Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-14-2008, 12:56 PM   #76
logoriel
Member#: 163179
2008 Impreza 2.5i
Thumbs up Excellent thread!
Subscribe-d. This is going to be what I'd do to my car if anything.
Of course, it all comes down to "Do I have the balls...*cough*...'technical expertise' to disassemble my (3 month old) daily driver?"
Ask me again in four years (or less if I'm lucky) when I've paid it off. And the answer will be "Hell Yes!"
logoriel is offline   Reply With Quote
Old 01-14-2008, 02:18 PM   #77
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Originally Posted by EarlQHan View Post
Great idea! When you have time, do you think you could add a Forester section?
I will eventually.
- Andrew
RaceComp Engineering is offline   Reply With Quote
Old 01-17-2008, 02:41 PM   #78
subikid
Member#: 114122
1990 miata(RIP 05rs)
red
I couldn't find it anywhere...
Will 02-05 wrx lowering springs fit on my 05 2.5rs? stock suspension, sways, etc.
Kevin
subikid is offline   Reply With Quote
Old 01-17-2008, 03:50 PM   #79
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
^see here. 02-03 springs are different then 04+ springs.
Springs
Springs for 04-07 RS or WRX will fit.
Aftermarket springs designed for Impreza STi will be too stiff for stock struts. OEM STi springs work well though.
To use springs designed for 02-03 Impreza, you must use 02-03 Impreza struts and rear strut top mounts.
See strut section above for spring fitment when using 02-03 struts.
Old 01-17-2008, 04:54 PM   #80
subikid
Member#: 114122
red
I still can't tell completely, maybe it's the wording. does that mean that Springs for 04-07 RS or WRX are INTERCHANGEABLE?
Sorry for my confusion, but I just don't want to buy the wrong thing
Here's what I'm trying to buy:
Item number: 120118184575 on eBay. Link isn't working for some reason.
The year says 02-05 WRX springs... which isn't consistent with the information in this thread..
Will they fit?
Kevin
Old 01-17-2008, 05:43 PM   #81
mdungelman
Member#: 97251
'13 Impreza 2.0i
Please don't get those. They look like $hit. And you're a "Scooby Specialist"? Shouldn't you know better by now? How about you get some reputable springs. STI takeoffs at the very least.
mdungelman is offline   Reply With Quote
Old 01-17-2008, 06:19 PM   #82
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
When in doubt, ebay listings from places you've never heard of are wrong.
There is no such thing as a spring that fits 02-05 WRX without any modifications (i.e. using different struts or strut tops.)
- andrew
Old 01-17-2008, 06:53 PM   #83
subikid
Member#: 114122
red
^^That's what I was asking. I thought it sounded odd.
Thanks for the help.
Kevin
Old 01-17-2008, 07:45 PM   #84
subikid
Member#: 114122
red
got my answer
Old 01-20-2008, 10:40 PM   #85
1984
Member#: 16461
WRB w/paintchip flake
I don't see the Bilstein/Prodrive RB320 struts for the 05+ STi on the list...
1984 is offline   Reply With Quote
Old 01-20-2008, 11:27 PM   #86
NDGeist
Member#: 143196
2002 WRX Wagon
Maroon
I'm putting RCE Wagon springs on my '02 wagon, along with a set of Koni's.
I can re-use my exising struts, as long as I get GroupN bushings for the rear, and either GroupN or Camber plates for the front, correct? No other parts that I need to buy?
NDGeist is offline   Reply With Quote
Old 01-30-2008, 09:29 PM   #87
DomzWRX
Member#: 143827
2004 WRB WRX
Enginuity-STG2
Is this not a sticky?
DomzWRX is offline   Reply With Quote
Old 01-30-2008, 09:44 PM   #88
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
You need 04 or later tophats (not bushings) for the rear, along with the TiC spacers or equivalent. Fit wise, they can be off any 04+ Impreza but WRX or STi ones will be stiffer, and Group N ones stiffer yet.
For the front, you don't need anything but you could upgrade to the stiffer Group N tophats, or camber plates if you want the camber and/or caster adjustability.
UkNuck is offline   Reply With Quote
Old 01-30-2008, 09:55 PM   #89
NDGeist
Member#: 143196
2002 WRX Wagon
Maroon
Ah yes... brain fart on my part... Yes... i need the tophats.
Speaking of which, mine should be here any day.
Old 01-30-2008, 10:31 PM   #90
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
It's in the main suspension sticky... link #2.
http://forums.nasioc.com/forums/showthread.php?t=171928
Old 01-31-2008, 12:11 PM   #91
mechanizedmedic
Member#: 96807
2002 Outback Sport
i didn't see anything specifically regarding wagon to sedan compatabilty. i used camber adjustable tophats to properly fit wrx coilovers on my OBS. ...is there an oem tophat option that would've worked?
mechanizedmedic is offline   Reply With Quote
Old 01-31-2008, 12:17 PM   #92
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
No, tophats are the same wagon vs. sedan.
- drew
Old 02-22-2008, 11:14 AM   #93
noboost4u
Member#: 126442
My car is slower
than your car
Originally Posted by RaceComp Engineering View Post
2004-2007 Impreza WRX, WRX Wagon, 2.5RS, 2.5 RS Wagon, Outback Sport
Other
Fender Braces do not fit non-turbo models.
This may be true for some cars, I definitiely have Shane's fender braces on my 05 RS sedan.
noboost4u is offline   Reply With Quote
Old 02-27-2008, 09:03 AM   #94
wrecks2008
Member#: 160712
2008 WRX
Rally Blue
Default Rear sway bar
2008 Impreza 2.5i, WRX, and Outback Sport
Struts
Springs
Strut tops and Camber Plates
Camber Bolts
Strut Bars
Coilovers
Swaybars and Swaybar mounts/bushings
Endlinks
Other
Struts + Shocks
Only 2008 Impreza specific struts and shocks will fit.
Springs
Only 2008 Impreza specific springs will fit. (probably)
Not sure yet about fronts.
Rears are probably 2008 Impreza specific.
Camber bolts
Probably 14mm camber bolts up front.
Strut Bars
Not sure on front compatibility, but probably 08 Impreza specific.
Only 2008 Impreza specific rear strut/shock tower bars will fit.
Coilovers
Only 2008 Impreza specific coilovers will fit.
I have an idea about front swaybar compatibility but I'm not able to confirm it yet.
Not sure on turbo/non-turbo front swaybar compatibility. Probably are not interchangeable though.
Only 2008 Impreza specific rear swaybars will fit.
Endlinks
Not sure on front compatibility.
Only 2008 Impreza specific rear endlinks will fit.
Other
Not sure on sedan and wagon differences yet.
Please help me update this section as info becomes available!
Hi, I am looking for a rear sway bar and I'm pretty sure the one from the 08 STI will fit on a regular 2008 WRX, increasing the size of the bar from 15mm to 18mm. So far, this bar would cost about half of what the landed cost of an aftermarket bar would cost (canuck ).
wrecks2008 is offline   Reply With Quote
Old 02-27-2008, 11:12 AM   #95
BXER4EJ20
Member#: 162587
does anyone here know if the Group N top hats will allow you to use the stock spring still for a 2002 WRX. Also does anyone know if the Cusco Pillow ball top hat will work with the stock spring.
Thanks in advance
BXER4EJ20 is offline   Reply With Quote
Old 02-27-2008, 11:18 AM   #96
kennyc
Member#: 158763
1996 AWD Brightn WGN
How about adding Legacy's in here as well?
kennyc is offline   Reply With Quote
Old 03-07-2008, 04:55 PM   #97
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
^ Eventually....when we start figuring out what's compatible between the leggy's and the new Impreza it will be helpful.
- Andrew
Old 03-12-2008, 06:03 PM   #98
GHK
Member#: 103886
2005 WRX
Does any one know if 05FXT trailing arms will fit 05 wrx sedan? I couldn't really find this info from search.
GHK is offline   Reply With Quote
Old 03-20-2008, 01:43 AM   #99
tuswm6
Member#: 144435
I just wanted to say thanks, the info on swaybars saved me some money, thanks.
tuswm6 is offline   Reply With Quote
Old 03-28-2008, 08:01 PM   #100
FF2
Member#: 63453
1998 Impreza 2.5RS
There is no info regarding interchangability of rear lateral links and trailing arms for the GC model (93-2001). Left out because nothing can be swapped or no one has tested that theory yet?
FF2 is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
