Old 05-09-2001, 06:48 AM   #1
AudiGuy
Member#: 1865
Question Am I crazy????
Okay, so the CE light on the RS came on last week. I took it in to the dealer yesterday, and he calls me back and tells me it was a bad AF (air flow?) sensor, and that they replaced it under warranty. Now, when I drive the car, I could swear it has better low-end pull. Am I crazy, or could this have improved the low-end torque of the car? Also, will it improve my gas mileage? I've been getting some low mileage since I got the car. It's got just over 7500 miles on it and I've been getting only around 20 m.p.g.. This is mostly city driving, but nonetheless, the sticker on the window said 21 city/29 highway. TIA.
AudiGuy is offline   Reply With Quote
Old 05-09-2001, 07:44 AM   #2
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Post
Makes sense. If your air-flow sensor was bad, then the computer wasn't running the engine right, so the new sensor lets the car run correctly, hence more power. And I would wager that your gas milage will go up, also, unless you "enjoy" your new-found power too often
HondaH8er is offline   Reply With Quote
Old 05-09-2001, 08:35 PM   #3
markus
Member#: 438
2004 STi
White on Gold
Post
I was specifically told that when something like the O2 or AF Sensor goes, the car will run rich and worsen you gas mileage. This means your car was mildly bogging due to too much fuel.
Now that its fixed, your back to running you should be and likely a little HP to boot. I'm not surprised with your observations one iota.
Cheers,
MB
markus is offline   Reply With Quote
Old 05-09-2001, 09:14 PM   #4
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Wink
YES, you are crazy J/K. It would make sense that you would get more power from a new MAF. And you're lucky you didn't have to pay $330 for a new one.
TaiChih is offline   Reply With Quote
Old 05-09-2001, 09:16 PM   #5
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
MY00 Imprezas don't have MAFs. But yes, replacing a bad MAP sensor would likely result in a better running car. Otherwise, they'd be better off eliminating it, right?
Ben
bsquare is offline   Reply With Quote
('93-'01) Am I crazy, or just dumb? RS-LOVER Impreza Forum 2 04-06-2001 06:06 AM
Am I crazy, or just dumb? RS-LOVER Normally Aspirated Powertrain 7 03-06-2001 10:22 AM
Talked to dealer about new impreza. Am I crazy or is he wrong? XJGPN WRX Forum Archive 7 02-01-2001 10:19 PM
Am I Crazy? (kinda long) skyliner33v General Forum Archive 2 01-10-2001 06:53 AM
Bought Nitrous, Am I crazy? Eric SS Technical Forum Archive 6 08-02-2000 12:00 PM
