Old 03-29-2008, 02:08 AM   #101
bsmitty
Member#: 158445
1993 Impreza L sedan
+ V7 drivetrain = <3
In the section on GC/GF cars...
Springs
Any 93-03 Impreza spring will fit.
It's best to use 93-01 specific springs.
04+ Impreza springs will not fit.
I've got a GC project in the works now (93 L sedan swapping in a JDM v7 drivetrain) and I currently have 04 STi struts AND springs on there. How? Well, first of all, work is being done by the guys at Pacific Import Auto here in Tacoma, WA so they know what they're doing. They told me that it works by using rear tophats from a BC Legacy (89-94, I believe).
Now, with that setup, I've got about 5" of wheel-well clearance (ready for rallying? ) and so if I want lowering springs, I need to look for 04-07 springs.
Any comment?
bsmitty is offline   Reply With Quote
Old 03-29-2008, 11:48 AM   #102
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
This thread isn't for custom fitment....you can make anything work if you try hard enough.
I suppose you would use 04-07 lowering springs with that set-up. However I would much rather just run a GC specific set-up and have the correct geometry since you may not have all that much camber with your set-up. That and STi struts leave a lot to be desired.
- Andrew
AndyRoo is offline   Reply With Quote
Old 03-29-2008, 11:50 AM   #103
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
Originally Posted by FF2 View Post
There is no info regarding interchangability of rear lateral links and trailing arms for the GC model (93-2001). Left out because nothing can be swapped or no one has tested that theory yet?
Hmm....what swap are you trying to do? I believe GD sedan lateral links will be too wide, but wagon lateral links may work. Not 100% sure.
Trailing arms should be fine.
- Andrew
Old 03-29-2008, 09:25 PM   #104
FF2
Member#: 63453
1998 Impreza 2.5RS
- Andrew
No swap, just major repairs. I need to replace the rear wheel bearings, so why not upgrade my suspension. I have STI Ver 5 RA struts and springs that I'd like to put it, I have the front aluminum control arms I'd like to use, I figured why not upgrade the lateral links and trailing arms as well. But as I was trying to remove the long bolt that holds the lateral links to the rear disk hub, the head broke off the bolt. So I am now forced to have someone do this correctly for me. Right now I am shopping around for a good Subaru shop as well as finding a set of lateral links and trailing arms.
So you are saying the trailing arms from any year STI would work?
FF2 is offline   Reply With Quote
Old 03-31-2008, 10:46 AM   #105
hoffmanEstates
Member#: 122043
04 wagonier
psm
Default 06 sti on 04 wagon?
found 06 sti struts and springs will they fit an 04 wrx wagon yes or no or with work? and will i lose neg camber like they say if so how can i fix it if i have it aligned again
hoffmanEstates is offline   Reply With Quote
Old 03-31-2008, 10:59 AM   #106
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
springs will fit, (front) struts won't fit so the camber issue is moot
UkNuck is offline   Reply With Quote
Old 03-31-2008, 11:01 AM   #107
gtasti
Member#: 152036
2004 Sti
this should be a sticky
gtasti is offline   Reply With Quote
Old 03-31-2008, 11:04 AM   #108
hoffmanEstates
Member#: 122043
04 wagonier
psm
trying to get ahold of tom at kartboy and ask him personally but its cali and like 2-3 hr difference shucks and no one gives u a straight awnser
Old 04-09-2008, 07:16 PM   #109
ritky
Member#: 72285
2003 WRX PSM w/FXHID
FLA Turnpike > I-95
Originally Posted by RaceComp Engineering View Post
2005-2007 Impreza STi
Same as 2004 STi, except for:
Coilovers
Only coilovers specific to 05+ STi will fit.
FYI, apparently from this thread you can fit rear 02-07 impreza coilovers/struts to fit the rear of the 05-07 STi. I guess only mainly applicable to doing the koni inserts.
This information may be helpful to others since it was very helpful with me.
ritky is offline   Reply With Quote
Old 04-09-2008, 07:19 PM   #110
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
^ This is true, the rears will fit (be sure to have the right rear springs/tophats).
But for clarity's sake I left it the way it is. Maybe I'll add a note later?
- Andrew
Old 04-28-2008, 06:18 PM   #111
thetugboatcomplex
Member#: 163560
so i can run sedan rear sway on my 07 wagon?
thetugboatcomplex is offline   Reply With Quote
Old 04-28-2008, 08:03 PM   #112
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
yes, except one from an STI sedan
Old 04-29-2008, 02:36 AM   #113
WPsubarally
Member#: 178717
Default fitment confermation
After a lot of hours searching all the subaru forums i could find, i think i've found a lift setup that will work w/ my 96 legacy outback. with the exception of a small brake line mount modification, i believe this strut/spring combination from a 01 forrester s should bolt right in.
http://www.subaruforester.org/vbulle...-wheels-32239/
Before I buy, i'm just checking if any body out there has swapped from this year model forrester. All swaps i've found seem to have been from Pre-2000 or the xt models.
Thanks for the help
WPsubarally is offline   Reply With Quote
Old 04-29-2008, 03:05 PM   #114
FF2
Member#: 63453
1998 Impreza 2.5RS
Any info on front sway bars and endlinks would be helpful for the GC line (MY93-2001).
Old 04-29-2008, 06:43 PM   #115
kainam00
Member#: 100708
2000 2.5RS
2006 WRX
So am I correct in thinking that if I get some 02-03 WRX springs and put them on my MY00 2.5RS (AGX struts with stock springs now), they will fit into the stock perches and everything?
If so, then I can get some Prodrive springs in 02-03 WRX fitment and have roughly the stock ride height but with a stiffer spring, correct?
kainam00 is offline   Reply With Quote
Old 04-29-2008, 08:05 PM   #116
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
Should be the same fitment from 93-01. Turbo front bars will not fit a non-turbo car.
- Andrew
Old 04-29-2008, 08:06 PM   #117
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
Thanks for the help
Probably worth it's own thread. 01 Forster should be the same fitment as pre 2000 for suspension though.
- Andrew
Old 04-29-2008, 08:07 PM   #118
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
They'll physically fit, but I have no idea what they'll do for your ride height and how it'll handle since it's designed for a completely different car.
- Andrew
Old 04-29-2008, 11:04 PM   #119
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
some have done this with different results and impressions. Not suggested.
Mw
RaceComp Engineering is offline   Reply With Quote
Old 04-30-2008, 10:12 AM   #120
kainam00
Member#: 100708
2000 2.5RS
2006 WRX
Why is it not suggested? What are some of the drawbacks? Do you have any links to people who've done it?
I understand that putting a spring that was not intended to use on my car onto my car is not necessarily a good idea, I just want to know if there is knowledge and experience of specific drawbacks.
Thanks!
Old 05-16-2008, 01:24 PM   #121
eclip5e
Member#: 14686
2004 RASpec Impreza
Dent Sport/visual assault
Heres a stumper:
Will rear 2005 STI struts fit rear 2004 STI knuckles?
eclip5e is offline   Reply With Quote
Old 05-16-2008, 03:01 PM   #122
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
Originally Posted by eclip5e View Post
Heres a stumper:
that i can do....yes the rears will fit.
Also you can take out the damper inserts and put them in the 04 housing if i recall.
- Andrew
GTWORX.com is offline   Reply With Quote
Old 05-19-2008, 10:20 AM   #123
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Thanks Jard - fixed the links, I think.
ButtDyno is offline   Reply With Quote
Old 05-19-2008, 10:23 AM   #124
Jard
In the silly seat
Member#: 34935
SPB- 2013
Smugmobile
They work for me!
Jard is online now   Reply With Quote
Old 06-05-2008, 09:23 AM   #125
Airborne_J
Member#: 93045
2004 FXT 5mt
2001 2.5 RS
Why, camber plates? control arm? the 5X114 knuckle?
Airborne_J is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread ButtDyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
Message Board Statistics All times are GMT -4. The time now is 02:27 PM.
