Old 02-08-2011, 07:37 PM   #301
greddy90
Member#: 147065
Hmm thanks a lot. But in terms of the macpherson design body that mounts to the knuckle, is it much different?
And you said .5 in shorter, do you know the length of the GR or GD strut?
greddy90 is offline   Reply With Quote
Old 02-08-2011, 09:15 PM   #302
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
if you compare the 05-07 GD to the 08+ GR, no different.
GR is shorter.
Mw
GTWORX.com is offline   Reply With Quote
Old 02-08-2011, 09:22 PM   #303
greddy90
Member#: 147065
GR is shorter.
Mw
Do you know how long it should be? I have a unlabeled KW V3 shock and not sure if it is for GR or GD
Old 02-08-2011, 10:49 PM   #304
GTWORX.com
Member#: 97303
Gray and Black
pm me the length from bottom of shock to top of extended unassembled front shock send me a picture so i can see how it was measured.
mw
Old 02-09-2011, 05:35 PM   #305
newscoobboob
Member#: 119956
2006 wrx waggin
Lexus White w/ Pink pearl
Whats a good rear sway bar for a 2006 wrx wagon?
newscoobboob is offline   Reply With Quote
Old 02-11-2011, 02:52 PM   #306
greddy90
Member#: 147065
mw
PM sent thanks
Old 02-11-2011, 03:14 PM   #307
d3v0
Member#: 225692
2015 WRX
Perhaps you want a front sway bar, not a rear:
http://www.iwsti.com/forums/gd-suspe...ngs-clint.html
^ I am going to run an RCE front sway. Whiteline also comes highly recommended. both are adjustable.
You'll want endlinks too, I recommend the simple design of the Kartboy.
d3v0 is offline   Reply With Quote
Old 02-12-2011, 06:03 PM   #308
lacdaddy
Member#: 229617
2002 WRX, 1998 OBS
its not clear or not, but can i use gc springs and struts on a gd?
lacdaddy is offline   Reply With Quote
Old 02-15-2011, 04:32 AM   #309
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
Has anyone found an exception to the fender brace rule for 06-07 2.5i/RS? I've skimed and seen some NA guys stating they have aftermarket braces installed. If I can confirm or deny they'll work with my 2.5i without pulling a fender, that would be awesome.
AWDmonk is offline   Reply With Quote
Old 02-15-2011, 07:02 PM   #310
Subiracer06
Member#: 182487
04 STI
JBP
ok guys... i need to know if the 2008+ wrx hatch sway bars will fit the 2011 2.5i premium. i have talked to several different shops and they give me one of those "oh let me check ill get back to you" its been 2 months and im sick of waiting.
perrin makes a kit but they are too expensive and i hate perrin. and another company makes a set (cant think of the name at the moment) but the diameter is too small (22mm) front and rear
please help me out with suggestions. i cant let my little bro drive a car with no rear sway bar for much longer haha.
Subiracer06 is offline   Reply With Quote
Old 02-15-2011, 07:33 PM   #311
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Our 08+ WRX front bar WONT fit the 2.5 NA car. The rear fits but you need to get brackets from the dealer if your car doesnt have a rear sway on it. You also need links for the rear too.
Correction: front "fits" but can make contact with the exhaust manifold.
Myles
RaceComp Engineering is online now   Reply With Quote
Old 02-15-2011, 08:28 PM   #312
Subiracer06
Member#: 182487
04 STI
JBP
Myles
one shop i went to said that if i used the WRX rear bar that i would need to get the WRX lateral links... is this true?
Old 02-15-2011, 08:38 PM   #313
d3v0
Member#: 225692
2015 WRX
I think that's what Myles said. Re-read the third sentence of the first paragraph.
Old 02-15-2011, 09:35 PM   #314
GTWORX.com
Member#: 97303
Gray and Black
not lateral links but sway bar links. The fact that the shop said lateral links tells us that he was thinking about the OLDER GD chassis which requires a lateral link change to be able to use the STI rear sway bar.
fail soup
Old 02-16-2011, 02:41 PM   #315
Subiracer06
Member#: 182487
04 STI
JBP
haha ok got it. thanks for the feed back
Old 03-11-2011, 12:05 PM   #316
chadr111
Member#: 37718
02 TS, (too Slow)
black
You should not have to pull the fender to find out. Grab a flashlight and maybe a rag, go open a front door and look inside the fender between and just in front of the hinges. On my NA 02 the threaded holes are there but covered with some thick body colored stickers.
chadr111 is offline   Reply With Quote
Old 03-17-2011, 04:25 PM   #317
CGkidd
Member#: 259364
2008 impreza
If I missed the post in here sorry. I have a 08 NA impreza hatch and am looking at helping the soft ride by updating the struts and springs. Will the struts and springs from a 2011 WRX work?
CGkidd is offline   Reply With Quote
Old 03-17-2011, 05:43 PM   #318
evilWagon
Member#: 128739
07 2.5i SE Wagon
Maybe I'm missing what it is you're concerned about? Will they fit, yes. Will you have to pull a fender, maybe not with a sedan, you'll at least have to loosen the top fender screws if you have a wagon. I'm doing mine this weekend on an 07 2.5i wagon.
evilWagon is offline   Reply With Quote
Old 03-17-2011, 09:23 PM   #319
Chader
Member#: 152298
2011 WRX Premium 5dr
IIRC, the answer is mixed. They will fit, but the camber will not be desirable. The lower strut mount is longer on the 2011's to accommodate the extended track. If you use them, it will give lower camber (more towards positive which is not desired).
This is based on I read with respect to the GTWorx/Bilstein struts that were designed around the 08-10 strut design. Those yield extra negative camber when used on a 2011 which is generally a good thing for handling to reduce understeer.
Chader is offline   Reply With Quote
Old 03-28-2011, 01:29 PM   #320
SubieKid07
Member#: 197679
2001 Impreza RS
Silverthorn
this may have already been answered on a different thread, but will KYB AGX Adjustable Gas Shocks for an '02-'03 WRX fit on an '01 RS? my brother had originally got them but never got around to putting them on his car, so he gave them to me.
SubieKid07 is offline   Reply With Quote
Old 04-02-2011, 11:47 AM   #321
GTX666
Member#: 183128
2002 wrx
wrb
I need to know if 08 sti springs will fit on a 2011 wrx?
GTX666 is offline   Reply With Quote
Old 04-02-2011, 03:54 PM   #322
GTWORX.com
Member#: 97303
Gray and Black
yes they will "fit" but the front will be loose between the perches at full droop.
Its also not needed as the 2011 rates are the same as the 2011 WRx and 2009/2010 WRX at 224/185.
Mw.
Old 04-02-2011, 04:27 PM   #323
GTX666
Member#: 183128
2002 wrx
wrb
When I go on the eibach website, the part number for the wrx 2011 and sti 08 is the same???
Old 04-02-2011, 05:11 PM   #324
robertbt7
Member#: 273661
2017 WRX
I fount that a front sway bar I ordered for a 2002 legacy GT fit my new 2011 2.5i with no problem. Subaru must have reused some older molds rather than reworking everything.
robertbt7 is offline   Reply With Quote
Old 04-11-2011, 04:54 PM   #325
Combat Chuck
Member#: 116567
2000 Impreza 2.5 RS
Blue Ridge Pearl
Thanks a lot for this thread, it's incredibly useful!
I'm currently investigating running '04 STI struts with GC springs and top hats on my 2000 GC RS. I keep hearing that it'll bolt up, but here I see I'd run into geometry issues. What sort of issues would I be running into, and what sort of workarounds are there?
Combat Chuck is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
