#1 |
Member#: 71240
SWIC
Vehicle:2002 WRX Cobb Stg II Aspen White w/Yakima Rack |
As the the title of the thread says, my headlights flicker when I engage the turn signals. I've found that there is a little bit of play in the switch used to turn on the headlights so when I use my turn signals, the headlight switch jiggles and the lights flicker. When the lights flicker I notice a clicking from the glove box area too.
This is on a 2002 WRX where the headlight switch is a knob at the end of the turn signal arm that you twist and there is just a bit of play when the lights are on. I can also get the lights to flicker if I turn on the lights and then rotate the switch that little extra movement that the switch has. Sorry for the long story...I hope this is kind of clear. Anyone have this experience or know how to fix it? Would I just need to replace the turn signal arm or does this sound like an electrical problem? Thanks for any help.
#2 |
Member#: 127878
Vehicle:2004 Impreza 2.5TS 2004 Outback sedan H6 |
It's possible that it's an electrical problem, although it's unlikely. You should be able to simply replace the turn signal/headlight multi-function switch and be good to go.
Your best bet would be to take it to a dealer and have them diagnose it for you. Just because you bring your car there doesn't mean that they have to do the repair work. It's actually not that difficult a job to do yourself. |
#3 |
Member#: 99591
RMIC
Vehicle:2003 18g w/38EWG PSM(siver) |
Mine does the same thing but i have no idea what it is. Did you figure it out?
MIke |
#4 |
Member#: 87133
SCIC
Vehicle:2005 M7760/V-Mount Crystal Grey Metallic |
I agree with silver2004impreza I used to work at a dealership and the multi-function switches would always go out just from age and use. good luck
#5 |
Member#: 71240
SWIC
I haven't figured it out yet but then again I haven't had time. I'm guessing I'll need a new turn signal "wand" with a new light switch.
#6 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
It's the "combination switch".
#7 |
Member#: 154119
South East
Vehicle:2002 WRX Wagon WR Blue/mud |
My '02 Wagon was doing the same thing. It got to the point where they flickered when I indicated a turn, and everytime I would tap the brakes. Eventually, after trying everything else, I replaced the connections on the battery. I replaced them with brass connections for marine use, and the problem was solved. Looking at the stock connections, they were pretty corroded and there's only a small bit that actually touches the battery anyway. Try that and see if it helps.
| Thread Tools | |
| Display Modes | |
| headlight flicker when turn signal used | STIckySTIfee | Electrical & Lighting | 13 | 07-10-2010 02:04 PM |
| Headlights cut out when turn signal engaged..? | STIckySTIfee | Electrical & Lighting | 2 | 08-17-2009 11:47 PM |
| Headlights flickering when using turn signals | Honest Bob | Electrical & Lighting | 0 | 04-05-2009 08:10 PM |
| lights flicker with turn signals | JBravo920 | Electrical & Lighting | 18 | 03-27-2006 01:41 PM |
| needle on gauge moves when turn signal is on | Rickyh | Electrical & Lighting | 2 | 11-23-2003 11:22 PM |
