Welcome to the North American Subaru Impreza Owners Club Monday December 22, 2014
Old 02-08-2012, 11:53 AM   #401
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
No problem, glad to help. Next thing on the list IMO would be swaybars front and rear and maybe a few bushings (ALK and steering rack bushings at least).
Turn In Concepts and Racecomp Engineering are 2 very good suspension shops.
- Andrew
AndyRoo is online now   Reply With Quote
Old 02-10-2012, 03:30 PM   #402
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
hey another thing i want sti springs all aroung or just the rear?
tcross is offline   Reply With Quote
Old 02-10-2012, 03:51 PM   #403
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
all around.
Old 02-10-2012, 03:58 PM   #404
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
ok and that will be fine with the 03 wrx struts and strut mounts on the front with sti springs for an 05 or 06 sti?
Old 02-10-2012, 04:04 PM   #405
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
right. you'll need 04-07 strut mounts for the rear from a WRX or STI and the scooby921 spacer available from turn-in-concepts.
Old 02-10-2012, 04:13 PM   #406
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
ok thanks. im not trying to second guess u because i dont know a damn thing about suspensions but im probly going to buy new sti strut mounts for the rear, new wrx ones for the front and new wrx struts this weekend hopefully and look for a set of low mile sti springs. but i am going with kyb Gr-2/excel-g struts for the car instead of those monroe ones from advanced auto i told you about before. those KYB struts are decent ones in ur opinion?
Old 02-10-2012, 04:34 PM   #407
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
the GR-2's will be better than the Monroes.
Old 02-10-2012, 04:38 PM   #408
tcross
Member#: 238552
0306 WRX, outback
PSM, Beige
ok deffinetly go with them. found them for a really good price of around $350 for em online.
Old 02-11-2012, 10:45 AM   #409
Annihilator817
Member#: 296742
'11 WRX, '96 328i,
'92 Civic SiR, '89 CRX Si
Do 08+ STI struts fit on 08+ WRX's? It looks like most aftermarket manufacturers list the same part numbers for the fronts for both the STI and the WRX, but list different part numbers for the rear.
What is the difference?
Annihilator817 is online now   Reply With Quote
Old 02-11-2012, 12:51 PM   #410
Annihilator817
Member#: 296742
'11 WRX, '96 328i,
I also see that TireRack lists the same part number for the Bilstein coilovers for the 08+ WRX as the STI, part #48-155830
I'd really like to buy a set of Ohlins DFV coilovers (part #SUS MI10), but Ohlins only lists WRX specific fitment.
I see BC racing (I'd never buy these, just using them for refernce) lists the same part number for the front struts for the WRX and the STI, but lists a different part number for the rear.
I've read the compatibility statements on the first page of this thread stating that struts and coiloovers won't fit between the STI and other models, but I am seeing these contradictions.
If anyone has any insight, I'd be very grateful.
Old 02-19-2012, 04:28 PM   #411
jh.
Member#: 263340
2011 4DR STI
Can any one confirm that 08+ sti 5dr hb coilovers will fit 11+ sti 4dr sedans?
jh. is offline   Reply With Quote
Old 02-19-2012, 07:00 PM   #412
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
confirmed.
RaceComp Engineering is offline   Reply With Quote
Old 02-24-2012, 04:00 PM   #413
chrismorgan107
Member#: 311418
Default 04 sti spring fit my 94 legacy wagon
So I herd that 04 si springs will fit my 94 legacy wagon but will it lower it? If not what will fit cause I want to.lower it. Only a few inches
chrismorgan107 is offline   Reply With Quote
Old 03-03-2012, 08:56 AM   #414
Nicolaasvan
Member#: 312220
Default 93-01 springs on 02?
Springs
Any 93-03 Impreza spring will fit.
It's best to use 93-01 specific springs.
Does this mean that 93-01 springs will fit my 02? (I want new rally springs, I've only been able to find the Tein G Tech for 93-01)
Why is it best to use 93-01 specific springs?
Nicolaasvan is offline   Reply With Quote
Old 03-14-2012, 01:11 AM   #415
shakerlax1
Member#: 313500
2005 Impreza 2.5rs
Platinum Silver Metallic
i have an 05 2.5rs and i was talking to a guy who has a full stock sti suspension for an 07. im assuming this will not fit my car? if not what is the reason for that?
shakerlax1 is offline   Reply With Quote
Old 03-14-2012, 01:12 AM   #416
shakerlax1
Member#: 313500
2005 Impreza 2.5rs
also if not what is a good recommended aftermarket strut lowering spring combo that's not too pricey to the point of where i might as well buy coils. Not a real rough ride as i do drive it daily
Old 03-19-2012, 09:59 PM   #417
jh.
Member#: 263340
2011 4DR STI
Will 08+ wrx coilovers fit a 08+ sti by changing the top hat?
Old 03-21-2012, 04:04 AM   #418
jh.
Member#: 263340
2011 4DR STI
bump for answer!
Old 03-21-2012, 10:11 AM   #419
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
no - it's the fitment of the front strut to the knuckle that is different
UkNuck is offline   Reply With Quote
Old 03-21-2012, 11:31 AM   #420
jh.
Member#: 263340
2011 4DR STI
Will they work in reverse? Sti coils on wrx?
I thought everything was interchangeable.
Old 03-21-2012, 11:38 AM   #421
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Nope. It's in this thread.
Old 03-21-2012, 06:54 PM   #422
jh.
Member#: 263340
2011 4DR STI
Hmm I've seen some guys use sti coilovers or shocks/springs combo on wrx's. They said no modifications.
Old 03-21-2012, 06:59 PM   #423
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Nope. 2004 STI struts and shocks are fine on a 2002-2007 WRX, but otherwise it ain't happening easily.
Springs are a different story.
Old 03-21-2012, 08:12 PM   #424
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
Question... May be dumb, but I'll ask anyway...
For the 08 WRX, the details say only 08 WRX specific shocks/struts will fit. Since most of this car was based on the 05 Legacy GT, would the shocks from the LGT work on the 08 WRX?
I've been looking at pics of installation on the LGT, and the shocks look the same. I think the brake line clips are different, but I haven't looked closely. Any ideas?
cianuro is offline   Reply With Quote
Old 03-22-2012, 12:02 AM   #425
jh.
Member#: 263340
2011 4DR STI
Sorry this was for 08+
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 12:46 PM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 07:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 07:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 11:25 PM
