Old 07-08-2007, 10:21 AM   #1
file_id
Member#: 28197
2003 WRX w/ VF34
Default Timing belt change with seal change?
I've developed a small leak in the front cover and my shop is going to tear it open and replace all the seals. Should I replace the timing belt while they are at it? The car has 29k miles.
file_id is offline   Reply With Quote
Old 07-08-2007, 12:32 PM   #2
edo2000
Member#: 68709
2012 WRX
red
I don't think that I would. The belt is spec'd for replacement at 105,000 miles, so it has more than 72% of its useful life left. A new timing belt for an STI is in the $200 range(for parts)and it is tedious to get everything lined up correctly after you remove it.
edit: After rereading your post, it seems that you probably will have the belt completely off to replace seals, but I still wouldn't replace it. Odds are you will be in there again before 105,000 miles has gone by.
edo2000 is offline   Reply With Quote
Old 07-08-2007, 09:54 PM   #3
scooby2.0t
Member#: 127092
2002 WRX WRB
05 Kawi ZX6R Plasma Blue
it all depends you might want to change it if you got oil all over it from your leaky seal. but if it looks fine i wouldnt replace it they arent cheap.
scooby2.0t is offline   Reply With Quote
Old 07-09-2007, 01:59 PM   #4
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
I would replace it if it is oil soaked, but if it isn't I would put it back in.
slowmike is offline   Reply With Quote
Good Shop in NoVA for Timing Belt/Fr. Cam Seal/Water Pump BossGVR4 Mid Atlantic Impreza Club -- MAIC 1 10-11-2004 11:23 PM
WRX timing belt tensioner with warranty IA Performance Private 'For Sale' Classifieds 4 12-03-2003 03:42 PM
EJ20 complete cam/belt covers with seals IA Performance Private 'For Sale' Classifieds 1 09-26-2003 06:54 PM
Will exhaust sound change with temp changes outside? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-31-2003 09:25 AM
Timing belt instructions with pics (Attn: Alex) N/A General Forum Archive 6 10-05-2000 03:41 PM
