Old 07-07-2007, 03:08 PM   #1
skydes
Member#: 141347
2005 WRX
Default Is PB Blaster safe to use on the rear swaybar bushing mounts?
The 2 allen key bolts that hold the swaybar bushing mount onto the bushing are giving me a hard time to get off. I want to use PB Blaster on them but I don't want to damage the rubber bushings in case it is corrosive. Is it safe?
Thanks.
skydes is offline   Reply With Quote
Old 07-07-2007, 03:37 PM   #2
chewbakarox
Member#: 25478
2003 WRX Sport Wagon
It's fine.....I've used PB Blaster on rubber before (exhaust hangers) with no ill effects.
chewbakarox is offline   Reply With Quote
Old 07-07-2007, 03:49 PM   #3
skydes
Member#: 141347
2005 WRX
ok thankyou
Chunk in Sidewall: Is this still safe to drive on? scottjua Tire & Wheel 5 08-10-2007 10:04 PM
What to use on the black plastic around the exterior? Torch Interior & Exterior Modification 29 05-30-2007 07:31 PM
Is this tire too worn out to use on the track? chimchimm5 Tire & Wheel 4 01-16-2007 11:20 AM
Anyone change out the end links on the rear swaybar of a WRX yet? Snappy Brakes, Steering & Suspension 3 04-29-2001 05:23 AM
What kind of grease do you use on the rear sway bar bushings? ImprezedRS Brakes, Steering & Suspension 7 03-29-2001 09:07 PM
