Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 04-11-2011, 05:04 PM   #326
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Originally Posted by Combat Chuck View Post
Thanks a lot for this thread, it's incredibly useful!
I'm currently investigating running '04 STI struts with GC springs and top hats on my 2000 GC RS. I keep hearing that it'll bolt up, but here I see I'd run into geometry issues. What sort of issues would I be running into, and what sort of workarounds are there?
I don't think the geometry will be that bad with that setup. The rear spring perch sits up higher on the '04 STI strut than on a GC strut, so the rear end of the car is going to sit up 1/2" higher than normal...
Jard is offline   Reply With Quote
Old 04-12-2011, 12:41 AM   #327
SubieKid07
Member#: 197679
2001 Impreza RS
Silverthorn
would that be the same with putting '03 WRX struts on a GC?
SubieKid07 is offline   Reply With Quote
Old 04-12-2011, 08:36 AM   #328
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Yes, it's a GD strut thing in general.
Old 04-12-2011, 11:39 AM   #329
Combat Chuck
Member#: 116567
2000 Impreza 2.5 RS
Blue Ridge Pearl
Much appreciated, thanks!
Combat Chuck is offline   Reply With Quote
Old 04-12-2011, 02:09 PM   #330
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I don't see anyone asking, but fwiw the 2011 STI LCA's fit fine on a 2011 WRX except that I seem to have picked up a little negative camber. With the bolts at max negative (in), I got -1.7 with the stock struts. Castor was 5.8/5.9. This is without changing to 08-10 struts. If I did that, I could probably hit -2.5 with just the stock camber bolts!
To make the LCA swap you do need to buy the 2011 STI rear bolts to replace the body-mounted studs that the 2011 WRX shares with the older 08-10 WRX's and STI's.
Also, the RCE swaybars fit perfectly on a 2011 WRX.
Frank
Frank A is offline   Reply With Quote
Old 04-16-2011, 01:55 PM   #331
qwk300
Member#: 263983
2015 wrx
Diamond Black
anyone know what other front sways i can run on my 99 rs, i have a wrx 20mm rear but cant find any info on what will fit the front. thanks for any help!
qwk300 is offline   Reply With Quote
Old 04-16-2011, 06:54 PM   #332
danparm302
Member#: 257048
2010 Impreza 2.5i
dark grey
is it possible to modify 2010 oem sti struts/springs to fit a 2010 2.5i? if so how involved would it be?
is there any big difference between the 2010 wrx struts/springs to the 2010 sti?
danparm302 is offline   Reply With Quote
Old 05-08-2011, 09:07 PM   #333
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
how about
2001 GC chassis
gc control arms
07 sti x member
will 07 sti front sway bar work with the gc kartboy endlinks?
topguneagle1 is offline   Reply With Quote
Old 05-09-2011, 10:56 AM   #334
Rummy
Member#: 38248
2007 LGT
No legacy love in this thread?
Rummy is offline   Reply With Quote
Old 05-09-2011, 01:16 PM   #335
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Sure there is.
My old 06' Spec-B with JDM front and rear bumper/spoiler, Bilstein "SPORT" shocks, JDM Pinks, Whiteline sways, ALK, Group-n spec rear bushings, Endless SSM pads, lines, Stage 2 Cobb, etc.
RaceComp Engineering is offline   Reply With Quote
Old 05-31-2011, 12:31 AM   #336
rugbugboy
Member#: 251136
2008 FSXT
Default RE: 02 TS Wagon
I've scanned the stickies for hours, but can't find these answers:
Is the 02 TS Wagon front swaybar 20mm like the 02 WRX wagon?
Is there an upgraded swaybar available for it?
If not, and I'm stuck with the stock front, what would be the recommendation for the size/stiffness of an upgraded rear swaybar?
And last, can I run stock sti strut mounts in front and 03 group N strut mounts in the back? Should I get stock 03 WRX rear strut mounts instead?
Thanks!
rugbugboy is offline   Reply With Quote
Old 05-31-2011, 08:56 AM   #337
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I'm pretty sure the TS wagon and WRX wagon shared the same front swaybar lengths. I had a Hotchkis sedan bar on my '02 wagon for quite a while. I had Perrin endlinks and they were at a bit of an angle, but they never wore out. You can also find wagon-specific front bars, possibly from Whiteline.
Any rear wrx swaybar will work on your wagon. You can pick the slightly thicker one from a WRX wagon, or the somewhat thicker one from a sedan (or sti) or any aftermarket bar. I would at least get a sedan bar, and if you are upgrading the front bar then you will definitely want at least a 20 mm rear aftermarket bar. A 20+ mm rear bar will make turn-in feel reasonably quick and you should be able to rotate the car at the limit. If the rear bar is ~2 mm thinner than the front, I find this to make for a fairly balanced car, especially if you upgrade spring rates later. It won't snap around on a rain-soaked exit ramp, but you can make it slide if you want. Some prefer equal front and rear diameters for easier rotation.
Front strut mounts are the same for all GD's. I think you can run 03 grp N mounts i the rear. Depending on the spring/shock setup you have, you may get the saggy rear-end effect.
Frank
Old 05-31-2011, 01:00 PM   #338
rugbugboy
Member#: 251136
2008 FSXT
Thanks Frank, but I'm still confused. I read somewhere that the stock front swaybar was 20mm, but they may have been talking about the WRX wagon only. I also read that front swaybars designed for the WRX wagon won't clear the NA header setup (or something like that). So I'm looking for a definitive answer for the front. If the TS stock front swaybar is 20mm I would leave it alone, but then I'm not sure what to do about the rear. Or if the Whiteline wagon-specific front swaybar would fit the TS I would go to the 22mm fixed bar, and then get the 22mm adjustable rear bar and try it at the lightest and medium settings to find a best feel. Everything kinda hinges on the stock front spec and the availability of aftermarket bars that fit the 02 NA wagons.
Old 05-31-2011, 01:13 PM   #339
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
afaik all the 02 Imprezas had a 20mm front bar, that's what's in the FSM anyhow
HOWEVER same DIAMETER does not mean the are the same BAR - length is only one issue, there are also header clearance issues with the shape of the turbo bars on N/A cars
so either stick with what you've got (should be 20mm) or find an N/A specific aftermarket bar - ideally an N/A wagon (TS/OBS) but you may have a hard time finding that, in which case just go for a NA sedan (RS/2.5i) bar and live with the endlink angle
UkNuck is offline   Reply With Quote
Old 05-31-2011, 03:35 PM   #340
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
hmm, well the OEM bars were different part numbers:
'02 WRX wagon: 20401FE010
'02 TS wagon: 20401FE020
And they are the same diameter because all '02 cars used the same bushing part #, so you may have a conflict with the header. I would check Whiteline's site for compatibility- they are usually reasonably sympathetic to covering the full model line with their compatibility information.
Old 05-31-2011, 09:16 PM   #341
chadr111
Member#: 37718
02 TS, (too Slow)
black
I'm using a 22 mil IPD front bar
http://www.rallitek.com/RalliTEK-Ant...93-2007/p-4382
I know Whiteline has at least one option as well.
Also, pretty sure the sti rear bar DOES NOT work with any other Imprezas, only the Forester.
edit: I found this saved in my subscriptions.
http://forums.nasioc.com/forums/show...+front+sway+na
Post 9 has some whiteline part numbers.
chadr111 is offline   Reply With Quote
Old 06-08-2011, 12:18 PM   #342
Lifeisgood
Member#: 162117
2000 2.5 RS Sedan
Silverthorn Metallic
I read that GD wagon struts would make the rear sit a bit higher when installed on a GC chassis, however the '02 WRX wagon struts I just installed on my '00 RS Sedan sit about a half in lower in the rear... I'm going to be installing some saggy butt spacers and maybe extended studs to level it out here shortly. Going from coilovers, I'd say the ride quality is pretty nice for a daily driver.
Lifeisgood is offline   Reply With Quote
Old 06-08-2011, 12:40 PM   #343
n2oiroc
Member#: 141952
15 legacy 16 wrx
Will 2011 sti springs work well in a 2011 wrx or will they be loose in the front perches like previous years?
n2oiroc is offline   Reply With Quote
Old 06-08-2011, 09:48 PM   #344
jdmoto
Member#: 275325
2006 Fitted Wagon
SGM
I read somewhere that a 06 wagon has the same trailing arm as sedan. Is this true? If so can i install the STI Pink trailing arm? I ask because im getting mixed answers on different threads.
Thanks in advance.
jdmoto is offline   Reply With Quote
Old 06-09-2011, 01:17 AM   #345
burnyou2
Member#: 251467
2002 2.5RS
Blue Ridge Pearl
Will MY00 struts fit a MY02 sedan? I have the MY02 top hats if thats the only issue
burnyou2 is offline   Reply With Quote
Old 06-09-2011, 01:57 AM   #346
vicious_fishes
Member#: 158864
2003 SOHC destroker
i know i can rip GD springs/struts out and put them on my GC by simply drilling an extra couple holes, but this will raise the car a little.
my question: can i do this with GR struts/springs which are a little shorter?
vicious_fishes is offline   Reply With Quote
Old 06-12-2011, 02:52 AM   #347
vicious_fishes
Member#: 158864
2003 SOHC destroker
anyone?
Old 06-24-2011, 02:44 PM   #348
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
can anyone point me in the direction of some information on exactly what is different between the 5X100 knuckles and the 5X114 knuckles?
i searched through the thread a bit and all that is said is that it wont fit because they are different. i am just wondering what is different.
thanks.
edit:
ok, this is the best i could find using knuckle as a term:
Originally Posted by UkNuck View Post
the front clevis spacing/bolt pattern changed when they went to the 5x114.3 hubs - other Imprezas still use the 5x100 hubs/knuckles
so are the mounting brackets on the 05 struts too far apart or too close together to fit on a 5X100 knuckle?
are the holes even a little close to the 04 positions?
in other words can a 05 front sti strut be modified to fit on a 5X100 knuckle?
or will i die in a fire while in a school zone?
greg donovan is offline   Reply With Quote
Old 06-24-2011, 02:59 PM   #349
nhat
Member#: 140163
03 STi
hellaflunctional
the front 5x114.3 has a wider clevis as is the bolt spacing.
the 05-07 sti front struts can't be modified to fit an 04 knuckle, but the 05 sti knuckle can be modified to fit an 04 sti strut.
so, in other words, you'll die in a fire in a school zone.
Old 06-27-2011, 02:40 AM   #350
spare52
Member#: 285578
Silver/Carbon Fiber Hood
Thanks this hole thing helped a lot to
A newb like me
spare52 is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
