#1 |
Member#: 82314
AKIC
Vehicle:2005 WRX STI wannabe Darkness |
I recently ordered the "teardrop" keyless entry remote for my 05 WRX; it came in today. I ordered it from a place OTHER than the dealership because they wanted WAY to much for the remote. Anyway, I was able to get the OEM remote for $39 instead of $120, with the program instructions. Now, I don't know if any of you have ever programmed your OEM remotes, but it's not SUPER simple-as they'd have you believe. I've run through the instructions about 5 times, to no avail. Any chance one of you could offer up some advice? I REALLY don't want to spend the $85 dollar programming fee that I was quoted here at the Fairbanks dealership. It was worth me asking, anyway.
#2 |
Member#: 90347
AKIC
Vehicle:2013 BRZ & Imp 2.5RS Yamaha FZ8 |
Getagrip would be the guy to help you. He's our remote guy. I can't program those ones. 00maddog should be able to help as well.
#3 |
Member#: 115511
AKIC
Vehicle:2005 wrx /w babyseat 2011 Forester 2.5x |
go to autoservice company, talk to jeremiah, hes one of the sales guys, he may be able to help.
#4 |
Member#: 113884
Vehicle:2013 BRZ Black on Gold |
would those work on the 04's? I liked the other one way better then the 05's!
#5 |
Member#: 62410
AKIC
Vehicle:2004 ra'd redrex in 8k w/ STI kit :) DASH |
which style remote, red button on back or not?
#6 |
Member#: 82314
AKIC
No red button on the back. This is the one I ordered:
![]() There's no trunk button, though. |
#7 |
Member#: 62410
AKIC
if no red button then just sit in car doors unlocked and all shut including trunk, cycle key ten times off to on,,, then back to acc, should honk at this point. keep trying until it honks, then open close door, hit button, open close door, hit transmitter 2 button, etc. if you only have one transmitter you can keep filling the slots (4 i think) with the same number to ensure only that fob will open it.
#8 |
Member#: 82314
AKIC
What do you mean, "hit transmitter 2 button, etc."?
#9 |
Member#: 82314
AKIC
Tried it, still no luck(horn doesn't sound). Any chance I'd have to clear any codes set by a previous owner?
#10 | |
Member#: 90347
AKIC
#11 | |
Member#: 82314
AKIC
Too bad there's no emoticon for frustrated...Oh well, trial and error, I guess. |
#12 |
Member#: 20328
AKIC
Vehicle:'05 FXT - '98 Foz '07 Legacy spec.B |
A = 11
B = 12 C = 13 D = 14 E = 15 F = 16 |
#13 |
Member#: 2045
AKIC
Vehicle:BRZ, E90 BMW 330xi 05 Mustang GT (hers) |
EDITED. I just realized you're is FBX. I was going to have you stop by because it takes all of 90 seconds.
Jake Last edited by Getagrip; 07-11-2007 at 02:24 PM. |
#14 |
Member#: 82314
AKIC
Thank you, the instructions don't specify that. How about the Zero? Or is it a 10? 4-10-A(11)...? Now, if I can get the damn thing to cycle...stupid.
Worse comes to worse, I'll be down in Wasilla next weekend(leaving Thursday night for a softball tournament). I have nothing but time on Friday and I was probably going to shoot into Anchorage, anyways. Thank you, as well. |
#15 |
Member#: 2045
AKIC
The correlation of numbers Jordy is referring to is good idea but not relevant. The numbers "410AB210A" is the part number. Nothing to do with programming.
You have the correct procedure for the progamming, BUT...... Look at page 2-15 of your owner's manual. The phrase in step #4 " Be sure to stop at the LOCK position." is incorrect. The phrase should be saying "Be sure to stop at the ACC position" This has been an error in the manuals for this type of programming since 1999. I remember pulling my hair out teh first time I tried this programming proceedure using the owner's manual. You can also call me at 261-0633. Jake |
#16 |
Member#: 82314
AKIC
So, start at ACC..ahhh. Then, it's ACC-ON, ACC-ON, etc...? If that's the part #, then where is the transmitter #? I opened it as the instructions stated, and that's the only # I can see on the board, and it's 8 alpha-numeric digits long.
#17 | |
Member#: 2045
AKIC
No, do as the instructions say, but only change the phrase i mentioned. You still start out at OFF, but after on the tenth backward rotation of the key end at ACC, not LOCK. The 8 digit alpha-numeric # inside the transmitter is of no consequence. If there is an 8 digit numeric # inside then that's used for programming other Subaru keyless systems. If still having probems, come see me. Jake |
#18 |
Member#: 62410
AKIC
aaaaaaagh.
if it has a red button on back you enter the 8 digit (all numbers!!) code with the lock switch. if it has no red button you just program like the old 02+ remotes. there's no way to enter the letters that are in the non-red button transmitters. keep trying the ten cycle thing, and follow the directions i posted, not the incorrect ones in the package as jake noted above the directions incorrectly tell you to go to lock, just go to acc. |
#19 |
Member#: 82314
AKIC
My sentiments, EXACTLY. I've tried the cycle thing OVER AND OVER again, and it just won't cycle. I start at LOCK(0), turn to ON(3), and return to LOCK(0)=1. I do this 10 times, except, on the 10th time, I stop at ACC(2). Still, no honk, no buzzer, no squeek, no airplane sound, no evil laugh, no NOTHING!!! Of course I'm exaggerating a bit, but, you get the point, HAHA!!! I'll keep trying to cycle it and try not to smash my new transmitter and forget it.
#20 |
Member#: 2045
AKIC
Hmm. You are performing the 10x cycle thingy with 15 seconds, right?
If you happen to be in A-town stop by Conti or PM me. |
#21 |
Modest Mouse
Moderator Member#: 27323
AKIC
Vehicle:2000 RSTi |
I would have paid the $120.... :-)
#22 |
Member#: 82314
AKIC
Yep. Any other reason(besides operator error), that it wouldn't be going into programming mode? Worse comes to worse, I'll be in Wasilla next Thursday night and I'll swing into Anchorage on Friday.
#23 |
Member#: 117002
AKIC
Vehicle:2010 >40psi, oh yes! POWERSTROKE |
Does it matter if it is in gear or if the e-brake isn't on?
#24 |
Member#: 2045
AKIC
Gear and e-brake don't matter. I'll see you Friday. I'm real curious now. You won't catch me between 12:30 and 2:00, that's my lunch.
Jake |
#25 |
Member#: 82314
AKIC
Alrighty, next Friday it is. I'll probably be by after 2:00, as well. In the mean time, I'll keep trying to get it into programming mode.
| Thread Tools | |
| Display Modes | |
| for the people who work at autoshops. | fantabulous | Mid Atlantic Impreza Club -- MAIC | 20 | 08-07-2005 12:34 AM |
| Help from people who work at dealerships | jetfan2207 | General Community | 27 | 10-07-2004 04:17 PM |
| Anyone who works at a Subaru dealership, I need some help | Pipercub | Mid Atlantic Impreza Club -- MAIC | 0 | 10-01-2004 01:26 PM |
| A Little Help From The Guys Who Know... | REX8 | Car Audio, Video & Security | 6 | 07-29-2004 11:27 PM |
| Okay - anyone know the screenname of the guy who works at Oilspot in Reston? | blaster88 | Mid Atlantic Impreza Club -- MAIC | 13 | 03-02-2004 09:57 PM |
