Old 07-08-2007, 11:29 AM   #1
CO2.5i
Member#: 108722
2007 WRX STI
Urban Grey
Default JDM Spec-C One Piece Intake Manifold on 07 Sti
Just saw this manifold on Rallitek for the WRX. I can't post links yet.
Will this work on the 07 Sti since it uses top feed injectors?
Thanks for the help.
CO2.5i is offline   Reply With Quote
Old 07-08-2007, 12:12 PM   #2
`04AlpineWhite
Member#: 65562
Apparently the 07s are top feed after all...
`04AlpineWhite is offline   Reply With Quote
Old 07-08-2007, 12:55 PM   #3
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Originally Posted by `04AlpineWhite View Post
No, if it is designed for top feed injectors you would need a lot of modifications to make it work on your 07 STI.
Here's a modification that would give you about the same effect:
http://www.rallitek.com/jdmtdeinmari.html
They are TGV deletes for side feed injectors.
You'll need some sort of engine management so that you can turn off the CEL that you'll get from not having functioning TGV motors.
07s are top feed...
Open Source tuning for the CE lights
Only actual problem I would see is the throttle body bolt pattern. The Drive by Wire bolt pattern on the USDM STI is different
Junior2JZ is offline   Reply With Quote
Old 07-08-2007, 01:10 PM   #4
`04AlpineWhite
Member#: 65562
Wow, I had no idea that they changed the injectors to top feeds in 07. I stand corrected.
I do agree with you on the bolt pattern. If that manifold is for a drive-by-wire throttle body, then it should work.
Old 07-08-2007, 03:21 PM   #5
CO2.5i
Member#: 108722
2007 WRX STI
Urban Grey
I don't think it is made for DBW. Is there a JDM 1 piece manifold that was made for DBW?
Old 07-08-2007, 03:25 PM   #6
`04AlpineWhite
Member#: 65562
Old 07-08-2007, 05:56 PM   #7
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Awesome thread!
I have done this conversion on my 05 STi and here are the issues that pertain to YOUR car since you already have top feed injectors.
1.) You will need to have an adaptor bracket machined and welded on the throttle body opening. The reason for this is clearance. The DBW throttle body needs extra clearance than the DBC throttle body.
2.) You will need either the fuel rails from the new intake manifold OR a set of aftermarket fuel rails WITH an adaptor bracket. If you decide to go the aftermarket fuel rails option, PM me and I can point you in the right direction on where to buy these adaptor brakets. If you decide to just use the JDM rails then you will NOT need the brackets.
3.) TGV codes will come up. I am not certain how they affect the 07 STi as opposed to the 02-03 wrx vs 04-06 turboed subies. Most likely, you will just need to have the TGV codes disabled. In the past for the 02-03 WRX, TGV deletes were a PITA and you had to either get the APS crap or just buy an aftermarket boost controller to take boost control away from the ECU. in 04 subaru changed that and all 04-06's just need the codes disabled with no ill affects.
If you have any other questions you can PM me. I can also send you pics.
YWIA.
blinguskahn is offline   Reply With Quote
Old 07-08-2007, 07:15 PM   #8
flwrx
Member#: 35944
'03 v7 wrx
MBP
I am in this position now. I know Gruppe-S sells the brackets, but 80 bucks is a little pricey for what it is. Do you know which rails come with adaptor bracket? Or is it possible to buy JDM aftermarket rails?
flwrx is offline   Reply With Quote
Old 07-09-2007, 01:04 AM   #9
CO2.5i
Member#: 108722
2007 WRX STI
Urban Grey
Thanks for the information. This step is what concerns me though. It would probably be easier to just have my TGVs deleted. Too bad there isn't a manifold like this for the DBW model.
Old 07-10-2007, 08:53 PM   #10
calib17a
Member#: 64150
The JDM STI Forester intake manifold uses DBW which is a direct fit for the USDM STI at least for the 04-06. Otherwise you may have to use your top feed fuel rails from you 07 Sti.
calib17a is offline   Reply With Quote
Old 11-25-2007, 08:44 PM   #11
CO2.5i
Member#: 108722
2007 WRX STI
Urban Grey
Awesome thread!
Do you have a pattern for the adaptor bracket? What should it look like, what are the measurements? Thanks
Old 11-25-2007, 09:01 PM   #12
CO2.5i
Member#: 108722
2007 WRX STI
Urban Grey
Also, does anyone know about the V9 STi spec-C manifold that is supposedly DBW friendly?
Old 11-26-2007, 11:05 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
v9 is still cable throttle
Old 12-05-2007, 02:44 PM   #14
Greg555
Member#: 814
Want engine mgmnt?
I sell ViPec's ECU's
I guess I could test it as I have 07 longblock on the engine stand and a Ver 7 intake on the shelf.
Only problem Im off to Florida for a week
Ask me next WED and I will check the fitment
Greg
gdrozd@gmail.com
Greg555 is offline   Reply With Quote
Old 02-05-2009, 03:31 PM   #15
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Not to bring back a dead thread, but I dont see a need to start a new one.
Can you use the Spec C intake manifold with the Gruppe S adapter and WRX topfeed injectors/rails on a 257 shortblock? (assuming your tuned for it of course)
trex616 is offline   Reply With Quote
Old 02-05-2009, 05:44 PM   #16
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Short block is not the issue, its the TB, so if your car is a WRX then you have a pretty easy solution, its guys with 04-06 sti that have an extra issue with the TB, and the 07sti guys just have to deal with the TB. There maybe some other little things involved even when using the manifold on a WRX but sounds like the vender's have that figured out.
Token-Negro is offline   Reply With Quote
Old 04-07-2009, 07:21 PM   #17
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
Ok, I have searched, but I can't find the bracket that makes this manifold work with DBW throttle bodies. Can I get a link anyone? Also, maybe a dumb question, but the rallitek website says this will only work on 2.0L engines, and obviously thats not the case since blinguskahn did this on his 2.5L 05 STI. Why would they say for 2.0L only?
Suby Noob is offline   Reply With Quote
Old 04-07-2009, 07:35 PM   #18
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
if you are going to get this manifold might as well get some parallel fuel lines also like the perrin ones...if you order this from gruppe-s they will give you the bracket for free but it usually takes 3 months or so to come in if it even does come in
jcbluescooby is offline   Reply With Quote
Old 04-07-2009, 08:22 PM   #19
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
will those work with it? rallitek has the spec-c fuel rails for 250.
edit: after looking, I dont think the perrin ones will work, although that would be hawt.
Old 04-08-2009, 11:04 PM   #20
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
Bumpage
Old 04-08-2009, 11:18 PM   #21
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
To do this right we just need to wait till subaru makes a Spec C Manifold for the 08/09's since they are DBW. So far nothing is one piece. Next best solution is what i picked up was JDM TGV housings. No holes fully factory ported tgv's.
Old 04-09-2009, 09:27 AM   #22
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
Yea, I saw those on the rallispec website for 155. They may be the best alternative, then you dont have to mess with the fuel rails. After looking at the perrin unit though, that sure would be nice.
Old 04-09-2009, 10:57 AM   #23
MasterKwan
Member#: 98961
2003 WRX
I really like the TGV deletes Grimmspeed does. I'd take them over the JDM deletes. About the same price if you return the cores. Got mine thermal coated black.
Old 04-09-2009, 11:04 AM   #24
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
The grimmspeed units are simply USDM riser that are machined by hand correct? The plus there is that you do not have to elongate the holes to make them mate up with the manifold.
Old 04-09-2009, 12:52 PM   #25
MasterKwan
Member#: 98961
2003 WRX
I've done my own TGV deletes and was expecting the Grimmspeed ones to be about the same quality. I was wrong, the porting job was really impressive and matched the gaskets on the top an bottom sides better than I'd done myself. The ends are plugged and the plugs are glued into place.
The JDM ones offer stock finish on the inside and no porting whatsoever so, for me knowing what I know now, the Grimmspeed ones were a no brainer. I was so impressed, I'm considering their ported intake and exhaust products now. Once I find someone who does quality work, I tend to stick with them. I've said in the past and truely believe that TGV deletes really don't provide that much benefit but, if you're going to do them, buying them is a hell of a lot easier.
05 STi intake manifold on 07 WRX: I know it fits, need help w/WRX harness onto STi IM adjasont Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-01-2010 03:25 PM
2004 STi Intake Manifold on 2007 STi i_drank_what Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 12-03-2008 12:08 PM
Need help with intake manifold on 04 STI (pic request!) chibich Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-10-2007 09:36 AM
JDM SPEC-C Version 8 Intake Manifold (No TGV) GroupBuy! Gruppe-S Vendor 'Group Buy' Classifieds 119 04-11-2007 11:56 AM
Who is using Legacy GT intake manifold on their STi? PA04STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 09-10-2006 11:29 AM
