Old 07-08-2007, 10:47 PM   #1
flycaster
Member#: 60142
2011 WRX
Grey
Default Meth Injection & Hot temps
I run a 50/50 H20 and Meth mix, and for the second summer I'm having occasional issues with boiling line fluid causing the pressure pump to cavitate. It happens when it is is ubber hot outside (105+) and the underhood temps skyrocket.
The only reason I'm posting this is as a heads-up to anyone running straight meth, which has an even lower boiling point than my mix. If you don't have a failsafe and/or a primer pump to keep the feeder line under pressure, be careful when it is really hot outside - your pump may not be able to get any juice to the injector.
Note - this problem increases with altitude. Beware
flycaster is offline   Reply With Quote
Old 07-08-2007, 11:12 PM   #2
shortys64
Member#: 74453
04 WRX-PSM
This sounds like an awesome problem....I have the SMC kit, do I have to worry about this? I am running a 50/50 mix. Thanks for the heads up.
shortys64 is offline   Reply With Quote
Old 07-09-2007, 12:07 AM   #3
flycaster
Member#: 60142
2011 WRX
Grey
I can't answer that - I'd run it by your installer.
I have an Aquamist system that utilizes the I/C spray container in the trunk and the original lines to pull liquid to the pump and injector system located in the engine compartment. It's boiling in the line before it gets to the injector pump - after that it is pressurized so there is no problem. My fix will be to relay the I/C pump (located in the tank) to fire with the Aquamist pump - that will pressurize the feeder line all the way to the Aquamist pump and raise the boiling point.
Old 07-09-2007, 09:24 AM   #4
ptirmal
Member#: 82243
07' Acura TL-S
So it's boiling in the trunk? Why not just install the AM pump in the trunk and run new hose to the IC? Also if it's getting hot in the line leading to the AM pump under the before it gets to the hood why is underhood temp important?
ptirmal is online now   Reply With Quote
Old 07-09-2007, 11:35 AM   #5
flycaster
Member#: 60142
2011 WRX
Grey
No, no, no - it's boiling in the feeder line portion inside the engine compartment leading up the main AM pressure pump. I can see it bubbling.
Here's my point: at my elevation (@ 4,000' asl), a 50/50 mix will boil at approx. 172f, and 100% meth will boil at only 140f. With hot outside temps, a hot engine, and no or low air, it's gonna boil unless it's under pressure.
Old 07-09-2007, 01:39 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
jblaine is offline   Reply With Quote
Old 07-09-2007, 01:50 PM   #7
flycaster
Member#: 60142
2011 WRX
Grey
^^We tried that right off the bat. If the car sits in a hot parking lot long enough with no air flow it isn't enough - line pressure is the best solution.
Old 08-13-2007, 09:58 PM   #8
defrancb
Member#: 156581
2004 WRX/STi
WRC Blue Pearl
Go to the Snow Performance website, they have an upgraded solenoid that may help when using the stock trunk mounted resvoir for water/ methanol.
defrancb is offline   Reply With Quote
Meth Heads: Small Turbo, 100% and 50/50 Meth Injection. What should I expect? nicholam Water/Methanol Injection, Nitrous & Intercooler Cooling 15 01-14-2008 08:31 AM
Alky injection or meth injection? fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-14-2007 12:53 AM
572hp & 532tq Pumpgas/Meth injection Badazzcr Proven Power Bragging 25 01-22-2006 12:58 PM
Anyone in TX running alky/meth injection _sti_05 Texas Impreza Club Forum -- TXIC 28 12-21-2005 12:52 AM
Meth Injection Kit MAD TKD Water/Methanol Injection, Nitrous & Intercooler Cooling 25 03-08-2004 12:12 PM
