Old 05-01-2014, 11:42 AM   #576
04OBS
Member#: 389570
2005 Legacy GT
white
Originally Posted by projectQWKSLVR View Post
The Russians are making struts? :-)
The KYB Gr2's are out of production, they are now the Excel G's. They're the same, but they're not, but they are. :-/
Either way, I've been running the Excel G's for a bit now. They aren't soft but they most certainly are not stiff either. A good OE type replacement.
hahaha, yeah haven't your heard!?! yes, i mean KYBs. And rock auto shows them as GR-2/Excel Gs so I didn't even realize it.
04OBS is offline   Reply With Quote
Old 05-01-2014, 11:53 AM   #577
Ismokeyou
Member#: 287201
2006 2.5i
Regal Blue Pearl
Originally Posted by Bikelok View Post
Yes, kind of. It will fit and work fine. The end links will attach to the outside of the sway bar as opposed to the inside. This will diminish the effectiveness of the bar ever so slightly. You won't notice the difference. Some very knowledgable folks said that the difference is way to small to really notice.
Ahh for sure I thought so. I may try and snag it still, but a wrx sway may just work better/easier.
Ismokeyou is offline   Reply With Quote
Old 05-01-2014, 11:59 AM   #578
05WrB WRX
Member#: 82019
2015 added soon
05WrB WRX is offline   Reply With Quote
Old 05-19-2014, 12:22 AM   #579
04OBS
Member#: 389570
2005 Legacy GT
white
You can use 04-07 WRX springs. You can also use 04-07 STI springs. Either will fit without issue. The WRX spring is probably a better match for the strut, but STI spring will work ok too.
Found a full set of 2007 sti struts, springs, and top hats. Would they be a direct swap or would I need new camber bolts and or top hats???
Old 05-19-2014, 08:08 AM   #580
gregroot198521
Member#: 280844
2006 STi
Bottom sides won't fit, that's almost a guarantee. 5x100 has a different setup than 5x114 setups.
gregroot198521 is offline   Reply With Quote
Old 05-19-2014, 09:16 AM   #581
JonnyV2889
Member#: 197384
2006 WRX Ltd
It can be done w 1/8" plates and some fab skills.
JonnyV2889 is offline   Reply With Quote
Old 05-19-2014, 01:39 PM   #582
04OBS
Member#: 389570
2005 Legacy GT
white
Dang. Thanks guys. Thought it was a long shot but figured I'd try
Old 05-27-2014, 02:27 PM   #583
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Default upper control arms Legacy Baja
Will the upper control arm from a 2004/2005 Legacy fit a 2005 Baja N/A? Is it the same part? Reason for asking is I need camber adjustment in the rear of my Baja (there currently is no way to adjust), and I would like to buy the White Line adjustable bushings that fit the 2004/2005 Legacy, they look like they would solve my problem. Thanks
Buck Rogers is offline   Reply With Quote
Old 05-28-2014, 12:48 AM   #584
mzolth
Member#: 392024
Default 2007 front strut inserts - need some help
New here as I'm not an STi owner but own a machine shop and am looking for some information. I need to replace a strut insert for 2007 STi that was damaged. I was looking at new strut prices and it appears that the retail price for a front strut for an STi is $330 - 380 while the same strut for a non-STi car is half that.
Is it just a matter of different valving or is the actual insert a different size / configuration? If it's just a matter of valving/ shim stacks etc, I'd like to buy the less expensive pieces and use the shaft / piston assembly from my strut in the new body.
Any help would be greatly appreciated whether it be information or possibly a lead on a used strut that is available.
I'm located in the San Francisco Bay Area.
Thanks in Advance
Mark Halmi
Independent Machine Works
Oakland, CA
mzolth is offline   Reply With Quote
Old 05-28-2014, 03:17 AM   #585
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Thanks in Advance
Mark Halmi
Oakland, CA
STI struts are inverted.
The STI struts use a cartridge that fits inside the housing, unlike a standard (WRX) strut.
They will in no way work with WRX struts.
How is it damaged? I'm assuming the cartridge is damaged and not the housing.
You can probably find a good used set of STI struts around for a fraction of the cost of new.
What many people do with STI struts are to send them to a company called Feal down in SoCal. They rebuild and re-valve them to perform better than new. Being a machinist, this is something you might want to try yourself, but getting it right takes lots of trial and error and a great understanding of these components.
Stock STI strut are known to be harsh and this is one of the things Feal rectifies very well.
Again, STI struts are an inverted design and can not be rebuilt with WRX type struts.
Also, 05-07 STI front struts do not match up with WRX struts (the 04 STI is the only one that does match the WRX). The STI clevis is too wide and the holes don't match up. STI struts have been modified to fit in a WRX, but it would not be easy (not worth all the trouble) to go the other way.
Used is the cost effective way to go. You can try rebuilding them yourself, or send them to Feal.
Bikelok is offline   Reply With Quote
Old 05-28-2014, 10:55 AM   #586
mzolth
Member#: 392024
Thanks for the info, its very helpful.
It is the strut insert/cartridge that is actually damaged (I did it).
Any leads on a used insert beyond the obvious (CL and eBay) would be appreciated.
Old 05-28-2014, 12:12 PM   #587
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Try the classifieds here.
Also for local Bay Area listings, go to I-Club classifieds.
I'm also in the Bay Area and that forums great for local stuff.
Good luck.
Old 05-28-2014, 12:29 PM   #588
mzolth
Member#: 392024
Good luck.
Thanks!
Old 05-29-2014, 02:11 PM   #589
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
This is the right forum, right? (Steering & Suspension) Last I knew an upper control arm was part of the suspension, anybody want to reply with a helpful suggestion?
Old 05-30-2014, 07:56 PM   #590
subscript
Member#: 140143
04 Forester XT
87 GL-10 RX wagon
Have you tried asking on the Legacy and Baja forums? They don't share much with the Impreza platform that this forum specializes in.
subscript is offline   Reply With Quote
Old 05-30-2014, 08:42 PM   #591
Shecker141
Member#: 368756
2005 impreza
San remo red
Will an 05 sti rear sway bar fit my 05 2.5rs? If not, what would I need to do to get it to fit?
Shecker141 is offline   Reply With Quote
Old 05-31-2014, 12:13 PM   #592
Bikelok
Member#: 254851
2002 WRX wagon 5mt
It will fit.
The endlinks will be mounted on the opposite side of the bar, but that's all the difference.
Old 05-31-2014, 12:22 PM   #593
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I'm not very familiar with newer Leggies/Baja.
With a quick look the rear lateral links are the same part number. The front and upper lateral links are not.
Just because the front and upper lateral links are not the same part number does not always mean it won't work on your model. As was said ask in a Legacy/Baja forum for a definitive answer.
And PLEASE POST YOUR OUTCOME HERE, for future searches.
Good luck.
Old 05-31-2014, 04:21 PM   #594
XxBuzzkill77xX
Member#: 227418
2004 Impreza WRX STi
Would an 03-07 forester coilover fit into an 04 STi? I know they are both 5x100 but I'm more concerned about the top hats.
XxBuzzkill77xX is offline   Reply With Quote
Old 06-06-2014, 10:07 AM   #595
Jesper M.
Member#: 392812
2007 Impreza
Well hi. I need some advise, fast
I have bought KYB AGX's to a 2000-2002 WRX (Bugeye) and Eibach springs to a 2003-2004 WRX STI (Blobeye).
My car is a 2007 Impreza 2,0 R which have the WRX body, without the engine and turbo, so the bodywork is 5x100 PCD.
After fitment of both AGX and Eibach, the rear keeps making "klonk" noises. I was told in Denmark, that they would fit. But after finding a few treads in here, i can se there is a difference in the struts, springs and the strut top mounts.
My car is the 2007, but should i buy Bugeye strut mounts, Blobeye strut mounts, or womething third to make it fit properly?
Jesper M. is offline   Reply With Quote
Old 06-06-2014, 11:26 AM   #596
Bikelok
Member#: 254851
2002 WRX wagon 5mt
You can make it work no problem.
As you said the AGX are Bugeye fitment (USDM 2002-2003, Europe/Japan 2000-2002).
The Eibach you have are Blobeye/Hawkeye fitment (USDM 2004-2007, Europe/Japan 2003-2007).
Now only the rear springs and top hats are different between these fitments. To get the blobeye/hawkeye rear springs and top hats to work on Bugeye rear struts you need a special washer. Commonly called a 921 spacer.
These 921 spacers are available from a US company called Turn in Concepts. They are inexpensive at around $20 US.
Install these spacers between the rear struts and rear top hats and your problems will go away.
You are using Blobeye/Hawkeye rear top hats right? If not then you will need a set of Blobeye/Hawkeye rear top hats and the 921 spacers to make it all work.
Old 06-06-2014, 12:51 PM   #597
Jesper M.
Member#: 392812
2007 Impreza
Hi. Well, i dont know if they are made for the US or EU Impreza's, but i know the Polish dealer had to bring one strut home from America, before he could ship it out.
I jused the OEM strut mounts (the top of the strut) tyhat was on my car, on the new AGX's, and it makes a terrible klonk from the right rear side. I'm thinking about replace them for some new, as i think one of them have taken a little damage from the dismount of the OEM springs ad struts, and the mount on the new struts.
Im guessing that i should buy this: http://turninconcepts.com/scooby921-strut-spacers.html How many?
But how can i know if it have taken damage? It would be silly to change them know if they still work proberbly?
Old 06-06-2014, 02:13 PM   #598
Bikelok
Member#: 254851
2002 WRX wagon 5mt
How is it damaged? What do you mean damaged when they were installed?
If you have not put too many kilometers on the struts since they were installed, they should be fine. It would probably take a month or more of daily driving before permanent damage occurs with the way it's set up now (without the spacers).
Yes, you should buy those spacers. They will fix the problem.
Old 06-06-2014, 06:13 PM   #599
Jesper M.
Member#: 392812
2007 Impreza
I mean the top hats. They have drivin 130.000km on the OEM struts, and wasnt changed when i shifted over to the AGX's with Eibach springs. Some say the bearing inside can get damaged when jusing a airtool to break apart the old ones, and install them on top of the new?
Or does it only make the klonk because i need the spacers?
Old 06-06-2014, 07:12 PM   #600
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Because of the spacers.
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
