Old 06-27-2011, 03:54 AM   #351
vicious_fishes
Member#: 158864
2003 SOHC destroker
will a GR spring go on a GD strut if you get the GR top hat as well?
vicious_fishes is online now   Reply With Quote
Old 06-29-2011, 11:23 PM   #352
Alaskan Pipeline
Member#: 266313
06' hta 68 Saabaru
01' Outback 'low n slow'
My girlfriend has a 03 Forester and I'm trying to get coilovers. Do 02-07 wrx coilovers fit?
Thanks in advance
Alaskan Pipeline is offline   Reply With Quote
Old 07-22-2011, 04:10 AM   #353
alexh
Member#: 275728
Even though this is predominately an impreza forum, info on what struts and such fit what legacy's would be awesome
alexh is offline   Reply With Quote
Old 07-22-2011, 04:13 AM   #354
alexh
Member#: 275728
Also, why in the heck isn't this a sticky???
Old 07-22-2011, 10:40 AM   #355
nhat
Member#: 140163
03 STi
hellaflunctional
i'm going why no and asking why would you want to do that.
Thanks in advance
yes.
http://forums.nasioc.com/forums/showthread.php?t=171928
Old 08-10-2011, 08:11 PM   #356
Lifeisgood
Member#: 162117
2000 2.5 RS Sedan
Silverthorn Metallic
Question... I am in need of both left and right spring perches for my stock '00 2.5 RS rear struts. I have access to a stock set from a '99 Legacy wagon will they fit?
Thanks.
Lifeisgood is offline   Reply With Quote
Old 08-22-2011, 10:48 AM   #357
martin_montreal
Member#: 286526
GREAT JOB - UkNuck - TurbojonLS - sixtoo - stoney98 - Andrew!
If anyone could add data for the BAJAs - particularly 2004 to 2006, it would be Most appreciated, per my post here:
http://forums.nasioc.com/forums/show...4#post34908364
Thanks in advance. Having a heck of a time finding BAJA / 2006 / Turbo specific information etc. We need to make our own site for sharing.
martin_montreal is offline   Reply With Quote
Old 09-08-2011, 12:38 AM   #358
dr.skril
Member#: 293812
A coworker of mine has 07 sti suspension (stock struts+ h&r sport springs) complete with tophats, etc. Will this fit my 02 wrx? if not what would need to be modified to drop these in?
dr.skril is offline   Reply With Quote
Old 09-09-2011, 01:11 AM   #359
dr.skril
Member#: 293812
any help would be greatly appreciated as I dont want to purchase these if they will not fit. 2007 sti complete front & rear struts/springs with tophats on a 02 wrx?
Old 09-09-2011, 01:16 AM   #360
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
No they will not fit. The front struts will not bolt up. It's not easily modified to make it work either.
AndyRoo is offline   Reply With Quote
Old 09-09-2011, 11:03 AM   #361
nhat
Member#: 140163
03 STi
hellaflunctional
there are sticky threads you could/should have read where you'd have found your answer. searching would have answered your question too.
Old 09-09-2011, 11:07 AM   #362
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
The answer was also in this very thread in post #2:
http://forums.nasioc.com/forums/show...33&postcount=2
Struts
The following have a specific fitment for 02-03 WRX and RS, and all of the following spring and strut top fitment with these is the same as it is for the stock struts.
1. KYB AGX
2. KYB GR2
3. Koni Inserts (not a complete strut, see here for install http://forums.nasioc.com/forums/show....php?t=1219607)
4. Tokico HP
5. Tokico D-SPEC
6. STi/SPT Version 7
To use OEM or aftermarket struts that have a specific fitment for 04-07 RS, WRX, or 04 STi, you must use 04+ style rear strut tops and 04+ springs.
2005+ STi struts will not fit.
Wagons are different, see notes below.
Old 09-11-2011, 11:28 PM   #363
dr.skril
Member#: 293812
Thanks guys, I did read that just wanted to confirm
Old 09-14-2011, 12:49 PM   #364
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
Originally Posted by jonesboy View Post
'96-'99 Legacy (BD / BK / BG)
'02 WRX struts and springs will fit, so long as you buy '02 top hats for all four corners *and* '02 front spring perches. You don't need to buy separate rear spring perches, since they're built into the tophats. This probably means that '02 WRX coilovers will work without any kind of messing about (assuming that have built-in hats).
Remember! Wagon bits go with wagons, sedan bits go with sedans. Don't mix and match!
-Matt
I can get ahold of '06 top hats will they work on some '02 wrx springs that i have laying around for my '97 LGT. any info will help thank you..
EPlascencia60 is offline   Reply With Quote
Old 09-14-2011, 01:10 PM   #365
nhat
Member#: 140163
03 STi
hellaflunctional
no they won't. you need '02-03 rear tophats with '02-03 springs.
Old 09-25-2011, 11:35 PM   #366
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
I'll be using 05 oem 92x/wrx struts with 06 sit take off springs on my 02 wrx wagon. I realize I must use 04+ top hats from all I've read here. My question is related to the rear spring perches, can I use the 02-03 style rear spring perches with 04+ sit rear springs. Sorry if my question has been covered but searching here has not gotten me the answer. Thank you.
Side note, Saab 92x oe struts are said to be tuned with firmer damping.
Thanks again.
D-Rodman is offline   Reply With Quote
Old 09-26-2011, 12:29 AM   #367
vicious_fishes
Member#: 158864
2003 SOHC destroker
how on earth do those single attachment coilovers (the ones that attach only to the top hole in the knuckle) not rip the axle right out of the diff over a decent bump?
Old 09-26-2011, 09:10 AM   #368
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
the 04-07 rear tophats have a solid rubber upper perch built in - you don't need/reuse the castellated ring from the 02-03
UkNuck is offline   Reply With Quote
Old 09-26-2011, 11:40 AM   #369
D-Rodman
Member#: 110078
05 saabaru artc gr
Thank you very much for that, guess I would have realized that once I went to install but I'm in the part collection part of the project still. First time that was pointed out in all the hours of reading about the stuff. Thank you.
Old 10-18-2011, 08:12 PM   #370
heyyodho
Member#: 298145
2010 WRX
I have a 2010 WRX. If I can acquire struts/springs from a 2011 WRX will I be able to just swap them in without modifications and have the stock 2011 ride height.
From what I've researched, the answer is yes but there might be some details I could be missing.
heyyodho is offline   Reply With Quote
Old 10-18-2011, 10:30 PM   #371
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Well the issue will be that on the front struts the lower clevis tabs are 12.5mm LONGER which would push your wheels OUT by that much AND in the process reduce your maximum camber capability.
In reverse......someone ( me) who has a 2011 WRX who installs say GTWORX/Bilsteins which are made for the 08-2010 WRX..that person would GAIN maximum camber. So the range would be -1.0 minimum to -2.9 maximum. AWESOME for performance.
Back to you. Your maximum camber would likely be reduced to like -.8 and your minimum would go down to like +1.0 which you dont want AT ALL.
Hope that helps.
Myles
RaceComp Engineering is offline   Reply With Quote
Old 10-19-2011, 01:43 AM   #372
heyyodho
Member#: 298145
2010 WRX
Hope that helps.
Myles
That was a very helpful response. Thank you. I am brand new to Subarus and the contributors to this forum, such as yourself, are greatly appreciated.
Old 10-19-2011, 12:39 PM   #373
Vash337
Member#: 282107
2011 wrx sedan
obsidian black
Hope that helps.
Myles
exactly the info i needed
Vash337 is offline   Reply With Quote
Old 10-21-2011, 11:30 AM   #374
nuggetWRX
Member#: 177174
2007 Impreza 2.5i
Sport Wagon
RCE, thank you for posting this thread. I was worried that OEM STi springs may be too stiff for my 07 2.5i wagon, but with your info I'm more confident my 07 wagon will sit at the stock STi ride height.
...Now, to anyone with the answer, do I need 2004 STi OEM springs or should I get another year that may fit better?
Thanks again!
- Jesse
nuggetWRX is offline   Reply With Quote
Old 10-21-2011, 11:45 AM   #375
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
I think they're all the same.
You may also want some saggy butt shims if you're using them on a wagon.
- Andrew
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
