Old 07-10-2007, 07:52 PM   #1
SINthetic
Member#: 53775
03 WRX
Default Meth or Alcohol Injection Vs Racegas C16
I have been reading up on Meth/Alcohol Injection but have not found any answers if it is better power wise over straight C16 racegas. Which will make more power? Im not talking around time, im asking at the track which will perform better.
I understand the benefits of the injection by cooling down the intake charge and you can run more boost and timing. But out performance race gas.
And what about Meth or Alky with race gas it that the best of both worlds.
Has anyone done both setups.
Thanks.
SINthetic is offline   Reply With Quote
Old 07-10-2007, 10:08 PM   #2
mxboy15u
Member#: 105115
Come saturday, I will have comparison results for you
mxboy15u is offline   Reply With Quote
Old 07-11-2007, 12:41 AM   #3
flycaster
Member#: 60142
2011 WRX
Grey
What base gas are you starting with in the tank? That'll make a huge difference. 91 Pump? 100 oct? What?
flycaster is offline   Reply With Quote
Old 07-11-2007, 09:00 AM   #4
SINthetic
Member#: 53775
03 WRX
93 oct pump gas with meth or alky vs 116 race gas.
Old 07-11-2007, 09:50 AM   #5
kn0bby8
Member#: 97644
2006 WRX
Don't go quoting me on this but C16 is better.
93 with a mixture of 50/50 meth distilled only raises the octaine to about 103.
Don't remember where I got that from...so take it as you will.
kn0bby8 is offline   Reply With Quote
Old 07-11-2007, 01:52 PM   #6
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
you dont need c16, its leaded and ruin your o2 sensor fast
something like 110 would work fine and it will more than likely be unleaded which will save your o2 sensor.
I dont think alky/meth will out perform race gas but it does have its benifiets like you mentioned. Race gas is just alot more expensive and not easy to get a hold of at certain times when you need it.
i have a race gas map right now, and i plan to do meth/alky on top of race gas.
TopEndPull is offline   Reply With Quote
Old 07-11-2007, 03:23 PM   #7
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Pure Methanol is 100 octane (Ron + Mon/2).
A 50/50 mix of methanol + distilled water, sprayed at a 1:5 mix:fuel ratio (20% spray) with 93 octane as the fuel is FAR from 103 octane.
jblaine is offline   Reply With Quote
Old 07-11-2007, 07:25 PM   #8
SINthetic
Member#: 53775
03 WRX
I am well aware about leaded gas on a O2 sensor. I just wanted to know which will out perform the other. I know meth/alky will be cheaper in the long run but im looking for every hp i can find.
Old 07-11-2007, 10:16 PM   #9
Ultimate Collision Center
Vendor
Member#: 69072
you will make slightly more power on c16 but on my evo it never netted me a better trap speed or et when comparing the two...
Ultimate Collision Center is offline   Reply With Quote
SMC Meth/Alcohol Injection Kit WRX/STi impreza_punk Engine/Power/Exhaust 8 09-12-2007 12:03 PM
water meth injection vs new fmic kit acidrain088 Factory 2.0L Turbo Powertrain 6 12-13-2006 02:07 PM
water or alcohol injection, which one makes more power? Aquamist Water/Methanol Injection, Nitrous & Intercooler Cooling 12 10-18-2006 05:10 PM
About to get the SMC Injection Kit- Run with Meth or Alcohol? The_Urban_Knight Water/Methanol Injection, Nitrous & Intercooler Cooling 15 10-01-2006 02:12 PM
Cryo or Alcohol/Meth injection gg64ss Water/Methanol Injection, Nitrous & Intercooler Cooling 2 09-29-2006 07:16 PM
Message Board Statistics All times are GMT -4. The time now is 10:27 AM.
