Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 12-30-2001, 04:28 PM   #1
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Default Which weight oil to use in this situation?
In a month or two (still winter), I plan on driving into Idaho/Montana/Wyoming, where it gets a bit chillier at night than the 30F+ Seattle. I expect to have about 3k miles on the car then, and had the oil changed at 800 (10w30 dino).
Q: should I get the oil changed just before the trip to a wider range oil like 5w30 to help deal with the 0F nighttime temps I will encounter, or just leave the 10w30 in the car?
Old 12-30-2001, 05:45 PM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Yeah, put in some 5W30 oil. After all you might hit a cold spell and have to deal with -15 which would be pretty cold for 10W oil. For the $10 it costs for oil and filter, it's a cheap thrill. I'm south of you, in Portland, and I use 5W30 from November through March. Why not - it gives better gas mileage, and there's no way we're going to encounter temps over 80 unless we drive to Arizona.
Alan is offline   Reply With Quote
Old 12-31-2001, 02:49 AM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Thanks! I'm still new to travelling to temps below 20F or so.
Old 12-31-2001, 10:01 AM   #4
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Yeah, I've switched to 5w30 year round.
I've tested it down to 9 deg F.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 12-31-2001, 11:15 AM   #5
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
You'll probably want to change the oil before leaving on the trip anyway. I drove from Kirkland to some small town in NW Montana, then on over to Wisconsin and back a few years ago and the whole trip was around 3400 miles, and it's a pain to have to stop on a trip to do an oil change.
CosmoTheCat is offline   Reply With Quote
Old 12-31-2001, 09:16 PM   #6
javalee
Member#: 11006
2002 wrx wagon
black
go with amsoil 0-30
javalee is offline   Reply With Quote
Old 01-01-2002, 06:07 PM   #7
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Thanks again! I just heard today that it's now been over 2 calendar years since the temp. hit 90F in Seattle, so 5w30 it is.
Old 01-01-2002, 06:14 PM   #8
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Talking
Originally posted by armand1
I just heard today that it's now been over 2 calendar years since the temp. hit 90F in Seattle...
Does that mean it hit 90 in Seattle in January of 2000??
Old 01-02-2002, 02:49 AM   #9
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
'Twas a brutal ski season, that '00 was.
Old 01-02-2002, 09:05 PM   #10
mlambert
Member#: 13831
Im across the bridge from you and my wrx wagon is at 3000miles, so I just went down and got a filter and some 10w30. I prolly shouldve gotten 5w30 but im driving to Houston sometime within the next 6-8 days and I figured id be experiencing some radical temp changes during the trip.
Think I should go back and get 5w30, or even, what would be best for a 3000mile trip that will consist of 70-80mph ave speeds?
mlambert is offline   Reply With Quote
Old 01-03-2002, 02:44 AM   #11
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I'd say you got the right oil. The only reason for 5W is for cold starts, once the oil is up to temperature, it will be the 30 weight that is the important one and the 10W-30 will remain thicker after use and at higher temperatures than the 5W30.
Having said that, it depends on your route, and where you plan to overnight. If you are going through Wyoming and Colorado, and you get up in the morning and the temperature is below 20, you want to let the engine warm up gently, and if it gets REALLY cold, it could be tough to crank over the engine.
But assuming you drive down I-5 to California, and then take I-10, you'll never have any problem. Heck in the summer, for severe running, I've used 20W-50 - but I doubt you'll need that, unless you get an opportunity for some track time with the car!
Old 01-16-2002, 04:14 AM   #12
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
just go with 5w-30...my 2 pennies!
SQUAD_907 is offline   Reply With Quote
Old 02-07-2002, 02:16 PM   #13
zemmo
Member#: 5416
2002 Wrx wagon
Doesn't Subaru recommend 5W30? I don't know why you'd want to use anything heavier unless you live in an inferno, or race. I've used 5W30 synthetics (Amsoil, Mobil 1, Chevron 0W30) from 90 above to 50 below, and have had no problems whatsoever.
zemmo is offline   Reply With Quote
Which gear oil to use in rearend? STIGuy115 Transmission (AT/MT) & Driveline 14 12-23-2009 09:13 PM
wheel offset difference, which way to go in this situation? irish44j Autocross 5 11-22-2009 11:55 AM
What weight oil to use in 97-98 2.5liter? 2slofouru Service & Maintenance 3 11-22-2005 11:37 AM
What weight oil to use during the summer,... subymamma South East Region Forum 6 05-24-2001 07:40 PM
