Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 07-09-2007, 07:32 PM   #1
P&L Motorsports Inc.
Vendor Sales Rating: (26)
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Default In Stock at P&L Motorsports!
Check out the posts all through this thread to see what we we're currently keeping in stock!
Spearco Top Mount Intercoolers
These high quality intercoolers come highly recommended by us at P&L. We have built quite a few high horsepower Subies using these intercoolers. Great flow, excellent fitment, and no lag in spool up from long front mount IC pipes! What more could you ask for!?
Turbo XS Up Pipes
This is a great chance for you older WRX owners to get rid of that cat in front of the turbo before it has a chance to blow it up! Turbo XS makes a great Up Pipe, perfect fitment, great look, and excellent price.
Cobb V2.0 AccessPorts for 2.5L Imprezas 04-07
The poster child of engine management is back and selling faster than ever! I'm not quite sure why I'm even posting this as In Stock because they go like hot cakes. (Sorry 2.0L guys and gals.. we just sold out, but I promise we'll get more in stock soon if you don't want to put one on order!)
** Currently out of stock, We will be receiving a new set of them in approximately 3 weeks from today (7/21) **
Endura-Tech Coilovers
These things are awesome. Height, dampening, and camber adjustable! Perfect for the daily driver and weekend racer. Available for all Imprezas my02+. Best of all, if we run out of stock it won’t be for long.. they’re local!
Spring Rate Front: 7kg (392 lbs./in)
Spring Rate Rear: 5kg (280 lbs./in)
WhiteLine Swaybars/Bushings/Endlinks
Tons of great suspension goodies in stock from a great company. No seriously, there's tons of stuff here. If you've been meaning to stiffen up your suspension, now is the time!
ACT Clutches and Flywheels
We have a number of different types for different applications. Call us up to see if we have what you’re looking for. If not, we can order anything you want.
Also, don't forget to take a look at our Maintenance and Services thread, as all these prices are still valid (subject to change .) I know someone needs an oil change or summer tires mounted!
Maintnence and Services
Please PM Me, or email for prices and to check availability.
Ty
P&L Motorsports
Sales@PandLMotorsports.com
847 678 4311
P&L Motorsports Inc. is online now
Old 07-13-2007, 06:44 PM   #2
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
New P&L Product IN STOCK! Hot off the work bench!!
We always knew that Tial's products had been legendary in terms of reliability, but never had a way of packaging their BOV design in such a way that every Impreza owner could leverage them. That has changed with the release of our new BOV kit for the 2002-2007 Impreza lineup.
We start off with a custom designed and waterjet cut flange. That is precision tig-welded onto a v-band flange that the Tial high performance BOV is bolted onto. Then the entire assembly is machined to make sure the flange surface is flat and true.
Our kit has been designed and tested around several of the common aftermarket intercoolers, as well as the standard OEM units.
All kits will include our custom flange assembly, v-band flange, the Tial unit, a new 3 layer BOV gasket, and a machined plug for your factory return line. You supply the elbow grease, and about 3 minutes later, you're done.
Our kits will be competative and retail in the same area as other high quality atmospheric units such as HKS's SSQV.
More info and you can buy online here! :
http://www.pandlmotorsports.com/~pan...9430acf4bf0cf4
*Update*
We are now offering our BOV Kits with a REUSABLE O-ring gasket built in to the flange! Instead of paying for a new gasket each time you want to take the intercooler or BOV off, you can reuse this one which is pressed into the flange. It also provides better protection against boost leaks as pressure is applied evenly around the hole to ensure a proper seal!
P&L Motorsports GT30r Kits In STOCK
P&L has spent over half a year designing, refining, and testing our turbo kit offerings for the Subaru Impreza. After having had to install and work with several companies other products, there were some shortcomings we simply knew could be overcome. So we started from scratch and started designing a kit from the ground up that covered fitment issues, quality control issues, etc.
Hand crafted in house by our fabricators, each kit is built and designed with pride in very small batches to keep quality control high. We've extensively tested all of our kits with various model year cars to make sure there are absolutely no fitment issues.
The heart of the system is the Garrett GT3076R turbocharger. For those looking for power levels under 450WHP (recommended for stock internal EJ257s) we have a .63 A/R exhaust option that is optimized well between 20-26 PSI. For those looking to get everything out of it, the .82 A/R exhaust option will spool up a few hundred RPM later, but flow well between 25-30 PSI (octane being appropriate of course).
Believe it or not, our kits are designed to work with high quality, upgraded top mount intercoolers (Spearco and TurboXS being our preferred choice). For those applications our kit comes with a 4" to a 3" intake with integrated MAF adapter. If you'd like to go with a front mount solution, the kit will come with a weld in 3" MAF adapter for blow through applications. Specify which you'd like at time of ordering.
Only the best components are used to keep maintenance down, and installation simple. Wastegate control is via a high quality Tial 44MM external wastegate. The Tial's V-band clamp assembly keeps maintenance at a minimal as there are no gaskets to blow out.
A custom stainless steel power steering line is included to replace the unwieldy factory unit, dramatically cleaning up the look of the engine compartment as well.
Our 30R kit includes:
-Garrett GT3076R turbocharger (.63 or .82 A/R)
-Stainless Up-pipe
-Stainless Downpipe with two O2 sensor bungs
-Tial 44MM EWG, V-bands and dump tube
-Choice of 4"-3" intake with integrated MAF, or 3" blow through MAF pipe
-Stainless steel power steering line
-Associated couplers and clamps
-Detailed instructions
Tuning required. For off-road use only.
$3499
OR $3149 plus install!!
P&L is now offering 10% off the hardware kit if you have it installed by us!! $350 off!!
93 OCT
100 OCT
Ty
P&L Motorsports
847 678 4311
Old 07-14-2007, 02:29 AM   #3
Umphreys448
Member Sales Rating: (2)
Member#: 73519
2003 WRX
The Spearco IC, uppipe, and sway bars are exactly what I'm in the market for... now if only Cody would respond to any of my PMs I might actually be able to buy something from you guys...
Umphreys448 is offline
Old 07-17-2007, 01:26 PM   #4
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Bump for updates!
Old 07-19-2007, 12:09 AM   #5
2MANYCARS
Member#: 24046
2007 STi, EVO, M6
E55, ML63, & Old 02 WRX.
PM'd you about the Tial BOV and Spearco TMIC, please reply.
2MANYCARS is offline
Old 07-19-2007, 12:27 PM   #6
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
PM Replied! Thanks for doing business with us!
Old 07-26-2007, 02:30 PM   #7
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Megan Racing Oil Catch Tank
Please tell me you aren't still using that empty coke bottle as an oil catch...
Why not upgrade the look and performance of your engine with these polished billet aluminum Oil Catch Tanks from Megan Racing.
Size 6.5cm x 8cm x 18cm
Package comes with all hardware and hoses, as seen in picture.
$69.95
Ty
P&L Motorsports
847-678-4311
Old 07-26-2007, 05:57 PM   #8
eurospek
Member Sales Rating: (20)
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
PM me a price for Whiteline wagon specific swaybars, 22mm front, 20-22-24 rear.
eurospek is offline
Old 07-31-2007, 12:39 PM   #9
SplatZ400
Member Sales Rating: (71)
Member#: 84377
2011 335d
pm sent on a tune ?
SplatZ400 is offline
Old 07-31-2007, 12:57 PM   #10
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Originally Posted by SplatZ400 View Post
pm sent on a tune ?
Replied.
Old 08-02-2007, 07:24 PM   #11
maxxflow
Member Sales Rating: (3)
Member#: 133504
2002 Impreza WRX
Platinum Silver
price on turbo xs up pipe installed
maxxflow is offline
Old 08-02-2007, 07:49 PM   #12
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
PM'd!
Ty
Old 08-09-2007, 08:21 PM   #13
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
**UPDATE**
$3449
Old 08-23-2007, 04:55 PM   #14
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
AEM Water Injection Kits
Lowest price around!!
We have installed many water injection kits here at the shop and we haven't seen one we have liked better than this kit! Ease of install, and quality of parts is OUTSTANDING with this kit. I already have one coming in for my car!
The Water Injection Kit is a safe and economical way to reduce air inlet temperatures to increase boost pressure for more power. Lower air inlet temperatures allow users to advance timing without having to run higher-octane fuel. This is the most complete kit available on the market straight out of the box- no additional parts required.
WATER INJECTION KEY FEATURES:
• Universal kit includes everything you need for installation
• Progressive, controller-driven 150 PSI pump
• One-gallon tank with integral fluid level sensor
• Dash light for system status and low fluid warning
Alcohol Compatible (up to 50% in solution with water)
• Progressive controller, provides boost-dependent variable flow
• Output provided to either decrease timing or boost if the system runs out of fluid or detects an error
• Includes three jets to match your power requirement
Order online today !
P&L Motorsports Online Store - AEM Water Injection Kit
Old 08-27-2007, 05:48 PM   #15
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Endura-Tech Hood Dampers !!
These things are so awesome. Plain and simple. They look amazing, and perform exactly as they should. Available currently only for 02-07 Imprezas, but be on the look out for 08+ and pre-02!
Included is 2 Carbon Fiber struts, 2 white Endura-Tech stickers to be applied to the shaft, and 2 mounting screws.
Originally Posted by Endura-Tech
Our CF hood dampers are made with real carbon fiber cylinders overlaying the twin sealed gas damper. The benefits of a twin seal is to help keep the piston rod clean and promote the life of the gas damper. These are a functional and fashionable option to your OEM hood stand. Great for show cars or just the car enthusiast who likes to work under the hood; our hood dampers are durable and come with a 10,000 cycle warranty (open & close 5,000 times) or two year warranty, which ever comes first.
We have 100 sets in stock ready to go!!
Pricing is too low to list! PM For best price!
-Ty @ P&L Motorsports
Old 08-29-2007, 07:49 PM   #16
HP ADDICT
Member Sales Rating: (1)
Member#: 121366
06 STI
Price of turbo kit installed and tuned on a 06 sti?
HP ADDICT is offline
Old 08-30-2007, 12:51 PM   #17
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
^^^ You have a PM.
Thanks!
-Ty
Old 09-26-2007, 04:36 PM   #18
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
P&L Used Parts In Stock
GPmoto equal length header + combined up pipe - comes pre wrapped! - $500 SOLD
H&R Springs Part number: 54457 - Was on a 06 STI for less than 5k miles, so clean I could probably sell them as new - $250 SOLD
Seibon carbon fiber hood scoop, 04-05 STI sized, about 3-5 miles on it. - $200
Used parts are cash only, picked up, or can be dropped off for a fee to the Chicagoland area.
-Ty
Old 09-27-2007, 07:58 PM   #19
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Used Seibon 06-07 carbon fiber hood with built in hood scoop: SOLD
Old 09-28-2007, 03:56 PM   #20
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
2005 STI Accessport V1 - Excellent condition - All cables included in original box - $500 OBO SOLD
Old 10-20-2007, 01:16 PM   #21
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Kartboy Bushings and Shifters
XL and Standard Exhaust Hangers - $8 bucks each, XL add $1
5 Speed WRX shifters - $100
6 Speed shifters - $150
Front shifter bushings - $30 WRX $32 STI
Rear shifter bushings - $35
Nuts and Studs
ARP Extended Wheel studs - We have a ton ! $50/wheel
Muteki open ended spline drive lug nuts (chrome, brushed aluminum, black, anodized blue) - $50 shipped!
Exhaust
Cobb CATTED Downpipe WRX/STI - $595
TurboXS Downpipe, Cat adapter (for use with other brand cat backs), Midpipe, Axle back. Can be sold as a complete set or parted out.
P&L Street and Race Series exhausts. Full 3" cat backs catered to your choice of components $599-$649 ~FREE Kartboy exhaust hangers~
DEI Turbo blanket and heat wrap kit - $95
DEI Heat wrap 2"x50' - $51
Ty Curtin
P&L Motorsports
847 678 4311
Old 10-22-2007, 10:44 PM   #22
see red
Member#: 138838
A white guy with
a red car
Now, if I can get in there........I need to know if the signiture exhaust will mount up to my invidia dp. Obviously I need the price for all the hardware as well, please.
Also need a wide band.
see red is offline
Old 10-24-2007, 06:05 PM   #23
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
PM'd in other thread.
Old 10-25-2007, 08:48 AM   #24
mykrrrr
Member Sales Rating: (22)
Member#: 733
'13 Focus ST
-Ty
Is this still available? I'm coming into town tonight and could pick it up tomorrow if it's still available. PM me ASAP or text me @
mykrrrr is offline
Old 10-25-2007, 11:31 AM   #25
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Pm'd
-Ty
Closed Thread
Prodrive RB320 for the 2005+ STi- IN STOCK at 201 Motorsports!! 201Motorsports Suspension/Brakes/Handling 6 11-27-2007 11:27 AM
SEMA Week Special at P&L Motorsports P&L Motorsports Inc. MWSOC Vendor Classifieds 0 10-25-2007 08:18 PM
PDR day at P&L Motorsports - 05/19/2007 P&L Motorsports Inc. MWSOC Vendor Classifieds 55 05-21-2007 01:33 PM
Season's greetings from all of us at P&L Motorsports P&L Motorsports Inc. Mid West Subaru Owners Club Forum -- MWSOC 8 12-24-2005 08:11 AM
