Old 10-22-2011, 12:48 PM   #376
ChopstickHero
Member#: 191525
2003 WRX Wagon
Working on next season's suspension setup for my 2003 WRX Wagon. It's a daily driver, no autocross, no track, spirited weekend driving:
Planning on buying:
KYB GR2 wagon specific struts
Swift Wagon springs
Group-N Top hats front and rear
Enkei RPF1 17x8 +45 with 225/45/17 Continental ExtremeContact DW
Already have:
Whiteline adjustable sway bars front and rear
Whiteline endlinks front and rear
Whiteline rear wagon strut bar
Now, my question is will I need saggy butt spacers or rear camber bolts to prevent rubbing in the rear? I did some research and read the 17x8 +45 will rub rear fenders slightly on a wagon. I don't mind rolling the rear, but I want to make sure even after I roll, there will be no rubbing.
ChopstickHero is offline   Reply With Quote
Old 11-23-2011, 01:13 PM   #377
Jux
Member#: 207693
2006 WRX wagon
Hello, first venture into the Subaru world. Just picked up an 06 WRX wagon. I wanted to upgrade the suspension on it to STi's as mine are all blown. But am I reading correctly that 05+ STi suspension will not fit on my wagon? Or is it just the front?
What would I need in order to make them work? The help is greatly appreciated!
Jux is offline   Reply With Quote
Old 11-24-2011, 02:17 PM   #378
Goettler
Member#: 301965
Looking at picking up a 2011 Impreza 2.5i Premium...
What suspension will fit as a replacement?
I'm looking for aftermarket coilover options.
Would 08-11 WRX coilovers work out?
What about a strut + Ground control coilover set up?
Thanks.
Goettler is offline   Reply With Quote
Old 12-11-2011, 03:28 PM   #379
snarefire
Member#: 268549
2005 Impreza Outback
Got a 2005 impreza outback sport. Friend has a set of megan racing street coilovers for his 05 wrx he is getting rid of. Will they fit?
snarefire is offline   Reply With Quote
Old 12-12-2011, 10:34 AM   #380
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
yes..
AndyRoo is offline   Reply With Quote
Old 12-12-2011, 11:04 AM   #381
snarefire
Member#: 268549
Thanks dude, you have no idea how much that helps. I love this forum, but sometimes it takes forever to just get a straight answer. I kept getting opinions on the coil overs, as opposed to the fit. Im getting them really cheap, cheaper than replacement struts are, so to me its a pretty good deal, even if they arent the best coil overs, or are only even decent.
Old 12-16-2011, 04:16 PM   #382
kleedzine
Member#: 273531
02 frankenSTI
white
Will 04,05 oem 20mm Sti rear sway bar fit on 08+ WRX??
Cant see the answer anywhere.
kleedzine is offline   Reply With Quote
Old 01-03-2012, 12:53 PM   #383
abacall
Member#: 132025
06 WRX Spec-C Swap
Thanks RCE!! Any idea on control arms/bushings interchangeability for 08 WRX?
abacall is offline   Reply With Quote
Old 01-03-2012, 01:32 PM   #384
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
What are you looking to interchange? ;-)
08-10 WRX (and 08-11 Impreza) front LCA are the same as 05-09 Legacy arms. The front/rear bushings in them are common to all 08+ Impreza (including 08-10 STI) and the 07-09 Legacy SpecB (other Legacies use softer interchangeable bushings). LCA are interchangeable with the 05-09 Legacies, including the aluminum arms used on the 07-09 Legacy Spec B. STI has a wider aluminum LCA that is too wide for the 08-10 WRX. 11-12 WRX has a wider arm, interchangeable with the 08-12 STI, but made of steel not aluminum (I suspect this is the same as a 09-11 Forester LCA). 11-12 STI got a new "pillow ball" rear bushing in the LCA, the arm was revised for this, the new bushing is no longer interchangeable with other Impreza/Legacy arms. There are rubber "Group-N" bushings available for these LCAs if you know where to look. Lots of urethane and metal options available too, most branded as an "ALK"
My 09 WRX stock LCA next to the SpecB Al version:
Rear Arms: 08-12 Impreza are all the same rear arms including WRX and STI, arms bushings etc all the same on all models. There is a Subaru JDM arm kit for the Impreza, features pillow-ball bushings for the rear LCA and toe arm. There are a few Group-N bushing available as well as a bunch of urethane bushing options.
Power6 is offline   Reply With Quote
Old 01-03-2012, 02:38 PM   #385
abacall
Member#: 132025
06 WRX Spec-C Swap
^^Awesome info, thanks!!
I have 05 Spec C STi arms/ALK/RCA etc on my Forester, was hoping I could transfer something... Oh well.
How about the RCA, will that work?
Old 01-03-2012, 03:53 PM   #386
abacall
Member#: 132025
06 WRX Spec-C Swap
To answer my own question.. Looks like the Whiteline RCA kit is for 02-12 application.
Looks like front endlinks also work 02-12.
Old 01-07-2012, 03:09 PM   #387
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
QUESTION:
What suspension parts from other year/model cars will fit my 98 forester L??
I want to get a little lift on it, wasnt sure if a OEM spring/strut combo from a tribeca or something could work....
or even a raising spring for a newer year forester or wrx.......HELP
SedonaScooby is offline   Reply With Quote
Old 01-10-2012, 11:34 PM   #388
scoobydoo666
Member#: 132099
2012 sti limited
rally blue
Default ??How to make a 05-07STi strut fit wrx 5x100
Hey guys, I have a set of coilovers made for the 5x114 (05-07Sti) and I want to make it fit my car, a 06 Wrx Tr with the standard 5x100.
I don t want to spend a lot for the 5x114 conversion...
could it be possible to extend, enlarge the holes on the coilovers to fit the bolts in at the bottom?
has someone tried that?
scoobydoo666 is offline   Reply With Quote
Old 01-11-2012, 03:10 AM   #389
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
yeah its been done but its a pure hack job and only worth it if someone GAVE you some Ohlins or at least mid level coilover. To pay for it AND have to hack the product not to mention what if you screw up the process of drilling those holes.........something to think about...
Myles
RCE
RaceComp Engineering is offline   Reply With Quote
Old 01-11-2012, 04:50 AM   #390
vicious_fishes
Member#: 158864
2003 SOHC destroker
could you simply buy another shock body?
vicious_fishes is offline   Reply With Quote
Old 01-13-2012, 11:04 AM   #391
skittles28
Member#: 306492
2004 STI
Default 02 wrx suspension problem
i have an 02 wrx, i put 04 struts and springs on it, when i took it to get an alignment as they were adjusting it the axles pulled out of the rear end. did i do something wrong??
skittles28 is offline   Reply With Quote
Old 02-07-2012, 06:30 PM   #392
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
i am buying monroe oe spectrum struts and top hats for my 03 sedan from advanced auto near me. i am not using my old springs and i want to get new ones, does anybody have any sugestion for which is a decent spring to buy? i really dont want to go lower as the rear of my car is low enough now. just looking for some advice and opinins on a decent set of springs that are better than the stock ones. Thanks
Last edited by tcross; 02-07-2012 at 07:25 PM. Reason: listed car as a wagon and its a sedan
tcross is offline   Reply With Quote
Old 02-07-2012, 07:00 PM   #393
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
There's a big wagon thread somewhere on here. One option is springs from an STI + rear top mounts from an STI (required) + Scooby921 spacer (required) + a saggy butt shim (optional, i'd probably do it).
I'd call TIC for those extras and find the springs used somewhere on here. No idea how they'll work with Monroe struts....wouldn't expect them to be a great performance choice but i haven't heard much about those.
- Andrew
Old 02-07-2012, 07:28 PM   #394
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
^^^ my fault im a dumbass and typed wagon and im doing this on my sedan.sorry
Old 02-07-2012, 08:00 PM   #395
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Ah, well same advice, just don't worry about the saggy butt shims.
Old 02-07-2012, 08:25 PM   #396
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
ok thanks ill look into that setup. what year sti should i get the springs and mounts from? and the new struts im looking at are just like the OE ones, so the springs and mounts will work with em? sorry for all the questions but my knowledge on suspension is very little. thanks
Old 02-07-2012, 08:33 PM   #397
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
2004 to 2007 for springs and mounts, the later the better just to get them in good condition. If the struts are the same as OEM then everything will work fine with that scooby921 spacer on the rear struts with the 04 to 07 STI rear mounts.
Old 02-07-2012, 08:44 PM   #398
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
another thing do i need the sti mounts for the front too?
Old 02-07-2012, 08:58 PM   #399
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Nope. It will be good to get a fresh set of topmounts to replace old worn out 8 year old ones but they can be from a WRX or an STI.
Old 02-08-2012, 12:34 AM   #400
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
i really appreciate the help. would have never known that i could do that i really appreciate it. ya saved me a lot of headaches. also i want to gradually start upgrading my suspension in the next 2 or 3 months, and like i said im a novice when it comes to suspension stuff any suggestions on what i should start looking into to upgrade or change on my car. its all stock right now and i got 105000 miles on it?
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 12:46 PM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 07:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 07:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 11:25 PM
