Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 12-30-2001, 06:30 PM   #1
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Question How are you supposed to torque a fluid line?
When installing my stainless steel brake lines I noticed that they had torque specs on them, 12-24 foot-pounds. How are you supposed to torque fluid lines? Because they are a line, I simply can't put a socket over them and use my torque wrench, because there is no way a sockect can fit over a line.
Is there a special tool for this, or is the brake line manufactirer just trying to cover thier ass from someone who overtightens the lines and leaks brake fluid?
I just tightened the lines up "real good" and hoped it's close to the correct torque spec... I'll just be sure to check my brake fluid over the next few weeks.
Corn-Picker is offline   Reply With Quote
Old 12-30-2001, 08:30 PM   #2
Bimmer
Member#: 4116
2002 Impreza TS
There ARE ways to adapt an open-end to your torque wrench, but it's a huge PITA and not worth it, IMHO.
IMHO, the manufacturer is just trying to cover his ass... figure that if you've got a 12" long open end wrench, you want to put 12-24 lbs. of pressure on it, and that sounds like "real good" to me.
Bimmer is offline   Reply With Quote
Old 12-31-2001, 09:28 PM   #3
MrHorspwer
Member#: 4063
The easiest and only way as far as I know or am concerned because it works just fine for me, to torque a fitting is with a crows foot of the correct size attached to a torque wrench.
MrHorspwer is offline   Reply With Quote
Old 12-31-2001, 10:20 PM   #4
Bimmer
Member#: 4116
2002 Impreza TS
Okay, the "crow's foot" is the short piece with the socket at one end and the open end wrench at the other, right? That's the alternative I was thinking of, but it's a PITA, because it's my understanding you have to re-calculate the torque wrench readings because you've increased the length of the lever...
Bottom line: "real good" is probably just about right. I'd worry more about over-tightening your brake lines than not getting them tight enough.
Old 01-01-2002, 04:23 AM   #5
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
hmmm, the crow's foot has a 3/8, 1/4 (or possibly a 1/2) square hole in one end and a open end wrench head on the other all about an 1 or so long. Now since there is no lever as such in use by way of the crow's foot in the operation of torque wrench then there is no increase/decrease in the application of torque over what is indicated on your torque wrench. Where I work there is an enormous amount of technical guidance on the use of torque wrenches and their appliction of such. We use crow's feet often and do not change the torque value applied when doing so. Either way a 12-24ftlbs variance is quite large and leaves room for error. Good and snug I always say.
mr2guru is offline   Reply With Quote
Old 01-02-2002, 05:56 PM   #6
tdman77
Member#: 9832
2004 STI
On the C-130 aircraft I work on we torque to 30ft lbs. But all hydro fluids are under high pressure at 3k psi. On other AN fittings tighten till snug then add 1/4 turn. This has worked on my other cars so far.
tdman77 is offline   Reply With Quote
Are you suppose to check the tranny fluid Ramo Transmission (AT/MT) & Driveline 4 02-06-2008 04:10 PM
How long after a filling are you supposed to be sore? Asinine Off-Topic 10 02-10-2005 01:13 PM
How are you guys running coolant and oil lines to your turbos? BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 0 10-01-2002 09:55 PM
How are RE730s supposed to feel? 215/45-ZR17 on Prodrive P7 feels very mushy...Luke? Sean Brakes, Steering & Suspension 10 10-01-2001 12:36 PM
