Old 12-13-2008, 07:26 PM   #176
Brack
Member#: 12445
13 Accent
Red
Originally Posted by Daishi00 View Post
What I have read on strut/spring combo
08/09 WRX struts will fit on 08/09 WRX.
08/09 STi struts will fit on 08/09 STi.
08/09 STi springs will fit on 08/09 STi and 09 WRX.
Can you send me to the place that states this ?
Thanks
Brack is offline   Reply With Quote
Old 12-13-2008, 07:35 PM   #177
Daishi00
Member#: 78952
2005 WRX
CGM
It's info pieced together from the board here.
We already know that the 08/09 STi' use a different front clevis just like previous models which means no transfer to the WRX body. We also know that the 09 WRX spring rate was increased substantially and by what BIGSKY has shared is pretty darn close to the stock STi rates. The STi springs should lower somewhere around 10mm, so a little under a half inch.
Daishi00 is offline   Reply With Quote
Old 01-10-2009, 10:21 PM   #178
shemoves
Member#: 80663
2005 STi
Very cool thread. If I may suggest, add fitment regarding 91-94 Turbo Legacys.
shemoves is online now   Reply With Quote
Old 01-10-2009, 10:35 PM   #179
team trucha racing
Member#: 118484
04 sti RotatedGT35
wrb harman motive tunned
thanks for the help!!!
team trucha racing is offline   Reply With Quote
Old 01-11-2009, 12:31 AM   #180
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
why doesn't an '08 sti spring work on an '08 wrx strut? was the '08 wrx strut crappy?
Frank A is offline   Reply With Quote
Old 02-04-2009, 11:38 AM   #181
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Any idea whether pre-08 camber plates will work on an 08?
Old 02-04-2009, 11:43 AM   #182
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
They won't work. 08+ use the same front plates as Legacy.
- Andrew
AndyRoo is offline   Reply With Quote
Old 02-04-2009, 11:44 AM   #183
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
They'll physically fit, but i think they'd be much too stiff for the crappy 08 strut.
- Andrew
Old 02-07-2009, 03:06 PM   #184
Haven
Member#: 95
2006 Wrx
Crystal Gray
So '04 sti struts won't fit '06 wrx?
Haven is offline   Reply With Quote
Old 02-07-2009, 03:24 PM   #185
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
04 *will* - it's 05+ that won't
UkNuck is offline   Reply With Quote
Old 02-07-2009, 03:34 PM   #186
Haven
Member#: 95
2006 Wrx
Crystal Gray
So they should just bolt up?
Thanks
Old 02-08-2009, 05:40 PM   #187
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
yes, exact same fitment.
Old 02-08-2009, 06:12 PM   #188
Brack
Member#: 12445
13 Accent
Red
So...now I know that the 08 STi springs will work on an 09 WRX.
I did it, and the result was minimal, as the STi fronts drop it maybe .4 and the rears did nothing. Spring rates on the STi's are 1# more than the WRX's
As soon as I can (afford), I am going to contact Myles and buy a set of the KW variant 3's.
Old 02-08-2009, 06:17 PM   #189
Daishi00
Member#: 78952
2005 WRX
CGM
So you confirmed what I said basically. About a 10mm drop with no real increase in spring rate.
Old 02-24-2009, 07:27 PM   #190
dntouch
Member#: 79662
11 Jeep Unlimited
Havent been able to find the right info.
Are sedan front springs from any year slightly lower than say an 06' wagon factory front? (my car 06 WRX wagon)
I went back to stock springs but kept all the happy turning suspension parts on the car i.e. sways, bracing, bushings, endlinks, etc. etc.,,,
I would like to lower my front end only a 1/2" or so, to even out the look and not give me higher spring rates than stock.
Anyone...
dntouch is offline   Reply With Quote
Old 02-24-2009, 07:53 PM   #191
ghostrat
Member#: 190936
08 Impreza
Anyone know what options I have for swaybars for my 08 2.5i waggin? Looking to pick some up before autocrossing next month.
Do swaybars made for a WRX fit? If so, what brands are available? Adjustability is a big plus.
Thanks to anyone who can help
ghostrat is offline   Reply With Quote
Old 02-26-2009, 01:34 PM   #192
EvanOT
Member#: 199592
2007 07 Forester XS
Silver?
How about 07 forester?
What year WRX/STI struts will fit?
EvanOT is offline   Reply With Quote
Old 02-26-2009, 05:12 PM   #193
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Forester basically works like a WRX. The 5x100 knuckles will work with the 02-07 WRX stuff, and the 04 STI stuff.
I would check on sf.org to be sure.
Abnormal is offline   Reply With Quote
Old 02-26-2009, 06:05 PM   #194
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Anyone...
I don't think any OEM spring exists that will do that for you. Sorry.
- Andrew
Old 02-26-2009, 06:05 PM   #195
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
The rears will fit. Front turbo swaybars probably will not.
- andrew
Old 02-26-2009, 08:54 PM   #196
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I know its been covered that '08 STI suspension does not work on an 08-09 WRX, but can anyone say why exactly? I have my stock STI suspension just laying around and it would be great if I could adapt it to my uncle's WRX.
Frank
edit *nevermind* - held my '08 sti struts next to the wrx suspension and the difference is obvious- the clevis on the STI is ~30mm wide, while the wrx is 22-24mm. No way is that working...
Old 02-26-2009, 08:58 PM   #197
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
It's the front struts that do not fit. Same with the old GD cars with 5x100 and 5x114 hub fitment differences.
It's not really an improvement over the 09 WRX suspension anyway.
- Andrew
Old 02-27-2009, 12:36 AM   #198
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Well, if you happen to know someone that wants to trade their '09 wrx suspension, have them give me a call
But in all seriousness, how big is the difference? I mean, can I use camber bolts to fix the included angle, or is the offset just too much?
Frank
Old 03-04-2009, 06:19 PM   #199
JetGirlArt
Member#: 203464
2007 Impreza 2.5i
Newport Blue Pearl
Swaybar post:
"02-07 Impreza RS require a specific sway bar to clear the non-turbo headers. WRX and STi front swaybars will not fit an RS."
by RS do you mean the 2.5i? I'm having a hard time finding a front swaybar for my car that will fit.
JetGirlArt is offline   Reply With Quote
Old 03-04-2009, 06:21 PM   #200
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Yes. RS == 2.5i
RS almost always means non-turbo on the boards
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 12:46 PM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 07:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 07:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 11:25 PM
