Mid Atlantic Impreza Club
Old 07-12-2007, 10:59 AM   #1
Zoinks
Member#: 35924
Default Mid-A AccessPort people - 91 or 93 octane maps?
Just wondering - for the people around here using APs, especially at stage 2, do you run the 93 octane maps, since we do have 93/E10 gas, or do you run 91 to play it safer?
Zoinks is offline   Reply With Quote
Old 07-12-2007, 11:02 AM   #2
meridock
Member#: 37868
2010 Corvette Z06
I ran the 93 map OTS before my protune and then retuned after the E10.
The 93 OTS is just fine IMHO for E10 Mix.
meridock is offline   Reply With Quote
Old 07-12-2007, 11:05 AM   #3
youngmoney
Member#: 152758
2006 Lamborghini
Gallardo
93 oct of course.
heck theres not even 91 oct except for sunoco.
its bad to run 91 oct on a 93 map
youngmoney is offline   Reply With Quote
Old 07-12-2007, 11:05 AM   #4
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I have been running the 93 maps for a while in our '02 and never had a problem.
Jard is offline   Reply With Quote
Old 07-12-2007, 11:10 AM   #5
Zoinks
Member#: 35924
Thanks for the responses so far. I figured most people would run 93, but didn't want to assume...
Originally Posted by youngmoney View Post
93 oct of course.
I'm actually asking if people run 93 gasoline and a 91 map, not vice versa. Cobb says you may want to run the 91 map on 93 gas if you get detonation.
Old 07-12-2007, 11:15 AM   #6
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I used to run the 91 map on 93 octane when I had my '04 WRX. I was traveling a lot to rural PA where the only gas available was 92 sometimes.
I also said I could care less about 5 more hp to be a little safer.
I say meh now.
Old 07-12-2007, 11:36 AM   #7
mla163
Member#: 104922
2016 WRX
I've never had a problem with the 93 map
mla163 is online now   Reply With Quote
Old 07-12-2007, 11:36 AM   #8
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
The octane is rated the same for e10 as non-e10. The timming is advanced or the boost is increased on the 93 map to produce more HP. So, you could blend all types of gas/ethanol as long as they have 93 or higher octane.
Rippen Griffen is offline   Reply With Quote
Old 07-12-2007, 01:16 PM   #9
wanalaugh74
Member#: 148922
2004 Sti
Im running the 93 map and its seems great.
wanalaugh74 is offline   Reply With Quote
Old 07-12-2007, 02:06 PM   #10
MiTurbinEsDerty
Member#: 107453
I use a 93 map because its readily available. 93 > 91.
MiTurbinEsDerty is offline   Reply With Quote
Old 07-13-2007, 08:18 AM   #11
styng88
Member#: 55541
05 Saabaru
96 Miata
My base map is Stage 2 93 and I run both 92 and 93 octane gas with no problems.
styng88 is offline   Reply With Quote
Looking for 91 or 93 octane ver8 EJ207 timing map jblaine Engine Management & Tuning 13 03-10-2011 06:49 PM
Running 91 on 93 Octane map...HELP! FLAME AccessPort 10 04-21-2008 05:05 PM
91 AND 93 Octane Maps? black05STIguy AccessPort 4 01-31-2007 08:47 PM
91 or 93 octane map for 92 octane? JiDM_WeRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-12-2005 01:16 AM
TXS Stage 2... 91 vs. 93 octane map andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-19-2002 04:25 AM
