, 03:23 AM   #15
STimo
Member#: 110273
450 whp 30R STI
[email protected]
^That's true, but when you've tuned probably thousands of subarus liek clark has using both GT30R's and GT35R's on the 2.5L you dont need a dyno to compare them. I'm sure he knows, as you do, that a 30R will make within 20hp of a gt35r on pump gas usually but have a much nicer powerband, IMO that would make it superior using pump gas. Race gas obviously the extra lag you have with the 35r is worth the 80+hp you will get..
STimo is offline   Reply With Quote
Old 07-07-2007, 10:12 AM   #16
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Al
I agree with the sentiment here. But I will also mention to both of you that there is no way to compare the drivers/owners of the cars. Both turbos offer certain pros and cons compared to each other, no matter how slight or how dramatic, that some people want or simply can't live with. To each their own in this case as having choices is a win/win situation for us Subie owners.
offset
offset is offline   Reply With Quote
Old 07-07-2007, 03:09 PM   #17
flycaster
Member#: 60142
2011 WRX
Grey
Well put.
flycaster is offline   Reply With Quote
Old 07-07-2007, 03:41 PM   #18
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
offset
My point is that for those customers inclined to get a GT30 - a FP green will spool up faster and make almost just abou the same power (espscially with a ewg)
On a 2.5 L the Gt35 makes a lot more sense to me - expecially if you intend to run meth injection or a secondary race map
Al
Old 07-07-2007, 07:20 PM   #19
GBX
Member#: 132764
07 STI Ltd
UGM
Al
any disadvantages to running a ewg on the green on newer STI's?
GBX is offline   Reply With Quote
Old 07-07-2007, 09:51 PM   #20
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Cost. That's it IMO.
offset
Old 07-08-2007, 03:06 AM   #21
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
Al
Yeah I must say the 35r is Nice, I just got dyno tuned today and made 480whp on C16 27psi On a Mustang Dyno. My only problem is that it falls out of boost on the Road.. Oh and take in mind that IN Arizona Today it was 116 Degrees Outside today
And my buddy with his 30R who made 465whp with 110 and 50/50 meth water injection pulls me all over the freeway, because with my 35R, I fall out of boost Between Gears. So i am thinking about a Twin scroll 35R or a LArge 30R
STi_Guy04 is offline   Reply With Quote
Old 07-08-2007, 06:07 AM   #22
STimo
Member#: 110273
450 whp 30R STI
[email protected]
^Id go get that 35R retuned cuz the freeway above ~95mph is where you should really start pulling wth that 35R.. Id keep the 35R if i were you unless you plan on running pump gas all the time, which in your case and tune now i doubt..
Old 07-08-2007, 06:49 AM   #23
stu
Member#: 25768
35R bugeye
Slowbaru
but there is somthing to be said for 9.0 compression and a 30r on meth and 110. believe me very fast spool and great top end will get you places. i will post plots a vids tomorrow. It might just change a few minds on nasioc. I will never go bigger and love the quick respnse of the 30R
stu is offline   Reply With Quote
Old 07-09-2007, 03:28 AM   #24
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
I believe cars running such large turbos like 35r and such, would really benefit from higher compression and Serious head-work, with the right selection of parts i think both turbos could be equally as fun on the street, its just how much money do you wana spend?
I`ll probably be looking into pulling the motor and going to a new compression ratio, hey Stu, see if you can get a overlay of our race-gas tunes, I think my plots are still on the Pc at the shop though
Old 07-09-2007, 07:01 AM   #25
Speed
Member#: 67371
05 BUILT 2.4L STI
35R on a built engine (cosworth heads) this is on 93 octane...
Speed is offline   Reply With Quote
BNIB Perrin gt35 kit!!! Silvers Engine/Power/Exhaust 11 09-03-2008 07:44 PM
'07 STI Stage II + with AP2 Pro Tune Dyno Flash Proven Power Bragging 10 07-25-2007 11:08 AM
'07 STI - 93 octane Stage II AP2 Pro Tune Dyno Flash Proven Power Bragging 34 03-27-2007 10:29 PM
PERRIN GT35 Kit by APT alcrudojr #00 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 01-22-2006 09:57 AM
perrin gt35 kit Another Bad Kreation Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 01-19-2006 12:19 AM
