Old 04-16-2010, 06:01 PM   #276
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
Originally Posted by dd9ucx View Post
quote:
What do you mean by Using any 02-07 Impreza struts result in certain issues that can technically be corrected.
Ive been searching on here all day and have come to the conclusion they will bolt straight onto the front, but I will need to modify the rear top mounts to get it to fit. Will I need to modify they hub mountings at all?
Looking at putting 2005 WRX complete strut/spring top hat take offs on my 98 Forester.
Thanks, Jason
98-08 foresters can only use 04 and earlier impreza struts because in 2005 impreza's changed to a 5x114.3 bolt pattern from 5x100. foresters did not change their 5x100 bolt pattern until 2009.
Matt515 is offline   Reply With Quote
Old 04-17-2010, 12:09 AM   #277
JM530
Member#: 69212
'11 A3 Quattro K04
DSG Lava Grey
On 08+ STI's, what is the most negative front camber you can run with stock tophats up front on co's? I have KW V3's coming, and honestly am fine with -1.5-2 camber up front, and avoid spending the extra $$ if I don't need to buy camber plates. Thoughts from any 08+ owners or those that may know?
JM530 is offline   Reply With Quote
Old 04-17-2010, 10:43 AM   #278
dd9ucx
Member#: 173205
Hey Matt thanks for the reply, is that just the Impreza STI that changed bolt pattern? It looks like the Impreza WRX kept 5x100 right up until at least 2008 according to my searching.
I hope they fit as I've just paid for them!!! ARRRGH
2008 new Tire Pressure Monitoring on all models
STI - 245/40R18 93W WRX, Premium - 205/50 R 17 88V P.C.D 114.3 (4.50)
Outback Sport - 205/50 R 17 88V P.C.D 114.3 (4.50)
2.5i- P205/55 R16 89V STI -18x81/2 j, offset 55 (2.17). P.C.D 114.3 (4.50)
WRX, Premium - 17x7jj, offset 55 (2.17), P.C.D 100 (3.94), alloy
Outback Sport - 17x7jj, offset 55 (2.17), P.C.D 100 (3.94), alloy
2.5i- 16x6.5jj, offset 55 (2.17), P.C.D 100 (3.94), alloy
2007 WRX, TR, Limited- 215/45 17 91W
STI, STI Limited- 225/45 R17 90W summer tire P.C.D 114.3 (4.50)
2.5i, Outback Sport- P205/55 R16 89V WRX, Tr, Ltd- 17x7jj, offset 55., alloy
STI, Ltd- 17x8jj, offset 53
2.5i, Outback Spt- 16x6jj, offset 55, alloy
2006 STi 225/45R17 90W summer tire 17x8jj offset 53, bolt pattern 5-114
2006 WRX, TR, Limited 215/45R17 91W 17x7jj offset 55, bolt pattern 5-100
2006 2.5i, Outback P205/55R16 89V 16x6.5jj offset 55, bolt pattern 5-100
2005 STi 225/45R17 Bridgestone Potenza RE070 Summer/Directional 8.0jj alloy, offset 53 (2.09), bolt pattern 5-114
2005-2002 WRX 205/55R16 89V Potenza RE92 M+S 6.5jj alloy, offset 55 (2.17), bolt pattern 5-100
2005-2002 Outback Sport 205/55R16 89V M+S 6.6jj alloy, offset 55 (2.17), bolt pattern 5-100
2005 RS wagon, sedan 205/55R16 M+S 6.5jj alloy, offset 55 (2.17)
2004 STi P225/45R17 Bridgestone Potenza RE070 Summer/Directional 7.5jj alloy, offset 53mm, bolt pattern 5-100
2004-2002 TS wagon P195/60R1587H M+S 6.0jj
2004-2002 RS sedan P205/55R16 87H M+S 6.5jj alloy, offset 53 (2.09)
2001-1997 Outback Sport P206/60R15 90S M+S 6.0jj alloy
2001-1998 2.5L RS P205/55R16 89V M+S 7jj alloy, offset 53 (2.09), bolt pattern 5-100
Jason
dd9ucx is offline   Reply With Quote
Old 04-17-2010, 11:16 AM   #279
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
Jason
Maybe your right, but i researched and went for the STI's because i wanted a little added performance. i hope you aren't disappointed with your choice and that everything works out!
Old 04-22-2010, 12:54 PM   #280
dd9ucx
Member#: 173205
Default They fit
Shocks arrived today, they came off a 2005 WRX Wagon from the breakers. They are of the inverted type compared to the right way up on the old Forester Shocks. Took about 20 minutes to do each wheel, changed ou the old Forester stuff and the WRX shocks were a perfect fit.
BEFORE
http://sphotos.ak.fbcdn.net/hphotos-..._6056871_n.jpg
AFTER
http://sphotos.ak.fbcdn.net/hphotos-..._7749132_n.jpg
Old 04-22-2010, 09:34 PM   #281
Cervantes
Member#: 219252
2000 STi w/S203 swap
did a search and couldn't find anything. i'm trying to find out whether or not STi Springs and KYG Struts will fit on a 2000 Subary Legacy Blitzen. I found some on sale for $150 and figured i would ask if it was worth it. i'm pretty much new, and limited on my knowledge. any help would be greatly appreciated.
Cervantes is offline   Reply With Quote
Old 05-07-2010, 07:50 AM   #282
scozmin
Member#: 214143
can you please tell me if kyb agx struts ( 733010, 733011, 734006 and 734007) will fit impreza 1999, wagon, N/A
from what i understand from the first posts all 93-01 struts will fit any 93-01 impreza, but i want to make sure.
I tried to check with kyb techsupport and they told me they can't find a match betwen my oem struts part no, and agx struts....
On Kyb catalog i can find AGX for impreza turbo, but they say nothing about non-turbo imprezas;
I'm almost certain agx will fit my car but i would like a confirmation from you guys.
thanks
scozmin is offline   Reply With Quote
Old 06-05-2010, 01:00 AM   #283
Tempest5UB4RU
Member#: 248595
2003 Outback
Green
Thank you so much for this useful tool! I have been looking for suspension upgrades for my Subaru for a while now, and this makes it a whole lot easier to find what I need.
Tempest5UB4RU is offline   Reply With Quote
Old 07-07-2010, 09:45 AM   #284
trdeli4
Member#: 250067
Default i have a question about lowering springs..
the stock 06 sti struts are good. the cobb lowering springs are a replacement for the factory springs. have you heard anything about cobb lowering springs?
Originally Posted by RaceComp Engineering View Post
2005-2007 Impreza STi
Same as 2004 STi, except for:
Struts
The only struts that will fit are Ohlins Fixed Perch Struts and STi Version 9 OEM or STi Version 9 Arai Pink Struts.
Coilovers
Only coilovers specific to 05+ STi will fit.
Strut Bars
Front strut bars for 04-05 STi fit the 06-07 STi but with some difficulty regarding the AC lines. There are a few 06-07 STi specific front strut bars.
All rear strut bars from any 02-07 Impreza fit.
Other
Only Lateral Links specific to 05+ STi will fit.
2005-2007 Impreza STi and 2006 Impreza use the same steering rack bushings, all other applications will not fit.
trdeli4 is offline   Reply With Quote
Old 07-11-2010, 10:59 AM   #285
RickRocks
Member#: 207327
2003 WRX wagon
Midnight Black Pearl
how about 04 STI struts onto a 98 OBS?
RickRocks is offline   Reply With Quote
Old 09-18-2010, 01:49 AM   #286
greddy90
Member#: 147065
Hey, hard to search through thread so sorry if it has been covered. But it says 08+ sti shocks cannot fit up front. Does that mean they will work on the rear?
I have a set of Blitz ZR coilovers for the STI but need something for my 08+ wrx...
Anyone know how to modify it to fit?
greddy90 is offline   Reply With Quote
Old 09-19-2010, 07:42 PM   #287
enigmaxxxx
Member#: 254236
'06 WRB STI
'11 Equinox
will 06 wrx s tein springs work for 06 sti? sorry for the noob question. I looked up the part numbers for them and the 06 sti had a part number of sks66-aub00, and a wrx with a part number of sks60-aub00. Would there be any effects as far as drivibility? Thanks.
enigmaxxxx is offline   Reply With Quote
Old 09-25-2010, 11:39 AM   #288
thatkhmer
Member#: 217500
2009 SWP Wrx
2010 WW Evo X
yes they will bolt right up to the rear,
to mate it up to the front you must either get an sti knuckle, get a new lower bracket for your coilover or chop everything up and do some welding. which isn't reccommended at all
thatkhmer is offline   Reply With Quote
Old 09-25-2010, 02:48 PM   #289
greddy90
Member#: 147065
and will the sti knuckles bolt rigth up?
Old 10-22-2010, 02:55 PM   #290
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
someday soon i will update this stuff and try and get more 3g WRX stuff in there.
RaceComp Engineering is offline   Reply With Quote
Old 10-28-2010, 11:48 AM   #291
hostile silence
Member#: 163878
05 STi & CBR1000rr
OBP & Blue and Yellow
so this guy says he had these sti pink struts on his 03 wagon, but goes on to say that these struts will fit with my 05 sti. i dont believe they will, but its worth a shot. here is his ad. let me know if you know, thanks!
http://pittsburgh.craigslist.org/pts/2029825800.html
hostile silence is offline   Reply With Quote
Old 10-29-2010, 10:46 AM   #292
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
anything that fit an 03 wagon won't fit an 05 sti (in the front).
AndyRoo is offline   Reply With Quote
Old 10-29-2010, 11:17 AM   #293
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I'm pretty sure that no, you'll also need to swap your front axles for sti axles because the splines in the sti hubs are different. This then creates a problem at the other end of the axle as some 5-speeds have stubs and some have pockets. Remember, also, that the axles from different years are different lengths.
For me, I'm just hoping that I can put GR front sti axles onto a 2011 wrx transmission. Then I can move my GR sti hubs and OEM shocks over to a new 2011 wrx and install MSI racing hubs on my sti.
Frank
Frank A is offline   Reply With Quote
Old 10-29-2010, 02:29 PM   #294
hostile silence
Member#: 163878
05 STi & CBR1000rr
thanks...
Old 11-08-2010, 01:46 PM   #295
Jimbo2NR
Member#: 259095
Excellent write up!
I have on question though, will an energy suspension master bushing kit for Impreza/Forester 2003-2004 work for a 1999 2.5RS/GC8 (JDM WRX)?
Part #1918101
I haven't read through all 12 pages, just the section that applies to my car. Thanks for any help offered
Jimbo2NR is offline   Reply With Quote
Old 11-08-2010, 03:18 PM   #296
imperium
Member#: 234738
2000 Impreza wagon
Red
nvm delete
imperium is offline   Reply With Quote
Old 11-29-2010, 07:47 PM   #297
ttoversteer
Member#: 465
2012 GTI
Gray
2008+ Impreza 2.5i, WRX, and Outback Sport
Struts + Shocks
Only 2008+ Impreza specific struts and shocks will fit.
Springs
Only 2008 Impreza specific springs will fit.
I've searched and searched, but haven't had luck finding the answer to my question. I think THIS post quoted above does answer the question. Here's my question anyway:
I have a 2011 Impreza 2.5i wagon. She is soft and I would like to put WRX shocks/springs on the car to firm her up a bit. It looks like the 2010 WRX shocks/springs should fit; the only difference that I can find is a wider rear track on the 2010 WRX vs my 2011 "RS."
Will the 2010 WRX suspension fit? I suspect the wider rear track of the 2010 means slightly different suspension mount locations on the swingarms vs the 2011. If not, I could be in business!
Thanks for the help.
ttoversteer is offline   Reply With Quote
Old 11-29-2010, 10:33 PM   #298
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The 2010 WRX suspension is also SOFTEE FREEZE left out in the sun ! Forget it, it wont be an improvement over your 2.5I. GTWORX has a sport shock/spring combo tha t fits on your car fine and would be a HUGE improvement over even the STI shocks.
Myles
Old 02-08-2011, 03:12 AM   #299
greddy90
Member#: 147065
Wanted to ask what the differences between the GD STI struts are with the GR struts?
Old 02-08-2011, 01:19 PM   #300
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
GD has strut front and rear with a motion ratio close to 1/1
GR has strut front and shock rear(multilink rear) with close to 1/1 front but .85 ish rear( dont quote me).
GR front is shorter by .50 inch and has close to same droop travel as GDk but less bump travel.
GR rear is shocks and have super limited travel but has less distance to work in and needs less to work in due to the multilink rear design.
Simply put.....GR's turn in BETTER than the even older GC chassis !
Avg GD front caster on an 04 STI with ALL the mods one cad do is 5.5-6.0 MAXED.
STOCK.. GR front caster is 6.0 ! So camber plates, ALK and a few tricks and you can yawn at 7.0+ caster on the 08+ STI(WRX).
The single group of buyers who got screwed werew 07 STI owners with some reported as low as 3.0 front caster!
I know you didnt ask for all of that but there it is.
Mw
GTWORX.com is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
