Old 03-04-2009, 06:25 PM   #201
JetGirlArt
Member#: 203464
2007 Impreza 2.5i
Newport Blue Pearl
Originally Posted by a13n0rma1 View Post
Yes. RS == 2.5i
RS almost always means non-turbo on the boards
good to know, im a total noob so I look for what I know, is is why i was having trouble finding info in the first place. ^_^
JetGirlArt is offline   Reply With Quote
Old 03-13-2009, 08:51 PM   #202
DeathSStar
Member#: 202982
Subscribed.
Any updates for STB's and swaybars for the 08+ 2.5i and/or Outback Sport?
DeathSStar is offline   Reply With Quote
Old 04-21-2009, 01:26 AM   #203
hater06
Member#: 139699
2011 WRX STi Limited
i just bought a set of used KYB AGX adjustable struts with Prodrive springs and Group N strut tops... this came off a 2002wrx... just to be clear after reading the articles... i would need to get the spacers for the rear struts only for a proper non-knocking fitment right?
all this suspension talk has really confused me... and yes i'm a complete suspension n00b.
hater06 is offline   Reply With Quote
Old 04-21-2009, 02:31 AM   #204
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
if they are completely assembled (struts, springs, tophats) then you don't need anything, they will bolt right in
it's only when you're mixing 04-07 springs/tophats with 02-03 struts that you need the spacers
UkNuck is offline   Reply With Quote
Old 04-21-2009, 08:48 AM   #205
hater06
Member#: 139699
ohhh sweet... thanks for the reply!
Old 04-28-2009, 03:18 AM   #206
WRX_JUNKi
Member#: 100695
2006 WRX Limited
Will a stock FSB from 02 fit on a 06 WRX? Also, is there a size difference on the stock FSB's from 02 and 06? TIA.
WRX_JUNKi is offline   Reply With Quote
Old 04-28-2009, 03:46 AM   #207
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
Does a 25mm Perrin Adjustable Front Sway Bar fit a 2005 wrx wagon with Perrin Wagon end links? I've heard it works with the right set of shims, provided with the end links.
nicholam is offline   Reply With Quote
Old 04-28-2009, 11:56 AM   #208
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
They should swap fine, but no difference in size from 02 WRX and 06 WRX for the front bar.
drew
AndyRoo is offline   Reply With Quote
Old 04-28-2009, 10:51 PM   #209
polonia2
Member#: 112262
Hi Guys,
I need a little help here. I read all FAQ but cannot find exact scenario. I have 06 Impreza RS and recently bought stock 05 STI spring (version 9) off craiglists. I want to know if the spring will work with my stock struts without any modification?
Thanks,
polonia2 is offline   Reply With Quote
Old 04-28-2009, 11:20 PM   #210
mdungelman
Member#: 97251
'13 Impreza 2.0i
Yes, the STI take-off springs will directly swap with your stock springs.
mdungelman is offline   Reply With Quote
Old 05-08-2009, 07:38 AM   #211
roarksbane
Member#: 177658
2004 WRX Wagon
So I just upgraded my 04 wagon wheels to 17x7.5 enkeis. During installation I noticed my RF strut seems to be leaking oil, so I already have another mod to perform. I am looking at upgrading to an STI spring/strut setup, but it seems they don't even make them for my wagon. Am I wrong? Keep in mind my car is a daily driver, I am a spirited driver, and I prefer function over form. I am not looking to lower (at least to the point where function is sacridiced). Please help with an STI setup that is 04 wagon specific.
roarksbane is offline   Reply With Quote
Old 05-08-2009, 08:45 AM   #212
my name is joe
Member#: 171412
04-07 wrx you said that oem sti springs fit without problems. what about jdm pinks? think you should include that too. love this thread haha. if you had products down that would be even better help but dreadfully long to do.
(sorry if this had been said before, didnt read through all the pages yet)
my name is joe is offline   Reply With Quote
Old 05-08-2009, 09:02 AM   #213
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
it's right there in post #3 - they will fit but are a bit too stiff for the WRX dampers
Springs
Springs for 04-07 RS or WRX will fit.
Aftermarket springs designed for Impreza STi will be too stiff for stock struts. OEM STi springs work well though.
Old 05-08-2009, 09:14 AM   #214
my name is joe
Member#: 171412
arent the pinks oem in japan?
Old 05-08-2009, 11:43 PM   #215
MERT K
Member#: 81807
07 WRX STi
Urban Grey & wingless
i read all of this and searched legacy pages for ever... i have a 92 legacy l wagon and i was told 04 sti strut/spring assembly bolts right in... but i heard a may have to change the top hat... which one from what car would work for this conversion, and will the front be way higher than the back or anything crazy like that? please expain what i need to do to make this work. thanks
MERT K is offline   Reply With Quote
Old 05-16-2009, 10:35 AM   #216
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
2004 STi front sways and GD N/A wagon front sways are the same length. The STi bar does have a slight angle to the mounting tabs which is not there on the wagon bar.
I am currently running the '07 wagon front sway with '04 STi control arms. End links are vertical at stock N/A ride height.
sniper1rfa is offline   Reply With Quote
Old 06-09-2009, 08:03 PM   #217
gaugeof12
Member#: 132859
2015 WRX
CWP
Originally Posted by RaceComp Engineering View Post
2004-2007 Impreza WRX, WRX Wagon, 2.5RS, 2.5 RS Wagon, Outback Sport
Struts
The following have a specific fitment for 04-07 WRX and RS, and all spring and strut top fitment with these is the same as it is for the stock struts.
1. Koni Inserts (not a complete strut, see here for install http://forums.nasioc.com/forums/show....php?t=1219607)
2. Ohlins Fixed Perch Struts
3. STi Version 8 OEM (2004 USDM STi)
4. STi Version 8 Arai Pink Struts
The following OEM and aftermarket struts for 02-03 Impreza can work in 2 ways.
1. KYB AGX
2. KYB GR2
3. Koni Inserts (there is an 04+ specific version too, so you can just get that)
4. Tokico HP
5. Tokico D-SPEC
6. STi/SPT Version 7
Either by using 02-03 springs and 02-03 rear strut top mounts.
OR
By using 04+ style springs, 04+ style rear strut top mounts, and the Scooby921 strut spacer. Details on why the spacer is needed available here:
http://forums.nasioc.com/forums/showthread.php?t=563382
Scooby921 Strut Spacer available here:
http://www.turninconcepts.com/produc...=234&osCsid=d9
05+ STi struts will not fit.
Wagons are different, see notes below.
The GR2s now have 04+ rear fitment available. Part numbers 334359 & 334358.
You can note the difference in the photo here...
KYB Stock photo 04-07
KYB Stock Photo 02-03
Photo from the spacer thread
gaugeof12 is offline   Reply With Quote
Old 06-10-2009, 03:16 PM   #218
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
great! i'll update the thread when i get home from work. and i'll try and add some 09-09 wrx and sti stuff.
- drew
Old 06-21-2009, 03:08 AM   #219
cdshot10
Member#: 213511
"2002-2007 2.5RS, TS, and 2.5i strut tops are softer then both WRX and STi strut tops (which are the same stiffness). confirmed?"
Has this been confirmed? The reason I ask is because I have 05 top hats from an RS which I plan on using with my rce wagon springs and 04-07 koni inserts using my 02 housings.
cdshot10 is offline   Reply With Quote
Old 06-21-2009, 03:50 AM   #220
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
Has it been confirmed yet that any front/rear strut tower bars made for 02-07 Impreza will fit on a 93-01 Impreza yet?
Suby<3777 is offline   Reply With Quote
Old 07-23-2009, 02:34 AM   #221
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Nice post. Didn't read all 9 pages but the strut bars will not fit from an 02-07 to a 97-01.
PhilSine is offline   Reply With Quote
Old 07-29-2009, 07:33 PM   #222
garrett02bugeye
Member#: 218501
2002 wrx
world rally blue
s13 240sx coilovers fit on 2002 wrx? please help!!!
garrett02bugeye is offline   Reply With Quote
Old 07-29-2009, 08:57 PM   #223
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
no, very no.
- andrew
Old 09-18-2009, 01:21 AM   #224
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
Anyone know if this will fit on a GF:
http://cgi.ebay.com/ebaymotors/Subar...Q5fAccessories
They advertise it and say it fits any 93-01 Impreza or 98-08 Forester but it looks exactly like the ones they make for 02-06 WRX's which don't fit on our cars. The very picture they have for it shows it with a WRX motor. I have even gone as far as sending a message to the seller asking him if it will fit my 99 Impreza and he said it will although it does not sound like he know's what he is talking about. So just wanted to make sure and run this by you guys just in the off chance that they are making these strut bars for our cars now. Let me know. Thanks, Dan
Old 10-23-2009, 04:38 PM   #225
Brisky
Member#: 148078
2001 Legacy GT
Birch White
Soo...
According to this thread 05 STi springs will not work on a 93-01 Impreza.
However has anyone actually tried it if they change the rear strut mounts?
Any help is appreciated.
Thanks!
Brisky is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 12:46 PM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 07:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 07:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 11:25 PM
