Old 07-25-2007, 04:35 PM   #26
stoney98
Member#: 65888
2010 FXT
on the 03 TS wagons, 2-point cowl braces do not fit as the bottom holes are not drilled into the frame. fyi.
stoney98 is offline   Reply With Quote
Old 08-09-2007, 02:22 PM   #27
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
^ thanks, made a few updates (fender braces, 05+ STi lateral links etc.). feel free to double check me.
- Andrew
RaceComp Engineering is offline   Reply With Quote
Old 08-09-2007, 07:06 PM   #28
jamesohoh7
Member#: 39070
GTF off my lawn!
Well, since Konis are mentioned as an application for WRX's...
Koni inserts in 05+ STi struts:
http://forums.nasioc.com/forums/show....php?t=1276865
Still a work-in-progress, but I've fit the front STi struts w/Konis.. others are in the process of doing the same. The rear Konis on 05+ STis can be done more easily by using WRX struts and gutting them (learn from my mistakes on experimenting with the rear STi struts).
So, a 'hybrid' setup, but you -can- get your Koni inserts on 05+ STis now. Read that entire thread before embarking on the project, it's a bit more work than typical WRX installation... it requires a shop-press, and patience, and much care. Obviously use the Koni inserts marketed for 04+ WRX's (to get the newer rears that work with 04+ rear tophats).
Not sure if you want to include this in the list just yet, but in the interest of completeness, 'there it is...'
jamesohoh7 is offline   Reply With Quote
Old 08-10-2007, 10:47 AM   #29
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Originally Posted by RaceComp Engineering View Post
Other
You will be required to use sedan front swaybars and sedan front endlinks. It is recommended to use sedan front axles as well, but not required.
I am trying to get this question answered, to no avail....
What years WRX Sedan Axle's are compatible with my 2004 WRX?
Sideshowbob is offline   Reply With Quote
Old 08-12-2007, 05:57 PM   #30
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Sunday Bump
Old 08-12-2007, 05:59 PM   #31
Siper2
Member#: 1134
2010 Legacy GT Ltd.
Good thread, RCE. Nice job.
Siper2 is offline   Reply With Quote
Old 08-13-2007, 12:33 AM   #32
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
wow....I never saw this Drew....VERY NICE WORK !!
Remind me to buy you Quizno's when I get back....
Mw
Old 08-20-2007, 04:38 PM   #33
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
bump5
Old 08-20-2007, 04:50 PM   #34
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
bump5
I think you'll have better luck asking that, in a separate thread, in the Tranny forum... there was a change from 'innie' to 'outie' stubs iirc, but I don't know when
UkNuck is offline   Reply With Quote
Old 08-21-2007, 10:59 PM   #35
mattwalters
Member#: 422
1998 Legacy 2.5GT
Rio Red
'96-'99 Legacy (BD / BK / BG)
'02 WRX struts and springs will fit, so long as you buy '02 top hats for all four corners *and* '02 front spring perches. You don't need to buy separate rear spring perches, since they're built into the tophats. This probably means that '02 WRX coilovers will work without any kind of messing about (assuming that have built-in hats).
Remember! Wagon bits go with wagons, sedan bits go with sedans. Don't mix and match!
-Matt
mattwalters is offline   Reply With Quote
Old 08-22-2007, 12:37 PM   #36
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
-Matt
Um, I am doing it purposefully to gain negative camber with regular struts without changing strut tops.
Why is it that Sedan axles are recommended? Length difference?
It looks like I just need to know if the car has inny or outty axles. It changed mid-2004 from what I have been told.
Old 08-23-2007, 05:21 PM   #37
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Bump for an answer.
Old 08-23-2007, 05:37 PM   #38
co-driver girlie
Member#: 49296
05 Impreza OB Sp.
Cry Gr./Slvr
if only i had read this BEFORE i purchased d-specs for my wagon.. oh well - they are posted in the for sale forum.
co-driver girlie is offline   Reply With Quote
Old 09-03-2007, 03:17 PM   #39
adbramsay
Member#: 152345
2000 R34 GTS-T sedan
Question ?
sorry i know this is a pain, but do you guys know what will fit an 01 jdm sti?
adbramsay is offline   Reply With Quote
Old 09-03-2007, 07:39 PM   #40
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Um, is that V7? ("Bugeye"?)
Got pics?
Old 09-03-2007, 09:35 PM   #41
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
What parts are you looking at in particular?
- Andrew
Old 09-06-2007, 07:12 PM   #42
dah23
Member#: 158170
i was wondering what kind of coil overs will fit a 08 impreza
dah23 is offline   Reply With Quote
Old 09-10-2007, 11:27 PM   #43
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Nothing from previous years will fit. The rear suspension is a completely new and different design, so you're gonna have to wait for new 2008 specific stuff to come out.
- Andrew
Old 09-10-2007, 11:46 PM   #44
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Updated as much as i could for 2008 WRX, but I don't have many answers there. As we figure things out I'll post things up.
Also updated a few GC8 stuff.
- Andrew
Old 09-11-2007, 01:20 AM   #45
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
I think the conclusion of the Sedan Wagon Axle thing is that they are long enough that it isn't an issue, at least with the Sedan Steel Axle's.
Old 09-12-2007, 01:00 PM   #46
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
until this becomes a 'sticky' I don't know what I think about it.
My '05 strut tower bar (ebay) is failing to fit an '07 sedan, and the guy is using this thread as 'proof'
Meh
cellobro is offline   Reply With Quote
Old 09-12-2007, 04:24 PM   #47
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Meh
front or rear strut bar?
07's usually require a little modification of the AC lines to fit perfectly up front. I'll add that fact in.
- Andrew
Old 09-12-2007, 05:13 PM   #48
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
It's the second thing listed in the Suspension supersticky:
http://forums.nasioc.com/forums/showthread.php?t=171928
john
Old 09-13-2007, 10:11 AM   #49
Scottie
Member#: 2080
06 Impreza Wagon
Red
Great thread.
Some things you may want to add:
1) Saabaru 9-2x parts. Even though, god forbid, that car is supposedly more on the comfort side than the WRX, some may still consider some those parts as a means of tweaking the balance of the car for certain applications.
2) As titled this is a fitment thread, but it would be nice to know the general differences between model years. Example, 04'+ models supposedly got multiphased valving in their struts, smaller rear swaybars, etc.
Scottie is offline   Reply With Quote
Old 09-13-2007, 10:44 AM   #50
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Default steering racks?
Miles,
great thread- thanks!
Got a challenge for you all:
I just installed an '04 (I think) sti steering rack in my stock geometry '02 wrx wagon. There was enough thread on the arms that I had about a turn or two to spare. I'd spoken to the guys at Rallispec before and knew this would just drop in. So here is the problem. I also put in a steering pump from an sti. Got it from Steve at east coast scooby (?) in Arizona, and I can't remember if it was JDM or not. So, question is, I hear the sti's switched to an RPM-based assist instead of a speed-based (or vice versa...). Right now, the pump is making weird noises at idle. Could still be clearing the bubbles out- haven't driven it. Or maybe I'm SOL? Both pumps use the same white single-wire connector, so unfortunately no help there (I did of course plug it in).
Frank
Frank A is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 12:46 PM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 07:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 07:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 11:25 PM
