Old 10-13-2009, 12:04 AM   #101
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by fxue View Post
Where could I find a WRX or STI motor to put in 07 2.5i?
In your dreams or the noob section?
Seriously, it would make no sense in a car that new. If you want a wrx or sti, sell yours and buy one.
ps. don't bump an old thread next time, start your own in the noob section.
Old 10-30-2009, 10:13 AM   #102
edro*
Member#: 177764
2004 STi
Adriatic Blue
Leave the noob alone he doesn't know any better plus he reminded me to post this pic.
This is my "custom" tool to keep the Flywheel from turning. it is essentially a wooden dowl that i jammed in between the f/w and block. its safe and effective.
edro* is offline   Reply With Quote
Old 12-12-2009, 07:57 PM   #103
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
bump this useful thread
KB'izzle is offline   Reply With Quote
Old 03-13-2010, 02:39 PM   #104
22psiSTI
Member#: 211423
2005 PSM STI
Corn fed
Thanks for all the pics, I'm a good mechanic but new to suby's so this made it easy for me to pull my engine and save lots of cash. Especially since I had to do it again a month later because I bought a really ****ty clutch and had to pull it out and put in a stock replacement haha
22psiSTI is offline   Reply With Quote
Old 04-07-2010, 12:46 AM   #105
jerry curl
Member#: 155135
03 115k Bugeye
285 AWHP 300 ft lbs torq.
subscribed
jerry curl is offline   Reply With Quote
Old 04-07-2010, 12:36 PM   #106
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
I would suggest double-nutting the 2 bottom studs on motor(that go through trans),pull them out before pulling engine.
and especially leave them off to install the motor,makes it alot easier.
Alot less room you have to slide the motor and trans to get seperated.
jsnm is offline   Reply With Quote
Old 04-07-2010, 03:02 PM   #107
guypier
Member#: 162669
Default Turbo
Looks pretty simple i would love to tear out my 2.5i or maybe ill just put a turbo on that
guypier is offline   Reply With Quote
Old 06-28-2010, 09:00 AM   #108
Izero
Member#: 121332
2004 STi
Platinum Silver Metallic
Would you mind if I turned this into a PDF... b/c its definitely going to be extremely helpful in the future.... I'll PM you about it...
made a PDF... I'll have a link up for it in no time flat....
and here's the Link to the PDF ladies and Gents!
DIY Engine Pull
Izero is offline   Reply With Quote
Old 11-18-2010, 06:19 PM   #109
feelme
Member#: 237935
Angry
how did you get the lower bolts off the tranny i am pulling my motor but i cant gain access to the driver side lower bolts due to the damn driveshafts in the way...
feelme is offline   Reply With Quote
Old 11-18-2010, 06:33 PM   #110
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
^ combination of swivel head extensions and a little patience. you can do it, but it's not an easy straight shot. i find it's easier to get all the bell housing bolts/nuts out from the top of the motor.
PCSkiBum_21 is offline   Reply With Quote
Old 11-18-2010, 06:55 PM   #111
Csquared33
Member#: 198053
93 2JZ something
swivels are your best friends when ur working on a subaru.
Csquared33 is offline   Reply With Quote
Old 12-10-2010, 06:07 AM   #112
sethbrown2007
Member#: 234701
MBP
Awesome write up! So need some help, I'm pulling my motor this weekend and i noticed that you hooked the strap to hoist your engine on the driver side onto the ac pump bracket, but where would the best place be to hook it onto the passenger side? thanks for this and all your help!
sethbrown2007 is offline   Reply With Quote
Old 12-10-2010, 01:38 PM   #113
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
You can do it wherever works really, I usually thread a bolt into the bell housing and use that. If you have a leveler it works a lot easier than just a chain. If you do it that way it isn't really balanced so you have to pull up on the drivers side also, but it works.
Old 08-28-2012, 08:59 AM   #114
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Great thread! Pulled motor using pics, worked as advertised.
Thanks bevis!
slowgenius is offline   Reply With Quote
Old 10-06-2012, 10:03 AM   #115
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
Great thread! Also pulled my motor using a checklist and these pictures. Worked perfectly
simon021 is offline   Reply With Quote
Old 01-05-2013, 07:38 PM   #116
davisclan
Member#: 283881
2004 WRX wagon 2.0
First time engine pull for me.
I have a stock WRX, I haven't unplugged a sensor on the exhaust. I see one on the straight pipe is that it?
Second I cant seem to get the bolts from the down pipe to the straight pipe loose. Any ideas?
I have sprayed penetrating oil. I am struggling with space, or is it muscle power?
Sean
davisclan is offline   Reply With Quote
Old 01-05-2013, 10:37 PM   #117
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Sean
Assuming your car is stock or close to stock, the oxygen sensor is on the passenger side of the exhaust manifold kind of behind the passenger front tire. If you dont pull that sensor out you will either not be able to get the motor out or you will damage the sensor when you do it. There is another oxygen sensor on the exhaust right around the center of the bottom of the car (half way between the front bumper and the rear bumper) that typically doesn't need to be removed when you pull the motor, be sure not to mix the two up.
If you're talking about the bolts at the end of the down-pipe next to the cat pipe (or race pipe if you dont have a cat), those are pretty unusual bolts to have an issue with. They are pretty well exposed and should come off easily if you have the correct tools. Be sure to use a six point socket to avoid stripping them. If you need more force, add a breaker bar with a pipe (hack handle?) on the end. If you're still stuck, PM me with your contact info and I will explain it to you. Good luck!
dexterous is offline   Reply With Quote
Old 01-07-2013, 09:28 PM   #118
davisclan
Member#: 283881
2004 WRX wagon 2.0
I am getting there. Not breaking things or my hands ;-) Hopefully I will have the motor out on Saturday.
For the front O2 sensor, do I need to take it out (unscrew) of the exhaust pipe or just unclip it from the harness and make it stay with the motor? If I need to take it out so it doesnt get damaged, is it a "simple" unbolt? Some of my other simple things have been a mission. The AC was awful, and the wiring clips so fiddly, I thought I would break the plastic. Now its so obvious.
Sean
Old 05-08-2013, 08:25 PM   #119
Montanasaurus_rex
Member#: 342272
05 wrx
black
I am having a lot of trouble with the clutch pin removal, to the point that I am going on day 3 of trying the remove it.
Is there any special trick to getting it out, I tried the battery tie down, and an intake manifold screw which was the same thread pitch to no avail.
Pretty much everything on this car was stuck on, but this bugger seems to really be testing me. Any ideas would be appreciated.
Not that I think it matters, but the car is an 05 wrx
Montanasaurus_rex is offline   Reply With Quote
Old 05-08-2013, 09:09 PM   #120
davisclan
Member#: 283881
2004 WRX wagon 2.0
I really struggled with mine. I am assuming you are referring to the "cylinder" that has a 6mm screw thread and is under the hex bolt cap on the side of the transmission.
If so I threaded a bolt in and used leverage(long screw driver) to edge it out horizontally. I also assume you had yanked up on the clutch lever to release it. I don't know if that helped. If its all been stuck enjoy getting the transmission loose from the motor. Putty knife was key for me. That patience persistence and prayer.
Old 05-08-2013, 09:14 PM   #121
Montanasaurus_rex
Member#: 342272
05 wrx
black
I've wiggled the clutch lever back and forth, but I was under the impression that you needed to remove that cylinder before you could lift the lever up to release it. I will have to try to get that up I suppose.
And yes, that cylinder with the hex cover is the same one I am referring to.
Old 05-08-2013, 09:16 PM   #122
niemkij
Member#: 141922
2006 Impreza Sti
Find a flange bolt that fits. Get two big flat screwdrivers or small prybars, one on each side and pry on the bolt. It shouldn't take more than that to get that pin out. Check that the clutch fork is loose.
niemkij is offline   Reply With Quote
Old 05-08-2013, 09:35 PM   #123
Montanasaurus_rex
Member#: 342272
05 wrx
black
And if the clutch fork is loose will it wiggle up and down, or back to front? Right now it wiggles back to front just fine, but that's it
Old 05-08-2013, 10:13 PM   #124
davisclan
Member#: 283881
2004 WRX wagon 2.0
I have only done this once before, but mine felt obviously loose. It was free to move in all directions. Good luck.
Old 05-10-2013, 01:41 AM   #125
Montanasaurus_rex
Member#: 342272
05 wrx
black
So just an update, I got it out. I was using a flange bolt before, but just applying pressure from the top. I took nimekijs advice and used a small screwdriver on the left side, and a chisel on the right of the bolt and after a little elbow grease it started inching out. From there the chisel on top and yanking on the bolt got it out, and man was it dirty. That whole car is just disgusting an in need of a major cleaning.
But, short story long, motor is coming out of the car now for a rebuild, and hopefully she'll be back on the road within a month
DIY: Pull your engine winterfourever Service & Maintenance 16 12-13-2015 09:33 PM
How to pull your oil pan without pulling the motor ihadmail Service & Maintenance 42 05-23-2015 02:27 PM
DIY: Piecing together your own stealthback exhaust Donzo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-17-2008 11:20 PM
Making your own wrist pin pulling tools reddevil Built Motor Discussion 14 08-24-2007 06:06 PM
Lots of pics from Lane Motor Museum, Nashville sigurd Member's Car Gallery 13 02-22-2007 09:11 PM
