Old 07-06-2007, 06:18 PM   #1
dkan
Member#: 123373
2005 wrb 05 wrx 18g
Default who does ecu tuning
what companies/people tune your vehicle via tactrix cable / ecuflash etc and will send you the maps vehicle specific?
dkan is offline   Reply With Quote
Old 07-08-2007, 09:14 PM   #2
vwsti05
Member#: 144399
2005 WRX STi stage 2
white Romraider tuned
you can go to xpttuning.com or try plasmatize.com the guys there are real helpful and there prices are great!! hope this helps
vwsti05 is offline   Reply With Quote
Old 07-09-2007, 03:38 PM   #3
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
blkscooby is offline   Reply With Quote
Old 07-17-2007, 08:31 PM   #4
wuuusaa
Member#: 92894
2015 Wrx
subscribed
Old 07-17-2007, 08:55 PM   #5
mogrl840
Member#: 85298
Keep talkin **** you
are makin me famous
A+
QUOTE=vwsti05;18648949]you can go to xpttuning.com or try plasmatize.com the guys there are real helpful and there prices are great!! hope this helps[/quote]
mogrl840 is offline   Reply With Quote
Old 07-17-2007, 11:08 PM   #6
wuuusaa
Member#: 92894
2015 Wrx
also try Master2192, and 06rexwagon those guys are awesome and a wealth of knowledge
Old 07-18-2007, 12:09 AM   #7
mogrl840
Member#: 85298
are makin me famous
I have talked to 06rexwagon he seems really cool and knows what he is doing.
Old 07-18-2007, 11:30 PM   #8
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
I'm here to help.
06rexwagon is offline   Reply With Quote
Old 07-19-2007, 08:54 AM   #9
RedRicer
Member#: 128810
05 STI
CGM
Default Do you prefer PM or forum posts?
Originally Posted by 06rexwagon View Post
I'm here to help.
I have a car that is finally going to have all the parts on it but I have fallen out with the installer/tuner and have few other options locally. After reviewing the enginuity.org and the openecu.org I feel i am more than up to changing the maps and going through the tuning process but I want a Semi Custom base map to start with and a helping hand as I tune.
RedRicer is offline   Reply With Quote
Old 07-19-2007, 09:16 AM   #10
06rexwagon
Member#: 114730
[email protected]
PM is best. I can get you a base map that will get you started. Pm me your complete mod list.
Old 07-19-2007, 12:42 PM   #11
blkscooby
Member#: 44422
2009 G8 GT
Not to be competitive with 06rexwagon, but I provide base maps as well. I am working with Dkan at the moment.
Old 07-19-2007, 04:45 PM   #12
06rexwagon
Member#: 114730
[email protected]
No problem. There are plenty of guys who know what they're doing. I have more than I can get done with cars locally at the moment anyway. Thanks to everyone who as offered to help the OP.
Old 07-19-2007, 04:48 PM   #13
wuuusaa
Member#: 92894
2015 Wrx
i spoke to both of you guys and both of you seemed very knowledgeable, i high recommend either one
Old 07-19-2007, 04:53 PM   #14
06rexwagon
Member#: 114730
[email protected]
Check out what I did on my lunch break. This an an RS with a GC swap. The lower of the two pulls was on a map that an un named shop in Cali did for him. I didn't touch the boost and actually went richer (11.1vs 11.3) on the a/f.
Oh and it was 95F on 91 octane.
Old 07-23-2007, 02:32 AM   #15
Hefe_sti_Pma
Member#: 89039
2005 Wrx Sti White
Gadiel Tuning
what are your mods?
Hefe_sti_Pma is offline   Reply With Quote
Old 07-23-2007, 03:03 AM   #16
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
so it made more power at 11.1 because you were able to run more timing? I am just curious to see how u made more power without touching boost, thats a huge increase in power from not touching the boost!
VideoGameWrx is offline   Reply With Quote
Old 07-23-2007, 09:01 AM   #17
blkscooby
Member#: 44422
2009 G8 GT
Unless that engine has AVCS (which I doubt), then it was most likely through timing.
Old 07-23-2007, 09:16 AM   #18
06rexwagon
Member#: 114730
[email protected]
No AVCS on that motor. The previous tune was just THAT bad. The timing and fueling tables were only scaled to 6800 rpm on a car that redlines at 8200. There were some really flat areas in the timing table as well. And yes, by adding some fuel I was able to add timing but I got within 3hp of the final run above at the old 11.3 a/f with timing alone. Once I found the edge of where timing would be accepted by the car I added fuel and the car never pulled a single degree.
Old 07-23-2007, 01:47 PM   #19
mogrl840
Member#: 85298
are makin me famous
sounds like someone knows what they are doing. ^
Old 07-23-2007, 01:49 PM   #20
06rexwagon
Member#: 114730
[email protected]
Thanks.
Old 07-23-2007, 06:15 PM   #21
mogrl840
Member#: 85298
are makin me famous
you are the first person on here that I have seen say good things about tuning. Like you know what you are talking about and are trying to help. The other people SOUND like they know what they are doing but are so cocky about it you don't trust them. You are one of the true friendly tuners.
Old 07-23-2007, 07:35 PM   #22
06rexwagon
Member#: 114730
[email protected]
I think there are a lot of knowledgeable people here and I've learned a lot on the forums. That being said, the people you are talking about are exactly the reason I started tuning.
Old 07-23-2007, 09:08 PM   #23
mogrl840
Member#: 85298
are makin me famous
yes there are some good tuners on these forums. They are hard to come by these days though. Everyone wants money and that's what it seems to take to get some of them to help. That's why I call you the friendly tuner.
Old 07-23-2007, 10:55 PM   #24
blkscooby
Member#: 44422
2009 G8 GT
Same here. Plus I could never afford to buy mods and pay for dyno time. So I learned..
Old 07-24-2007, 12:49 AM   #25
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Nice work! I have found that these engines seem to be more sensitive to timing than AFR. Especially on pump fuels, I tried leaning out to 11.2 on the local 92 octane but found I could make more power at 10.8.
Who does your tuning? 03' Scooby Texas Impreza Club Forum -- TXIC 11 08-01-2007 06:03 PM
Okay, who does scooby tuning? TattooLost Texas Impreza Club Forum -- TXIC 69 07-25-2007 04:53 PM
I need fellow nasioc members help, anyone who goes to ECU or knows someone who does size18boarder South East Region Forum 0 09-16-2006 02:39 AM
Who does cobb tuning? jawbrkr Mid Atlantic Impreza Club -- MAIC 7 05-21-2004 07:54 PM
Who does ECU reflash in the Northeast? WRXVII Tri-State Area Forum 9 01-12-2004 04:05 PM
