#1 |
Member#: 127319
Vehicle:2002 WRX MBP |
ok...i've search here and on enginuity and openecu and could fine the answer...so..
...just bought an openport cable...i have everything pluged where they're suppose to...but it wont let me do anything with the ecu...(reading from...load to...test load...etc..)...at the bottom of ecuflash screen...no vehicle interface... and it won't let me log with enginuity too...only com port3 shows up...no other choices...i'm sure there someone out there that can help...
#2 |
Member#: 124318
NWIC
Vehicle:1989 Taurus SHO Oxford White |
IIRC you have to install the drivers for the cable, then the comm ports will become available. when you first plug in the cable it will detect the device, then you click ok for it to find the drivers for the device automatically. that was for xp though I have no idea how vista does that stuff. good luck.
#3 |
Member#: 142599
RMIC
Vehicle:2002 WRX silver |
I'm running vista with no problems. Try reloading the software.
#4 |
Member#: 129905
AKIC
Vehicle:2005 WRB WRX 2003 F-350SD, 7.3PSD |
did you install ECUflash to get the driver on your system? I'm running vista w/ ECUflash & Enginuity and it works great. You can't just plug the cable in, install enginuity and call it a day. I'd research the whole openecu option.. Seeing as you havent even researched enough to know to install ecuflash, you might need to learn a thing or 2 about the program. Search my friend.. It will do you more good in the end!
#5 |
Member#: 106818
South East
Vehicle:2002 WRX |
Yah took me a bit to realize i had to load the drivers myself, but wasn't to bad. Just be patient, feel free to ask more questions if ya can't find it searching. Good luck!!
#6 |
Member#: 51243
Vehicle:2004 Subaru WRX STi WRB - GTX30r |
My Vista laptop came with the Serial ports disabled, when the laptop is booting up hit F2 go into BIOS and make sure your serial ports are enabled. Else its the drivers.
#7 |
Member#: 129905
AKIC
Travis
Do you have the tactrix cable? |
| Thread Tools | |
| Display Modes | |
| AP and Windows Vista | SCMedic | AccessPort | 32 | 06-08-2009 08:38 PM |
| Ap v1 and windows vista 32-bit | SonnyCrockett04 | AccessPort | 2 | 12-05-2007 11:44 AM |
| Need help with alarm and window module | hybrid gti 2 | Car Audio, Video & Security | 4 | 06-14-2007 03:39 PM |
| Getting a new laptop and windows vista | Mrs.COS | Off-Topic | 1 | 08-17-2006 01:37 PM |
| need help with cable modem, digital cable. trying to split signal | STEALTH-WRX | Off-Topic | 9 | 08-18-2003 04:43 PM |
