Old 08-23-2013, 01:36 PM   #501
Toys-N-Joys
Member#: 339716
old subaru
will 98-02 forester struts fit a 03-08?
i hear people lowering the 98-02 with just wrx suspension. and it bolts in other than the rear top hat.
i noticed companies sell the 98-02 struts alot cheaper and i figured they are the same.
but i will ask a knowledge based forum first.
thanks
Toys-N-Joys is offline   Reply With Quote
Old 08-25-2013, 05:48 PM   #502
Jonesy35615
Member#: 353367
2006 Impreza WRX
TP Tuned 255whp/295wtq
Has anyone used the eibach pro-kit lowering springs on an 06 wrx limited in just the front with stock struts? Curious to see if it will work, instead of lowering the whole car.
Jonesy35615 is offline   Reply With Quote
Old 08-27-2013, 03:48 PM   #503
chosen_cartel
Member#: 151620
2003 WRX
will 02-03 wrx stock springs and wrx kyb-gr2s fit my 2005 legacy gt?
chosen_cartel is offline   Reply With Quote
Old 08-27-2013, 05:09 PM   #504
skunkman
Member#: 118141
95 'lifted' legacy
No, different rear suspension set-ups
skunkman is offline   Reply With Quote
Old 08-29-2013, 01:32 PM   #505
jdm_wrx95
Member#: 366509
2003 wrx
blue
Hey guys i have an 03 wrx im running into a little issue and im clueless as of now what can it be...
Before i used to rock the stock wrx suspension whit lowered spring and it was great the springs broke so had to replace...
So i changed them whit an version 8 suspension but the front was sitting way higher then the rear so i changed the version 8 suspension in the rear to the v9 and did no difference...
So what I'd like to do is get the front to sit lower whitout using coilovers (kinda stiff) any suggestions?
Thanks.
jdm_wrx95 is offline   Reply With Quote
Old 08-31-2013, 09:17 AM   #506
jdm_wrx95
Member#: 366509
2003 wrx
blue
Anyone?
Old 08-31-2013, 09:48 AM   #507
SilverRex13
Member#: 365188
2013 WRX
Will this part 2008-2011 h brace
https://www.subarugenuineparts.com/p...oducts_id=1423
Fit my 2013 wrx. Thanks ...
SilverRex13 is offline   Reply With Quote
Old 08-31-2013, 10:00 AM   #508
subieguy87
Member#: 153412
1998 Impreza wrxRS
https://www.subarugenuineparts.com/product_info
.php?products_id=1423
I don't see why not... Not like you asked about a gc part...
Underbody parts should all be the same 08+
subieguy87 is offline   Reply With Quote
Old 09-02-2013, 02:05 AM   #509
cwa831
Member#: 222304
2001 2.5 RS
Anything for a 2002 forester? Trying to see what would fit from the impreza
cwa831 is offline   Reply With Quote
Old 09-03-2013, 06:57 AM   #510
Jeffreynn
Member#: 367203
Well FWD back struts, will fit and you can't quickly exchange on horizontal links to add a back swaybar. That delivers me, to my next factor which is most, of the mature S designs did not have a back swaybar so horizontal links, and supports would have to be changed on.
Jeffreynn is offline   Reply With Quote
Old 10-08-2013, 11:49 AM   #511
FUJHY
Member#: 369197
2014 Outback
ISM
Thanks to RCE for the most useful thread on NASIOC!
FUJHY is offline   Reply With Quote
Old 11-18-2013, 09:52 AM   #512
SCHM1AN
Member#: 277693
2003 Impreza Outback
Sedona Red Pearl
Has there been any definitive answer on the differences in 2008-2011 WRX and STI swaybars? Is it a different geometry or is the WRX bar just too short? And if so, how much shorter?
SCHM1AN is offline   Reply With Quote
Old 11-19-2013, 05:49 PM   #513
skunkman
Member#: 118141
95 'lifted' legacy
thanks
Are you trying to lift something, a gen 2 IMP?
Old 11-20-2013, 08:18 PM   #514
Verittas
Member#: 374181
Hey guys!
So it says on here;
"Swaybars and Swaybar mounts/bushings
Not sure on turbo/non-turbo front swaybar compatibility. Probably are not interchangeable though.
Only 2008 Impreza specific front and rear swaybars will fit.
Strut Bars
Only 2008 Impreza specific front and rear strut/shock tower bars will fit."
Not really specifying on the different trim levels.
So will aftermarket parts meant for 2010 WRX/STI fit my 2010 2.5i?? Been looking through this forum for a few days now and still unable to find a straight yes or no answer. I appreciate all the replies. Cant wait to start ordering and upgrade my suspension.
Verittas is offline   Reply With Quote
Old 01-12-2014, 12:50 PM   #515
msspag
Member#: 221916
2006 STI
Rally Blue
I am considering a complete JDM V9 suspension conversion to 2002 WRX wagon. I understand I am going to end up with a wider track but will everything bolt up. I guess what I am asking is, "are the mounting points the same on the older wagon chassis as on the newer sedan chassis?"
Your research on this subject is amazing. Thanks msspag
msspag is offline   Reply With Quote
Old 01-23-2014, 07:56 PM   #516
Shred_the_2.5i
Member#: 313598
2006 wrx aluminum control arms on my 2006 2.5i? I noticed that the wrx arms are a one hole design for the endlinks while my stock is 2?
Shred_the_2.5i is offline   Reply With Quote
Old 01-24-2014, 08:59 AM   #517
subieguy87
Member#: 153412
1998 Impreza wrxRS
In a nutshell, yes
Old 01-24-2014, 09:01 AM   #518
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Actually I do'nt think so.
JDM V9 would be similar to 2005 STI. So you'd have problems due to different spacing on the front hubs.
AndyRoo is online now   Reply With Quote
Old 01-24-2014, 09:02 AM   #519
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
You'd probably want a different swaybar but I'm not sure.
Old 01-24-2014, 09:02 AM   #520
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Originally Posted by Verittas View Post
Hey guys!
So it says on here;
Strut Bars
Like it says the front swaybar probably won't fit.
Front struts will not fit.
Springs will be way too stiff unless you get Konis or something.
Old 01-24-2014, 01:21 PM   #521
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Hey guys! So it says on here; "Swaybars and Swaybar mounts/bushings Not sure on turbo/non-turbo front swaybar compatibility. Probably are not interchangeable though. Only 2008 Impreza specific front and rear swaybars will fit. Strut Bars Only 2008 Impreza specific front and rear strut/shock tower bars will fit." Not really specifying on the different trim levels. So will aftermarket parts meant for 2010 WRX/STI fit my 2010 2.5i?? Been looking through this forum for a few days now and still unable to find a straight yes or no answer. I appreciate all the replies. Cant wait to start ordering and upgrade my suspension.
08+ imprezas have a specific swaybar that fits. Available from whiteline or rallitek. I heard from a few people that they modified the wrx swaybar to fit bit I wouldn't recommend it.
Any 08-14 wrx/STI strut tower bar will fit.
As andyroo said, the front struts from a STI will not fit without modification to the knuckle location. However any 08-14 wrx suspension part will fit (I.e. Oem/aftermarket struts/coils, bushings, bracing-except h braces, etc.)
Pm for more info if needed.
KartRacer3 is offline   Reply With Quote
Old 01-25-2014, 09:29 AM   #522
Son of Zartan
Member#: 216279
2014 Crosstrék
any idea what parts fit the Crosstrek?
Son of Zartan is offline   Reply With Quote
Old 01-25-2014, 11:58 AM   #523
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
I have a question that I have been trying to find the answer to for a few days now by comparing part numbers and searching, but my question is,Will the front control arms from a GC fit on an 03 WRX wagon? What about wagon control arms from 02-07, are they all the same?
tersplat is offline   Reply With Quote
Old 01-25-2014, 12:44 PM   #524
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Yes and yes.
GC and GG (GD wagon) control arms have the same dimensions.
Bikelok is offline   Reply With Quote
Old 01-25-2014, 02:04 PM   #525
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
^ Thanks!
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
